Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > Z Series > E89 Z4 (2009 - current)
Old 12-23-2008, 11:15 AM
kevalent kevalent is offline
Mein Auto: 2006 Z4 3.0Si
'09 Z4 Article/Pics
Not sure if anyone's seen this from Edmunds yet but there's quite a few pics and some info. Looks like the new Z4 is going to be 221 - 364 lbs heavier than the current model and from the pics there is virtually no trunk space with the top down (maybe enough for a small duffle-bag) . It does get an optional twin-clutch transmission and the N54 TT though.
Article: http://www.edmunds.com/insideline/au...4roadster.html
Old 12-23-2008, 12:33 PM
SUNZOUT SUNZOUT is offline
Mein Auto: '00 M Roadster
PLease see the sticky at the top - Z4 2009 posts have their own forum...
TC Kline S/A Coilovers | Sharked | Turner Slotted Rotors | Axxis Ultimate Pads | SS Front Strut | IE Subframe Bushings | IE Rear Toe/Camber Kit
Whalen Shift Machine | Stygar Clutch Pedal | CDV Delete | LeatherZ Armrest | Whalen seat bushings | Z3Solutions Windblocker | Shift Pin fix
Old 12-23-2008, 12:43 PM
Ah, for some reason I never noticed that sub-forum before, guess I just like the earlier models better...haha. Mods please move this thread into the 09+ Z4 forum. Thx!
Old 12-23-2008, 04:48 PM
reidconti reidconti is offline
Officially Weird
Mein Auto: Clownshoe,Miata,WeeStrom
If it's that much heavier it seems clear BMW knows it's going into cruiser territory and they'll likely introduce a Z2.. can't wait!
Old 12-23-2008, 05:31 PM
greyish's Avatar
greyish greyish is offline
tire consumer
Mein Auto: 99 z3c
I like your thinking.. while we're at it, let's suppose a Z2 coupe for maximum happiness.
Old 12-23-2008, 05:33 PM
Officially Weird
Giggity giggity! (this board needs a Quagmire smily)
Old 12-23-2008, 08:26 PM
westwest888's Avatar
westwest888 westwest888 is offline
Banned
Mein Auto: 2010 Audi S4
Is it the case that the 255hp version will be about the same weight as the outgoing model? I think it's better to compare apples to apples. Adding the two turbos, the heavier engine block, the intercooler and fluid, the additional exhaust piping is 150 pounds, IIRC.
EDIT: I should have RTFM.
An sDrive30i with a manual transmission is 221 pounds heavier than its 2008 counterpart while the sDrive35i with a manual is up 364 pounds over its predecessor.
HTML code is Off
