E28 (1982 - 1988)
Old 03-14-2009, 11:12 AM
viperjesse viperjesse is offline
Mein Auto: 1985 528e
Now my side lights don't work???
1985 528e, new SI board and new brake light switch fixed everytning. My side lights were working fine. I was installing a CD player and amp. They still worked with the cd player but when I was hooking up the amp my power wire touched a ground and sparked.
I'm thinking this blew something. I checked fuses 9 & 10 they look good and I have 14 volts on both sides of the holders but all four side lights are out. Everything else works fine.
Oh yeah, The battery died on me yesterday so I recharged it and reset the SI lights by jumping pins 1 & 7.
Thanks in advance
JZ
Old 03-14-2009, 03:48 PM
Are there more fuses under the dash??
The wire I connected constant 12v power to the amp was a red wire up under the dash by the hood release.
JZ
Old 03-15-2009, 07:43 AM
OK, the right side works. Left side took another new bulb in the front so that one works. I have no voltage to the left rear side light. All other lights, turn signals etc. work. The car's wiring and mechanicals are in factory condition, nobody ever changed anything.
I tried a seperate ground wire directly to the battery neg and still no light so I'm thinking it is a power issue.
Old 03-15-2009, 01:50 PM
I shoulda continued my troubleshooting. A combination of a bad new bulb and a bad wire in the rear.
All is well now.
JZ
