Sponsored by The Tirerack. Moderated by Gary@Tirerack.com
Old 07-07-2003, 04:39 PM
bmw540i's Avatar
bmw540i bmw540i is offline
Technik Stg 1
Mein Auto: 01 - M62
Zr Y Rated Meaning
What does y rated and ZR rated mean. I know its speed difference but what does each mean
Old 07-07-2003, 04:41 PM
Mr. The Edge's Avatar
Mr. The Edge Mr. The Edge is offline
Mein Auto: .
ZR=149mph+
Y=186mph
http://www.tirerack.com/tires/tirete...eral/speed.htm
Belief cannot argue with unbelief, it can only preach to it
To clasp the hands in prayer is the beginning of an uprising against the disorder of the world.
Old 07-07-2003, 04:42 PM
alee's Avatar
alee alee is offline
Super Moderator
Mein Auto: '13 E92 M3, '01 E46 330Ci
Any compelling reason to get Y over ZR assuming that your car will never be able to hit 186mph?
2001 E46 330Ci - 42K miles, 2013 E92 M3 - 1425 miles, ED drop-off 4/26 Frankfurt, waiting for PCD
Old 07-07-2003, 06:02 PM
marcelgood marcelgood is offline
Mein Auto: 2004 330Ci
Well, if I understand correctly then ZR rated tires are always rated W or Y in addition, because ZR just says 149mph and above, but doesn't specify how much above. The manual should say wheather they are ZR W or ZR Y. My pilot sports sidewall markings say ZR, but according to tirerack, they are actually Y rated. Somebody correct me if I didn't get this straight.
Old 07-07-2003, 07:22 PM
The HACK's Avatar
The HACK The HACK is offline
Rest in peace, Coach
Mein Auto: '06 MZ4C, '09 WRX Wagon
The actual speed rating is behind the load rating...It'll say something like xxx/xx/ZRxx 91W, which will indicate a Z rated tire (capable of 149+mph) but should not go over 154mph, which is W rated tire's theoretical limit. If it says something like xxx/xx/ZRxx 89Y, it means the tire can handle up to 186mph.
"Bench racing" about track times driven by professionals are like a bunch of nerds arguing which Princess Leia is hotter, the slave Leia or the no-bra jail-bait Leia. No matter how compelling your argument is, the plain and simple fact is, none of you will EVER get to hit that.
Old 07-07-2003, 08:34 PM
The Roadstergal's Avatar
The Roadstergal The Roadstergal is offline
Butting back in
Mein Auto: GS500F
I was once told that the higher the speed rating, the better; it indicates better structural integrity at 'lower' speeds, as well. Anyone care to refute or confirm this?
"This is a revolution, dammit! We're going to have to offend SOMEbody!"
Old 07-07-2003, 08:37 PM
TGray5's Avatar
TGray5 TGray5 is offline
Ultimate Driving Machine
Mein Auto: '13 F10 550i; '11 R1200GS
The speeds quoted reflect the tires ability to hold that speed for one hour straight So there's a little safety margin built in for those of use that might hit solid triple digits for a few seconds every once in awhile But don't complain to me if you blow a tire at 150
Old 07-07-2003, 08:45 PM
The HACK's Avatar
Don't worry about me...I hit sustained triple digit speeds mostly on the track. It's STUKA/Butthead we need to worry about.
Old 07-07-2003, 10:36 PM
Emission's Avatar
Emission Emission is offline
Automotive Monomaniac
Mein Auto: Schnelle Autos
There is a valid reason to buy the highest speed rating you can tolerate!
Speed rating is based on the ability of the tire carcass to sustain the centrifical force, and the compound to sustain the high temps found during high speed cruising.
...With this in mind, a tire with a high speed rating of ZR or better will be much more stable, and less likely to blow, in the event of a sudden pressure lost at normal speeds. Those first critical seconds... when the tire pressure drops to zero... and the rim is pressing a flat tire against the pavement at speed... are when the extra heat tolerance and reinforced sidewalls will mean all the difference in the world.
I can't say a TR or SR tire will fail, but I will say a ZR or YR tire will fail in a much more controlled manner.
I will not let my wife (or myself) drive on tires with less than an HR rating. Sure, they cost a bit more, and ride a bit harsher... but the safety margin is everything.
My new Porsche site Flat6News http://flat6news.com/
I am fortunate to have unique press cars delivered weekly, but I own:
'13 Audi Q5 2.0T Quattro 8AT
'86 Porsche 911 Turbo 4MT
Gone, but never forgotten... E70 X5 35d, E90 335i, E46 330i, E36 328i, E70 X5 3.0si, E53 X5 3.0i.
Find my work on Autoblog or on my new Porsche site Flat6News!
Old 07-08-2003, 02:19 AM
Pinecone's Avatar
Pinecone Pinecone is offline
M Mad
Mein Auto: M Roadster/M3
The "official" speed ratings are S, H, V, Z. Those are the ones you find actually in the tires size designation (except they don't put an S in there).
So you get a 205/50HR15, would be an H rated radial (R) tire.
The highest rating is Z, which is above 149. But the tire manufacturers got worried about the speed potential for the super cars and started with additional ratings for Z tires to indicate the actual speed rating above 149. So Y or W rated tire is really a Z rated tire, with additional info.
That is why the Y or W, etc. is indicated folowoing the offical tire size and rating designation.
The higher the tire rating the better the construction to take the higher heat of high speed running. Typically the better handling tires end up with higher ratings.
Terry Carraway
'95 Alpine M3 LTW
'00 Dakar M Roadster
'02 Topaz M3
Old 07-08-2003, 05:34 PM
Stuka Stuka is offline
Mein Auto: German
Not all have the Y rating. Some Z rated tires actually are Z, 149+ with no upper cap. Well, the theoretical top speed of modern sports cars are around 240mph.
Guess what the Big Mac come shodded with?
There are plenty of cars now capable of breaking the Y rating nowadays, and their tires come with Z rating without the upper cap as indicated by the Y and the W.
Andy
02 M3 CB/Cloth SMG
Old 07-09-2003, 12:41 AM
Pinecone's Avatar
M Mad
Andy
02 M3 CB/Cloth SMG
The problem is, if you get a Z rated tire (and ONLY Z) you don't know whether the tire is only good for 150 MPH or 250 MPH. That is why the Y and W rating came about.
Yes, there are some Z rated tires good for 240 MPH, but you can't tell by the rating.
Terry Carraway
'95 Alpine M3 LTW
'02 Topaz M3
