E36 (1991 - 1999)
Old 01-26-2009, 03:11 AM
2sickfish2 2sickfish2 is offline
Mein Auto: 1993 325i
Exclamation Instrument Cluster Not Working!! Help!!
I have a 1993 325i 4door and have recently just hooked up a new head unit sub and amp now only my speedo works out of my instrument cluster works all the rest (tacho temp fuel ect) when i start the car the hand break light and another red light next to it just light up and stay on for the hole trip. if anyone out there can help me it would be very helpfull before i have to take it to an auto sparky.
Thanks all lots
Old 01-26-2009, 09:00 AM
HyphE36's Avatar
HyphE36 HyphE36 is offline
Search Button Upper Right
Mein Auto: E36 95 325IS Black/Black
Check fuses and relays for the Instrument Cluster. Fuses that have to do with Instrument Cluster for your year should be 22, 23, 25, 27, 31, 37, and 46. I'm not sure if any relays (the larger squares in your power distribution box surrounded by fuses, there should be 15 relays, not all may be used) actually deal with the Instrument Cluster, however Relay #1. Fuel Pump Relay and Relay #2. System(main) Relay. may send information to the Instrument Cluster as well.
If there is no problem there then pull your new HU out and check to make sure the wires are connected without horribly interfering with any other wires in the area. You may also want to pull out your Instrument Cluster and check the connections to that. If all connections and electronic communications seem to be fine (use a digital multimeter to know for sure) then you may want to pull the cover off the back of the Instrument Cluster and look for a short in the circuitry on the Cluster itself.
Did you unhook your battery while installing your new components? Not sure if you have to or not, but it could be possible that if you didn't it somehow allowed for a power surge to reach your Cluster and fry parts, or pop a fuse, or relay, or fault wiring...
I'm doing similar tests/fixes in my car because my cluster won't light up, but its not the bulbs or the fuses, so I have to delve deeply into e36 electrical land too... it sucks...
There is a lot to check, good luck bro and let us know how it goes
Looking for a nice classic 2002, 1972-75 preferred
. SOLD
MEMBER OF THE MOST EXCLUSIVE SECRET CLUB ON THE 'FEST
Old 01-27-2009, 02:37 AM
Hey thanks for the help man i recheaked all of the fuses that you listed i had cheaked them all before bar 25 and replacing that seems to have fixed it.
God luck with your car bro and thanks again for the help
Old 01-27-2009, 05:08 PM
HyphE36's Avatar
Glad to have been a help bro and thanks for the luck wish, I'll need it to be rid of my electrical gremlins ><
. SOLD
dash, gauge, instrument cluster, tacho
