Old 01-27-2009, 02:57 PM
Fire One Fire One is offline
Mein Auto: 2003 Z4 & 2007 X3
2003 Z4 won't start
This is an intermittent problem.
Turn the key, hear a faint click click in the accessory possision - radio, dash lites, fan, ALL WORK , and continue turning to start the car and NOTHING !!! NO click, No engine turning, NOTHING
Repeat this one to thirty times and finally the car starts. This could take ten min's
Then the car starts great for ten days before the problem starts again.
My mechanic has the car now, but it is starting every time he turns the key. He can't trace the problem unless it won't start!!!
The starter motor was replaced & a new battery was installed. All cables look good & tight.
ANY IDEAS ??????
Old 01-27-2009, 05:14 PM
Bmwcat Bmwcat is offline
Retired Slacker
Mein Auto: A car.
Could be the switch in the clutch pedal is going bad; and it wont let the engine start. hard to say...
"Patriotism is the last refuge of a scoundrel." -Samuel Johnson
Old 01-27-2009, 05:17 PM
BKZ4MC BKZ4MC is offline
Mein Auto: '07 Z4 M Coupe
that's worse than mine... good luck man !
Old 01-28-2009, 05:43 AM
Good Idea but the mechanic checked the clutch pedal switch & it is OK
ignition switch, intermittent, starting
