E30 (1982 - 1993)
Old 01-11-2009, 08:24 PM
bughaus bughaus is offline
Mein Auto: 1986 325es
doesn't start
I have a 1986 BMW 325es which I bought a couple weeks ago. This was pretty exciting for the 2 weeks that it ran. But now that nothing happens but a single click when I turn the ignition, I've quickly become weary of push starting it. Just doesn't look cool.
I charged the battery; no help. I took out the starter and tested it; it works. I bypassed
the 26-year-old wiring by connecting the starter directly to the
battery; nothing except the sparks when I connect it.
Clearly there is something else at play, but I'm too inexperienced to know what it
is. Maybe there's something wrong with the ignition (certainly
possible when you consider that to start the car you turn the key to
the "on" position and then depress a doorbell installed by the last
owner) but I don't know how to test that. Or there is some kind of
clutch interlock messed up and blocking the way.
I'm driving my bicycle to work every day, but I haven't left a 5 mile radius from my
apartment in a long time. Help me move on to the 27 other problems
which need fixing once it starts!
Old 01-11-2009, 09:22 PM
JohnMadd's Avatar
JohnMadd JohnMadd is offline
obsessed
Mein Auto: 1989 325is 03 330i ZHP
unhook your battery for a couple minutes-2-and then rehook and reply what happens and this is the first thing to do.
This will reset the computer.
Old 01-11-2009, 09:24 PM
Ryan M Ryan M is offline
Mein Auto: .
Conduct a voltage drop test. Put the positive and negative leads of a voltmeter on the positive and negative battery terminals. Then have someone crank the car. You should get a voltage drop.
For Sale: M60B30 intake manifold, M50 intake manifold, 2.81 differential, new OEM upper control arm bushings, 8 M62 fuel injectors.
Old 01-12-2009, 07:52 AM
lordofthewaters's Avatar
lordofthewaters lordofthewaters is offline
Rather Large Member
Mein Auto: 88 325is 04&09 jetta TDi
Check your engine ground on the driver's side of the oil pan.
An easy way to test if this is your problem is to: Clamp one neg clamp of your jumper cables on the oil plug, and the other neg clamp on the strut tower or steering rack, and try and turn it over. If it cranks you need to replace the ground.
Sarcasm is a body's natural defense against stupid.
When a man talks dirty to a woman, it's sexual harassment. When a woman talks dirty to a man, it's 3.95 per minute.
"My mother never saw the irony in calling me a son-of-a-bitch." Jack Nicholson
Old age and treachery, will always overcome youth and skill.
Old 01-12-2009, 11:54 AM
metroman810 metroman810 is offline
Mein Auto: e30 325i cabby
how did u test the starter , your sure the thrust bearing on the starter is good, or there aint a flat spot on the starter bushes , have u tried bypassin the starter relay with a screwdriver .if u do this an it still just goes clunk, then im stumped sorry
Old 01-15-2009, 11:38 AM
OK, so the problem is the starter motor won't turn over when I turn
the ignition. the problem is not the battery as it's charged and jump
starting did not help. The starter does work; it was tested at
autozone, and also it works if you do some bypassing.
I took a piece of wire and connected the power source to the wire going
from solenoid to starter motor; this works. So you might think the
solenoid is shot.
But next I connected the power source to the terminal that runs the switch allowing current through the
solenoid and it worked again. which would argue that this terminal is not
getting juice.
So I took the wire off of the terminal, touched it to a test light, turned the
ignition, and it lighted up; power gets through the wire to the terminal
that operates the switch in the solenoid. The connection is not corroded; I replaced it.
I suppose maybe not enough current gets through the wire to the terminal
; I don't have a voltmeter, but the test light is nice and bright.
Is there some other angle I should be taking here?
unhooking the battery for a few minutes didn't help.
I should get the battery load tested some time, but things didn't work with a jump.
I did not check the engine ground thing yet.
1986, 325e, electrical, ignition, starter
