Old 12-29-2008, 04:24 PM
westwest888's Avatar
westwest888 westwest888 is offline
Banned
Mein Auto: 2010 Audi S4
car-on-lift symbol warning on dash?
Hopped in my car to go to lunch today and the instrument cluster popped up this esoteric warning hieroglyph. It looks like a car jacked up the ceiling on a lift. I presume this means "Inspection 1 soon". Does anyone know for sure? I have 57,000 miles.
Inspection 1 sounds like a load of crap to me. I've already replaced the dampers, the brakes, brake fluid. I figure an oil change, oil filter, and air fliter next time. Anything else?
And how do I make that stupid icon go away?
EDIT: added the icon to this post.
Old 12-29-2008, 07:32 PM
AzNMpower32's Avatar
Tar Heel Faithful
Yeah, the vehicle is due for Inspection. I don't think BMW differentiates between Inspection I & II like they used to on the newer BMWs.
To make the icon go away, try hitting the BC button.
Old 12-30-2008, 06:58 AM
BimmerRat BimmerRat is offline
Mein Auto: 2007 335i Coupe
can you post a picture of the warning icon?
2007 335i Coupe Jet Black / Black Leather / Steptronic w. Paddles / Aluminum / Premium / Sport / CA / Navigation / Satellite
Old 12-30-2008, 07:30 AM
applebimmer applebimmer is offline
Mein Auto: 2006 330i
I can't say for-certain what that actually means but, on the left-side of your steering column you should be able to toggle through your Car inspector’s computer system. It can be done two ways. 1. You can press in the end-side which you are probably already know to get little things like MPG, or AVG SP, and things like that: Now: 2. On that same leaver there is a little notch that goes up and down; So, while the car is running and you’re in park, you can used this up/down function to check on other engine related issues. This functions tells gives you Service Info, Heating and Cooling Temp and fluid levels, emissions, it also shows that symbol you are referring to, so I would check there to see if any info registers. Just my .02.. Hope this helps.
2006 330i "Total Package and some"
1973 Caprice Classic "Darth Vader"
Gone not forgotten:
1994 525i E34 2.5L
2004 330xi E46 3.0L
Old 12-30-2008, 07:32 AM
-=Hot|Ice=-'s Avatar
-=Hot|Ice=- -=Hot|Ice=- is offline
Been there, Done that.
Mein Auto: Does it matter?
You're due for your 30k service.
Originally Posted by CaptainAudio
In the words of one of Bimmerfest's greatest minds:"Been there, done that"
Originally Posted by boltjaM3s View Post
Half the fun of succeeding in life is fighting the fight and making it.
Old 12-30-2008, 02:38 PM
Banned
Right, but I call shenanigans on a 60k service. Exactly what needs to be done?
Old 12-31-2008, 10:01 AM
328Vert_Jim 328Vert_Jim is offline
Mein Auto: 328i Convertible
Actually, if you could spare a moment to RTFM, you might be a lot more interested in resolving this.
Looks like the car-on-a-lift icon means bad things may be going on. If RED, you might have starter, ignition or lighting system issues. If yellow it could mean brake lights/fuel system/or trailer lighting (?) issues
Jim
'08 328i E93, Black Sapphire, Black Leather, Premium, CA, MT
Old 12-31-2008, 11:06 AM
Banned
Hmm. I just moved so all of my crap is in boxes, and the manual is out of reach for now. But I found the PDF online. I think this is my problem:
"The warning lamps light up in red
even though the handbrake has been
released. A message appears on the
Control Display. The brake pads have
reached the safe limit for pad wear. Have brake
pads replaced immediately.
That is odd because I just had the pads replaced. I know there is a pad wear sensor on the front left and right rear discs. It's an electromechanical connection - when a wire is able to press up against the disc, some rubber wears off of it, it makes a connection and it lights up the dash.
I'll have to take a look at what's going on.
I added the icon to the first post.
Old 12-31-2008, 02:47 PM
Sounds like you are on the right track. Didn't realize after reading the original post that the icon was accompanied by the "Brake" indication.
Jim
Old 12-31-2008, 02:53 PM
adc adc is offline
BMW Fahrer
Mein Auto: E90 M3
When mine lit up with under 10k mile, the dealer said it was the brake sensor getting confused. They reset the warning, then it came back a thousand miles later and so they upgraded the SW on the car - and never came back since.
This was awhile back, I think the SW was upgraded then from v27.x to v28.x.
Did you replace the brake sensors after replacing the pads? Many people recommend putting in new sensors, not sure why.
adc
15 M3 Sedan ED
13 X1 2.8i ED
04 Z4 3.0
Old 12-31-2008, 04:35 PM
Banned
I wonder if I can reset this myself the same way you reset the oil light.
I went out and checked the pads at lunch. They are about as thick as a deck of cards, which they should be since they are only a month old. You can see your pads by looking inbetween the spokes on the wheels, and looking under the caliper. You'll know when they are wearing down because the clips will be getting close to the rotor; eventually they will contact the rotor and make a squealing sound every time you brake, as a last warning. The outside front left was fine, which is what sensor 1 is connected to. Sensor 2 is connected to the inside rear right pad.
Plenty of brake fluid, and that is new also.
Old 01-01-2009, 09:00 PM
Banned
What a tremendous PITA. My car is in perfectly good working order, but some designed to fail sensor needed to be replaced with the pads. So you have to add $50 and labor to every brake job to replace these sensors that I didn't even know existed until they failed! It seems like needless complication. There's a squeal alarm AND an indicator in the dash of when the pads need to be replaced.
This truly might be my first bona fide frustration with the manufacture of this car.
Old 01-02-2009, 07:57 AM
adc adc is offline
BMW Fahrer
Mein Auto: E90 M3
Hehe, that's because you didn't get the twin turbo motor...
Anyway, I've bought brake sensors before from Zeckhausen and they were around $15-20 per piece (two needed). Replacing them is a matter of removing the wheel, unplugging the sensor at both ends (pad and plug) and from the retaining brackets - a 5 minute job, no more.
The only problem is, this may not necessarily fix the dash warning - in my case, the sensors were the original ones (in perfect working order) and the dealer never replaced them. They simply did a software reset.
Try finding an independent in your area (www.bimrs.org) - if you find a good one, they should be able to rest the warning for a nominal fee (less than $50).
adc
15 M3 Sedan ED
13 X1 2.8i ED
04 Z4 3.0
Old 01-02-2009, 01:36 PM
Banned
No one had a clue about a turbo motor in 2005 when I bought my car. The mere suggestion or forced induction or a model change-up before the LCI was blasphemy. Anyway, my car gets me from A to B in style and around the track quick enough that I want to kiss the ground when I get back to the paddock in one piece.
I think I'll drive around with the light on until I get my next oil change. I can't devote an entire morning to car diagnostics.
Old 01-02-2009, 02:40 PM
adc adc is offline
BMW Fahrer
Mein Auto: E90 M3
I was still driving my ZHP in 2005 and frankly was none the worse for it...
The current 335i is an experiment (lease), to see if I would want the engine longterm. It's fast enough allright, but it lacks in other areas (tires, suspension). I'm still on the fence between a (modified) 135i or a (stock-ish) E90 M3 for my next car.
Good luck with the warning. If you have the time, you could also try a battery reset (disconnect).
adc
15 M3 Sedan ED
13 X1 2.8i ED
04 Z4 3.0
Old 01-02-2009, 03:37 PM
Banned
I'd really like to replace the 2006 Miata with a 2009 Z4, on the condition I can get it for $1000 over invoice and 0.9% financing. I'd go for the trusty naturally aspirated engine and a 6 speed, mostly because I don't want to pay $7-8k for the turbo. For that price, I'd buy a Cayman or Boxster in the non-S variant.
I couldn't part with my 325i. I have the suspension set up just the way I want it after so much fiddling. When I see a stock e90 M3, all I can think is how I'd be gutting the suspension and brakes to bring it up to snuff.
The 135i is cool because it has nearly a full M tech sport package on it. But it loses some points for only accommodating a 215 width tire on a 7.5" wheel up front. I think 8" is the max, and 8.5" will rub. Not a deal breaker but something to keep in mind. Also, something about the longer wheelbase seems to give the 335i e92 coupe a performance advantage in lap times - it's a better chassis for some reason even though it weighs ever so slightly more. Even more interesting, Turner Motorsports thinks the e90 sedan has better aerodynamics than the coupe because of the way the rear windshield puts downforce on the trunk.
Old 01-03-2009, 07:50 AM
adc adc is offline
BMW Fahrer
Mein Auto: E90 M3
Yeah, I got that about the sedan, that's why I was thinking about the E90 M3 (well and the significantly lower price of course). I test drove the E90 M3 at Watkins Glen in the rain, on those bumpy and narrow country roads and it was absolutely fantastic. Sure you can always improve things in the suspension department, but right off the showroom floor it blew my mind away - and no understeer whatsoever. Brilliant.
There are a number of posts on e90post and 1addicts about fitting M3 upper/lower front suspension arms, rear subframe bushings, rear sway and other M3 components to the 3 or 1 to make it handle more like the M - meaning banish the understeer while keeping useful suspension travel and correct geometry (and possibly also the warranty intact).
So there are ways to make the 135 or 335 handle very well (as you know by now), but it would still be missing a real diff, and the OEM tires are still crap. So I have to think if a $45k modified 135i makes more or less sense than a $54k stock M3 - right now, I just don't know. The 135i would cost me around $37k for Euro Delivery, but still, $7k in mods is alot of money that I'll never see back...
adc
15 M3 Sedan ED
13 X1 2.8i ED
04 Z4 3.0
Old 10-23-2015, 09:19 AM
chillingliketha chillingliketha is offline
Mein Auto: 3 series - 328xi
car on lift signal
Hello,
I drive a 2008 328xi and I had same issue while driving to work this morning.
Got the car on lift signal (yellow) for a few seconds and the car went of while in drive. I turned on my hazard light and then stopped fully on the road, put the car to park and hit the start button, the car came back on but the cooling/AC fan was as loud as a trucks engine.
I managed it to work (5 mins drive) but it kept hesitating when I tried to move. I just fixed new rotors and brakes (all round) from BMW dealership last month so I don't think that's the issue.
Any expert advise or thoughts will be appreciated...
Many thanks
Old 10-23-2015, 09:37 AM
Tom K.'s Avatar
Tom K. Tom K. is offline
Since the car on a lift can be a generic service issue warning, you might try to read any stored check control messages.
2007 On Line manual, p.83 (Button 1 is the small lever on the turn signal stalk, button 2 is the button on the end of the stalk.):
1. Push button 1 in the turn indicator lever up
or down repeatedly until the appropriate
symbol appears in the display, accompanied
by the words "CHECK CONTROL".
2. Press button 2.
"CHECK OK" appears if there are no Check
Control messages.
If a Check Control message has been
stored, the corresponding lamp comes on.
It is accompanied by a text message on the
Control Display.
3. Push button 1 to check for other messages.
4. Press button 2.
The display again shows the outside temperature
and the time.
Good luck.
Tom
Old 10-23-2015, 10:00 AM
car on lift signal
2. Press button 2.
Control messages.
Control Display.
4. Press button 2.
and the time.
Good luck.
Tom
Just did that and all I can see it the bulb light... driver side angel/halo bulb is bad..
Guess I'll have to go diagnose it to see if there's any other issues
Old 10-24-2015, 06:49 AM
wilt wilt is offline
Mein Auto: 2011 328i
Originally Posted by chillingliketha View Post
Hello,
Many thanks
"Lights up in yellow (without secondary indicator light):
> Control of the brake lamps failed or
> fuel supply malfunctioning
You can continue your journey, but
moderate your speed and exercise due
caution. Have the system in question
checked without delay."
The car on the lift symbol might also indicated need for periodic state inspection, as determined by the reset date interval
Old 10-24-2015, 08:10 AM
need4speed's Avatar
need4speed need4speed is offline
Mein Auto: 16 435 CV Msport PPK/335d
This has a different icon that pops up.
