Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > General BMW Questions
Use this forum to ask general question about the BMW ownership and keep up on the latest BMW news. Direct all model specific questions to model specific forums below.
Old 11-19-2005, 04:49 AM
docror docror is offline
Mein Auto: BMW 328i Convertable
BMW 328i Cab (E36) vs BMW 330ci Cab (E46)
I am the rpoud owner of a BMW 328i Cabrliolet - 1998. This is one of the last few to be imported to SA. I have been looking at buying a BMW 330ci (E46) cabriolet and was wondering if any of you out there can give some comparisons. I have a motor journalsit friend who own a M Coupe based on the Z3. His comments were that I would be dissapointed as he feels the E46 was "numb" compared to the E36. Any other comments?
Old 11-21-2005, 05:41 AM
Passenger Passenger is offline
Mein Auto: E46 325ci
Most cars would feel numb to somebody acustomed to the "arsey" antics of an M Coupe.[... with it's M power applied to the road via the primitive rear end !]
Early E46s were often described as feeling a little "remote" but mods to the front end and to the power steering weight from 2002 helped.
I moved from an E36 318i [...not a fast car but beautiful handling, thanks to the light engine] to an E46 325 coupe. I prefer the E46. Slightly different feel but just as responsive and equally fun.
Old 11-21-2005, 06:14 AM
LmtdSlip's Avatar
LmtdSlip LmtdSlip is offline
Do the interns get Glocks
Send a message via AIM to LmtdSlip
Mein Auto: 325iC
The E46 vert is far stiffer than the E36. The roof structure of the folding top on the E46 was significantly improved and much stronger and stiffer than the E36. So that alone should improve the driving experience.
Photobucket
Old 11-21-2005, 08:53 PM
Some more help
Thanks guys for your info. I am very keen on getting a 300ci vert. Some more help or info please. From time to time I get a "Brake Light Circuit Fault" warning. This happens irregularly. However when checking the usual light bulbs nothing wrong. Any ideas what could be causing this? I used to own am 1992 525i and prior to the battery saying cheers it would also give funny warning messages. Could this be the problem?
Old 11-22-2005, 06:09 AM
LmtdSlip's Avatar
Mein Auto: 325iC
COuld be. Or the contacts of the bulb and/or the socket are getting a bit corroded.
Photobucket
Old 11-22-2005, 07:32 AM
Light fitting
Now that you mention it there is a very tiny hole in the left hand side light bulb metal contact. Can you replace this or should you replace the entire light fitting?
Similar Threads
Wall Street Journal Article on BMW's Past, Present and Future Salvator General BMW Questions 65 12-25-2010 08:22 PM
1998 M3 = 540i = 740i = 20K rumratt General BMW Questions 36 01-12-2007 06:26 PM
Option code list Terry Kennedy General BMW Questions 16 05-14-2006 03:59 PM
Is Lemförder (the owl) the OEM Control arms supplier? Fifty_Cent 3 Series & 4 Series 1 09-18-2004 07:56 AM
Just got a BMW 330Ci E46 TWELEVIE 3 Series & 4 Series 23 04-05-2004 06:51 PM
