Sponsored by The Tirerack. Moderated by Gary@Tirerack.com
Old 07-04-2003, 01:49 PM
Scotes's Avatar
Scotes Scotes is offline
Send a message via AIM to Scotes
Mein Auto: '03 M5
'01 325Ci and plus zero tire size on sport rims
I have an '01 325Ci with the sport package (the 7 spoke type 44 rims I believe) and while pokeing through a tire site sw something on "plus zero" sizing. I am somewhat familiar with plus one and plus two sizing and needing new rims for the larger tires but not about plus zero. The size they noted was 235/40/17 (stock on the car now are 225/45/17 Dunlop SP2000Es). Will a 235/40/17 tire fit on my stock rims without a problem? I've got 18k on the Dunlops and am probably going to go with Bridgestone S-03s as the replacments if it matters. Thanks!
Vince
'03 M5 Carbon Black
Stolen, recovered, auctioned: '03 530i 5sp Sterling Gray, SP, PP, modified CDV, Dinan rear sway, retrofitted NAV
"A democracy is a sheep and two wolves deciding on what to have for lunch. Freedom is a well armed sheep contesting the results of the decision." - Benjamin Franklin
Old 07-05-2003, 12:38 AM
Ashe too's Avatar
Ashe too Ashe too is offline
Common Sense, isn't
Mein Auto: '04 330i ZHP
Discount Tires Direct shows 235/45/17 as plus zero for a 325i w/ sport pkg.
___________________________________________
2004 330i | zhp | 6-speed manual
Old 07-05-2003, 09:06 AM
Gary@Tirerack's Avatar
Gary@Tirerack Gary@Tirerack is offline
Moderator
Mein Auto: 1995 BMW M3
235/40R17 will fit with no problem. Many E46ers also have used 235/45R17 with sucess, but this fitment may require a fender roll, especially if the car is slammed.
Refer to 'Gary/Bimmerfest' as your previous contact when you order online. Credit Bimmerfest.com by ordering through the sig link.
Gary@Tirerack.com
Old 07-05-2003, 04:15 PM
Scotes's Avatar
Mein Auto: '03 M5
Sorry, I should have noted 235/45r17 as opposed to 40. What do you mean by the car being slammed? Has anyone here put 235/40r17s or 235/45r17s on their stock 325Ci rims? Also, what are the upsdowns of going with this?
'03 M5 Carbon Black
Old 07-06-2003, 06:57 PM
Moderator
By 'slammed' I mean aggresively lowered. If you have 7.5" wheels the 235 width tires will look fairly stretched on that narrow of a wheel and you may need that fender roll . Other than that, should be good to go for a street tire.
Gary@Tirerack.com
Old 07-06-2003, 07:44 PM
Scotes's Avatar
Mein Auto: '03 M5
Gary - I show the BMW type 44 star spoke wheels on my 325Ci sport as being 8 X 17 so the 235s should work on my stock wheels without a problem them right? MY car is not lowered and is stock.
Has anyone out there put 235s on type 44s and if so do oyu have a photo of it?
'03 M5 Carbon Black
Old 07-07-2003, 05:16 AM
Moderator
If they're 8" wheels, the 235 width tires will mount on the wheels fine
Gary@Tirerack.com
