E34 (1989 - 1995)
Brake wear indicators
I have BMW 520i N reg (1995-1996) 2litre 24 valve saloon
Basically, the brakes wearing down n the brake wear idicator didnt show, n wen brakes changed it was because the pad without the indicator was worn down first anyway, had all discs and pads replaced both on rear or front, but the handbrake shoes were not replaced (seperate to my discs and pads at rear) anyway all of s udden for no reaosn the brake wear indicator came on, ignored it n it went off n then came back on and has been on wen ever id rive the car now i kno that on one of the brake wear idicators prev owner cut it, n rumours are tht because it is an open circuit a ssuch it causes light to come on, however, its not been on before whilst this has been cut any ideas how to solve it and wud it b safe to close the ciruit by connecting the two wires on the one side on the one wheel togteher to "close" the circuit? please help |
solved it by looking at another page on different series, that being, turn the key to position 2 so electrics work but the engine is NOT started, leave 30 secs - min, turn off, wait half min n then turn engine on n shud go out
doesnt work
the idea someone gave me works of r ahilw but then the light comes back again, checked pads n discs nt hey are stil in new coniditon
The wear sensors work by cutting continuity to the circuit. If they have been removed the connectors can be jumpered or if cut the wires can be connected to prevent the message (make sure they are well insulated to prevent corrosion). It only costs about $10 for the wear sensors. It would be good to replace them. There is no other warning system for low brakes on this car. You can install the sensors without taking everything apart.
If you jumper the connectors or install new sensors and the message is still up you probably have a wiring short.
sorted
the prev owner actualy cut the prev sensor off completely, so iv just left it off, prevents problems etc etc, so looped it n all insulated so shudnt b an issue now
| Bookmarks |
| Tags |
| brake, brake wear indicators, indicators |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
