Old 07-24-2015, 01:59 PM
Dave 20T's Avatar
Dave 20T Dave 20T is offline
Moderator
Mein Auto: '13 320i, occ. use of X3
brake fluid change and jacking vehicle
Planning to change brake fluid myself. Can you access the drain without removing the wheels? If you have to remove the wheels is a jack (type that you pump up and has a metal rod to pump) strong enough to gravity drain (may take 30 minutes). I don't have jack stands, only a ramp and a jack and a scissors jack.
My guess is the rear wheels need removal and also the front unless you are a contortionist.
Old 07-24-2015, 04:46 PM
R ODonnell R ODonnell is offline
Retired
Mein Auto: 2009 E83 X3
You have to remove the wheels. I use a 2 ton hydraulic jack (under the jack pad) from Walmart and slide the removed wheel under the car for safety. I have a home made power bleeder that I made years ago that works fantastic. They're easy to make and the net is full of instructions. Gravity bleeding takes a very, very, long time.
FYI: My dealer only charges about $132.00 to flush brakes. At that price it's almost not worth it to bother at home.
Another quick note. Our cars take LV brake fluid. I use this: http://www.amazon.com/Pentosin-DOT-B.../dp/B0070Y9CE4
Old 07-24-2015, 06:01 PM
lahiru97 lahiru97 is offline
Mein Auto: 2007 BMW X3 3.0si
I did a full break service (new pads, rooters and fluid flush) with the spare tire jack when I first bought my car. THIS IS NOT the best option but after spending $800+ on parts and a few tools I was reluctant to buy a quality jack and stands at the time, which I have since bought.
The jack I bought from Home Depot for only $100 and it's great 3 ton Husky jack. Jack stands were $40 a pair from Autozone for the 4 ton set.
I also purchased a pressure flushing tool for $60 from ECS tuning which made the job a lot quicker.
