E46 (1999 - 2006)
The fourth generation 3 Series (E46 chassis) was introduced in 1999 and set the standard for engineering and performance during it's years of production including being named to Car & Driver's 10 best list every one of those years! ! -- View the E46 Wiki |
Reverse Clunk
I have read many threads about this but i would like an answer for my specific situation.
Im looking at a 2000 328i automatic with 135k. Everything works great on it except when i shift into reverse from park, after about 1 sec it feels like a mule kicked me from behind, but that is the only time there is any sort of clunk, there is none between any other gears. The explanation i have gotten is the rear diff. mount. I have read other posts with similar problems such as a reverse clunk and clunks when shifting to other gears, and people suggest transmission problems. I watched a short video of a bad diff. mount and i can see how that would create the clunk when shifting to reverse. So is this indeed the rear diff. mount? and second can i drive the car for a while with a bad rear diff. mount? keep in mind i do not drive my cars hard, and i only drive about 5k miles a year. Thanks in advance, Dan |
1. Yes.
2. Depends on how bad the mount is. |
so what eventually happens? the mount breaks apart completely if left unfixed?
I don't know what happens.
Mine was diagnosed as needing replacement. It's a $50 part, but they need to drop the differential to do it. I think the estimate was for over $800. Since it's not clunking too badly, I'll wait a while. I think it's just a rubber mount that gets old and cracks or something like that. |
Same Problem!
Hi there
I had this exact problem with my 2000 BMW 328i with 140kilometers Auto transmission. At first it freaked me out. Loud thumping noise into reverse and on weight transfer. I took it to the shop and they told me it was a cracked near diff mount. Turns out thats exactly what it was. The part was 50$ and had to be ordered. The labor was 3.3 hours at a total of 280$. Whole driveshaft and other big things apart on the back, hence all the labor. Now she runs like a damn dream. After it was done he showed me the part that came out. Looks like a small cup with a rubber core and hollow metal centre for the mount. It was indeed all the rubber that had cracked and there was play in the mount. So dont be afraid its not a tranny problem! |
My 96 328i has always clunked into reverse after initial start up. Goes away when warm. I'm not worried.
Transmission Clunks
I'm also trying to figure out why my transmission clunks when I shift car from park to drive or vise versa. I'm thinking maybe I need new transmisson or differential mounts? I also have a slight hesitation from first to second gear in the morning when I take my first drive (cold engine). Other than that it shifts great. Is there a way to see or check if the mounts are worn?
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
