Old 01-06-2009, 04:17 PM
Fast6 Fast6 is offline
matching revs in
Mein Auto: Z4 M Coupe
Question Z4MC: how long to adjust valves?
Dropped my car off for Inspection I this morning and to address one other issue. Just got a call from the SA to let me know that they'd be done with it late tomorrow. Reason? "Adjusting the valves is a 6 hour job."
I've never gotten dirty inside an S54; is this true?
'06 M Coupe - Silver Gray/Sepang Brown Dark/Aluminum
E36 M3 - gone
E24 645 - gone
Old 01-06-2009, 04:30 PM
blau335 blau335 is offline
Mein Auto: 335
No, it might be billed 6 hours, but especially on a z4 it's not, remove valve cover, check, change shims if needed, rotate engine, check, change shims if needed, replace valve cover. Don't even have to hassle with the cowling in our car like the e46.
They do however, have to let the car cool off, preferably in the bay, so they probably leave ot over night and do it first thing in the morning.
http://www.youtube.com/watch?v=OqX7IIaXtkg Is it on a dyno? No.
TCK d/a coilovers, Stoptech 6/4 piston BBK, OEM CSL headers
Old 01-06-2009, 05:18 PM
pal's Avatar
pal pal is offline
S54=Living on the Edge
Mein Auto: 2007 M Coupe, 2004 Audi T
Fast6 - How many miles on your car?
Old 01-06-2009, 05:30 PM
matching revs in
21k
E36 M3 - gone
E24 645 - gone
Old 01-06-2009, 05:53 PM
jragan's Avatar
jragan jragan is offline
Mein Auto: 07 Imola Red/Black MCoupe
What were the issue(s)/indicator(s) that the valves needed adjustment?
His: E86 ///M Coupe: Pics Track Pics Vids
Hers: 997-1 C4S: Pics
Old 01-06-2009, 05:56 PM
jmillet's Avatar
jmillet jmillet is offline
Mein Auto: E86 Z4 M Coupe 7LM08376
Wink How about three hours
Might take six hours for a do-it-yourselfer like me but shouldn't take a trained dealer tech more than three hours
http://m3forum.net/m3forum/showpost....&postcount=124
Be sure they provide you with a list of before and after adjustment valve clearances.
Jim Millet
2007 Imola Red Z4 M Coupe'
Premium Package, Nav, HD Radio, Heated Seats, CDV Delete, RPI Scoop, Strong-Strut fire wall braces, TCK DA Coil Over Suspension with Camber/Caster plates.
Old 01-06-2009, 07:15 PM
matching revs in
It's a standard part of Inspection I/II to check and adjust as necessary.
Thanks for the info Jim. I will call them in the AM to make sure they get me that list.
E36 M3 - gone
E24 645 - gone
Old 01-06-2009, 07:55 PM
Ron Stygar's Avatar
19,585 Miles
Z3 S54 valve check: http://www.bimmerfest.com/forums/sho...t=valve+adjust
This is my first valva adjust / check with Randy's chart.
Old 01-06-2009, 07:58 PM
Ron Stygar's Avatar
19,585 Miles
If it's still eight units per hour around 4.5 hours.
Old 01-06-2009, 08:09 PM
Ron Stygar's Avatar
19,585 Miles
Some tool info if you decide to do it.
Old 01-07-2009, 09:51 AM
matching revs in
Thank you, Ron!
E36 M3 - gone
E24 645 - gone
Old 01-07-2009, 10:01 AM
Ron Stygar's Avatar
19,585 Miles
Thank you, Ron!
See what part numbers are on the invoice.
Gasket, sealing rings and maybe some adjusting plates.
Old 01-07-2009, 05:57 PM
matching revs in
Talked to the tech; he didn't keep a list, but he found 2 tight valves and one loose one. One of the shims he pulled out was able to be used at one of the other valves.
Parts related to valve adjustment:
1x 11-34-7-832-286 Adjusting plate
1x 11-34-7-832-283 Adjusting plate
1x 11-12-7-832-034 Profile-gasket
6x 11-12-7-831-271 Profile-gasket
They also correctly filled the engine oil for the first time since I've had the car.
Car and owner are happy.
E36 M3 - gone
E24 645 - gone
Old 01-07-2009, 06:00 PM
Ron Stygar's Avatar
19,585 Miles
Good.
Old 01-08-2009, 09:25 AM
Mein Auto: 335
Tight vales
