E34 (1989 - 1995)
Old 12-20-2008, 10:02 PM
Nena Nena is offline
Mein Auto: 1989 535i
!989 535i doors locked....Help???
Mechanic said the car was ready to go after he finished working on the instrument cluster. He left it out on the street after he closed his shop so I could pick it up.
All the doors are locked and none will open with the key. I can only open the trunk.
Is there a trick to open the driver's door? Please help.
Thanx in advance
Old 12-21-2008, 05:34 AM
v8mick v8mick is offline
Mein Auto: bmw 318 is coupe
Ive had the same problem--and im sure on this site the answer lurks , but, if you go to bmw34.net and look under troubleshooting. You will find the answer.
Have you tried your key on the passenger door? Hold the handle up while you turn key.
Hope this helps.
Old 12-22-2008, 05:02 AM
cpnwrench's Avatar
cpnwrench cpnwrench is offline
Wrenchin' guy
Mein Auto: 92 525i
locked out.....
Ya ya ya ya,, I know this one........
found it in the Bently manual (doors / security etc) when it happened to me.... an I got a 92. 525.
something about the passenger side like the man says,, apparently when mechanic locked it it went to the "second-stage" lock... wierd I know..
But I believe thats correct, pass side while holding the handle up.
cpnwrench
Old 05-08-2013, 06:56 PM
Daniel Boon Daniel Boon is offline
Mein Auto: E34 530
Locked E34
Thanx in advance
I know this advice is late; however ...
Turn key anti-clockwise and life the handle, try separate combinations until you fee resistance on the key and or handle ... and drivers door should unlock, even if (car) battery is flat.
If all else fails, you will need a long thin rod, squat in front of the car where the kidney grill is an gently push the rod - between the bonnet and the panel immediately below it (its a tight fit) guiding it into the bonnet release catch, this will allow you to open the bonnet and put some charge into the car by placing the positive (red) cable clamp on the silver pole (with a dimple in it) and earth the other clamp and then fix to another battery preferable in a running car ... then your locking system will work ...
Daniel Boon (OZ)
Old 05-08-2013, 07:04 PM
Mein Auto: E34 530
Thanx in advance
Turn key anti-clockwise and lift the handle, try separate combinations until you fee resistance on the key and or handle ... and drivers door should unlock, even if (car) battery is flat.
If all else fails, you will need a long thin rod tapered to about 3mm (round or square); squat in front of the car where the kidney grill is an gently push the rod - between the bonnet and the panel immediately below it (its a tight fit) guiding it into the bonnet release catch, this will allow you to open the bonnet and put some charge into the car by placing the positive (red) cable clamp on the silver pole (with a dimple in it) and earth the other clamp and then fix to another battery preferable in a running car ... then your locking system will work ...
Old 05-08-2013, 07:05 PM
Mein Auto: E34 530
Old 05-09-2013, 07:12 AM
gmnmsclM540i's Avatar
gmnmsclM540i gmnmsclM540i is offline
545i pilot
Mein Auto: e60 545i e34 540 e32 740
Re: !989 535i doors locked....Help???
Wow this is the thread that led me to the fest when i had this problem a month later(jan 09)
Old 05-09-2013, 07:22 AM
BMR_LVR's Avatar
BMR_LVR BMR_LVR is offline
Humble E34 lover
Mein Auto: 1992 525i
Ah .... good times eh?
Steve
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 05-09-2013, 08:24 AM
reza338 reza338 is offline
Mein Auto: 535i E34
emergency closing or opening
refer to attached file
Old 05-09-2013, 11:27 AM
545i pilot
Well definitely strange to see again
Sent from my DROID RAZR using BimmerApp mobile app
Old 05-09-2013, 12:55 PM
E34ZombieHunter's Avatar
E34ZombieHunter E34ZombieHunter is offline
Nothin like an E34
Mein Auto: 95 540i B/B
What is second stage lock?
Old 05-13-2013, 01:54 AM
Mein Auto: 1989 525i M20B25
It double locks the doors so that the lock tab cannot be pulled up by thieves who break a window.
