E46 (1999 - 2006)
Old 02-02-2009, 07:30 AM
hansbockler hansbockler is offline
Mein Auto: 2001 325i
What type of Coolant?
I had posted a few days ago saying my coolant light had come on. Two questions:
1) when it comes on, it is only on for maybe a minute, then it turns off. should I even be worried?
2) what type of coolant? just any old 50/50 brand? also, under the hood, i fill it up under the cap that says "do not open when engine is hot", right?
sorry! my dad used to do all this stuff for me - now i am reaping the "benefit" of that
I have a 2001 325i
Old 02-02-2009, 08:45 AM
milobloom242's Avatar
milobloom242 milobloom242 is offline
gashlycrumb
Mein Auto: 325i
1) maybe it's the coolant level sensor going bad, if the fluid level is in fact ok
2) it's safest to pick up BMW coolant from the dealer
You can also find a local independent BMW mechanic near you, and have them check it out instead of the dealer. Search w/ this site http://www.bimrs.org/
Old 02-02-2009, 08:46 AM
KrisL's Avatar
KrisL KrisL is offline
Ubergeek
Send a message via AIM to KrisL Send a message via Yahoo to KrisL
Mein Auto: 330i ZHP
+1.. and only check the level when the engine is completely cold (i.e. first thing in the morning).
Old 02-02-2009, 08:49 AM
Solidjake's Avatar
Solidjake Solidjake is offline
Zero. Leaks.
Mein Auto: 02 330i 6MT
Hey Hans, go to the dealer and buy BMW coolant. It is 100% coolant and it comes as 1 gallon. Buy a gallon if DISTILLED water and have an extra gallon bottle from like milk or something and clean it out WELL. Put half of the distilled water into the empty gallon bottle so it's half and half between the two bottles of distilled water. Then pour half of the BMW coolant to one of the bottles and then take the other half a gallon and put it into the BMW coolant bottle.
When the car is cold, before you turn it on for the first time, check the level. You will see this little stick and the second ball from the top should be where it is shown in the pic. If not add coolant.
Old 02-02-2009, 08:50 AM
Strategery Strategery is offline
Mein Auto: 02 325i
Is there a cheaper place than a stealership to get BMW coolant? My local group of "I need to pay for my new boat" BMW guys charges 25 bucks a gallon for the crap..
Old 02-02-2009, 08:56 AM
Solidjake's Avatar
Zero. Leaks.
All the sites have them for like 15 to 20. after shipping and all it may end up being more than the dealer. Just go to the dealer and get it.
gashlycrumb
Mein Auto: 325i
CCA membership provides discount @ the dealer
Old 02-02-2009, 09:30 AM
jcourcoul jcourcoul is offline
Supporter of Bimmer Lore
Mein Auto: 2006 325Ci
Why do we use a 50-50% mix of antifreeze and distilled water?
Assuming that the active ingredient in BMW coolant is ethylene glycol, why that dilution? I know that it is an easier dilution, since you only have to do a half-and-half, but technically speaking a 60-40 mix gives you a wider protection range.
A 50% ethylene glycol and 50% distilled water mix freezes at -36F/-37C and boils at +225F/+107C*
A 60% ethylene glycol and 40% distilled water mix freezes at -70F/-55C and boils at +232F/+111C*
*Reference: http://www.engineeringtoolbox.com/et...col-d_146.html
So, does BMW coolant contain some other secret ingredient that requires the specific 50-50 mix, or is it just plain convenience? Cause the wider freezing/boiling range afforded by a 60-40 mix will probably look mightily attractive to some folks in Kentucky and other colder parts this winter, as well as those in Arizona, NM, etc., this coming summer.
BTW, don't get any funny ideas of using ethylene glycol straight up without diluting: when pure, it freezes at +8.6F /-12.9C and boils at +387F/+197.3C.
2006 325Ci
Old 02-02-2009, 09:40 AM
KrisL's Avatar
Ubergeek
Mein Auto: 330i ZHP
Even though 40% water will have more protection, 50% water will cool your engine better - distilled water has a lower specific heat.
Old 02-02-2009, 09:54 AM
Ok, so it is related to the amount of fluid the system holds, and how fast it can carry the heat away. So, in the high end (AZ, NM, NV, even TX), that is important. But for folks in the North, the difference between -36F and -70F may mean the difference between being able to ride out and a split engine block.
2006 325Ci
Old 02-02-2009, 09:55 AM
KrisL's Avatar
Ubergeek
Mein Auto: 330i ZHP
Yep.
Old 02-02-2009, 11:49 AM
dakarm dakarm is offline
Send a message via AIM to dakarm
Mein Auto: 00 M Coupe, 08 MCS JCW S1
my gfs 02 330i was doing that, I would check the level and it would be need about 1-3cups of coolant/distilled water (I alternated). After a month or so of this, it turns out the plastic end tank was split and weeping coolant. No coolant light ever since the tank was replaced.
member of CRS Club
'00 Dakar Duck CRS Edition
'10 335d
'12 X5d
'12 MINI Countryman S
Old 12-21-2013, 09:26 AM
cashmonay cashmonay is offline
Mein Auto: 2001 330i
Is there another type of coolant you could use instead of the BMW coolant as I do not have access to a dealership ATM???
Old 12-21-2013, 10:58 AM
ticklemejoviemo ticklemejoviemo is offline
Mein Auto: 2002 BMW Z3 Coupe 3.0
Re: What type of Coolant?
i googled this several months back, there is a pdf datasheet from bmw that lists other approved coolants. cant seem to find it as of now, but i remember glysantin g-48 was one and i believe prestone extended life.
Sent from my SAMSUNG-SGH-I747 using BimmerApp mobile app
Old 12-22-2013, 03:09 PM
GoForthFast GoForthFast is offline
Mein Auto: '04 330Ci 6-speed
+1
I've used Prestone for upwards of seven years and the inside of my engine looks close to new.
Old 12-22-2013, 06:00 PM
i inquired about Delo extended life, and according to their datasheet is approved by many vehicle manuf., including volkswagen, audi, andif im not mistaken mercedes. but bmw was not listed. at the end of the day though, im sure its more than adequate protection as most of those other engines are composed of the same exact material. however, i did end up using BMW coolant
