X3 E83 (2004 - 2010)
Talk about the E83 BMW X3 in this forum! |
Setting Up Garage Door Opener On 2007 X3
Anybody have experience setting up the garage door opener on their X3. I have a Lift-Master Security + opener and I think it has so much security that it doesn't work with the cars system.
I have followed the manuals instructions severall times with no luck. Any thoughts or ideas would be appreciated. I feel like a total idiot on this one.
John 2007 X3 3.0si - Wife's Car 2004 X3 2.5i - Daughter's Car 2003 K1200RS - Dad's Toy 2001 750 iL - Retired by me in 2005 - Great Car but wanted AWD 1995 750 iL - Retired by me in 2002 - Great Car |
I couldnt do it either
It's complicated with a rolling code opener.. Be very careful, or you can fry your opener. Ask me how I know.. I did it with no problem with our previous E46, but this one drove me nuts.. After I replaced the opener ($400 later), I got it done on about the 5th try... If your local dealer has a delivery specialist who goes over the car with you.. pay them $50 to come out and do it for you... It works with virtually all systems, so it's doubtful yours is a problem with the opener itself.. Good luck, kyfdx
2006 330Ci ZHP Imola Red 2011 X3 Bluewater 1987 325iS Bronzit (retired) 2011 Z4 Space Gray (retired) 2008 X3 Sapphire Black (retired) 2005 330Cic Silver-Gray (retired) 2003 325i Sport Steel Blue (retired) 1967 2000CS Delphin Gray (retired) |
One suggestion that worked for me and has helped others (but possibly with different systems)...
Press and hold the buttons on the mirror for a longer time than specified in the instructions. Each step eventually gave the correct confirmation, but often after a longer period that listed in the instructions.
Recent ED: 25 June 10, 328xiT in Red. Then headed SW to Italy & France. Flew home via Rome. Hoegh Kobe departed 22 July; unloaded at PH 17 Aug. Redelivery 11 Sept. (Re-redelivery 14 Sept....read the details here.) Previous ED: 7 June 08, X3 3.0si in rosso corsa (*), then off to Italy, Austria, Slovenia. (*Note: A61 Crimson Red north of the Alps.) Back-up vehicle (while waiting for re-deliveries): 1999 M Roadster in Estoril Blue. |
Here is what worked for me:
1: Turn ignition to position 2 2: Hold down buttons 1 & 3 on the X3 until they begin to flash. This clears any previous codes 3: Hold down button 1 on the X3, then continuously press/release the button on your hand held remote, till button #1 flashes. (Time the press/release repeat cycle at about 1 second) 4: Press the learn button on the opener, then within 30 seconds, press button #1 on the X3. 5: Done
2008 ML320 CDI 2008 X3 3.0si 2005 X5 (retired) 2002 X5 (retired) 1999 Z3 (retired) 1990 535i (retired) 1986 528e (retired) 1978 733i (retired) 1977 320i (retired) 1974 2002tii (in storage) 1972 Bavaria (retired) 1970 2002 (retired) |
Our rolling code garage door opener has a little button up on the motor/mechanism (that pulls the door up) under the cover for the lightbulbs. We needed to push that button (someone up on a ladder) and the one in the X3. It takes two people to do. I would download the instructions from your garage door opener off the web and see what they say. It is a pain...
Once mirror is programmed, press button on garage door opener motor then press your mirror button again. Garage lights should flash on/off. Then the X3's button should work!
Madurodave My garage: 2007 BMW Z4 3.0si Manual, 2007 BMW X3, 2006 BMW 530xi Retired: 1998 BMW Z3 Member of BMWCCA! |
Those are the correct instructions.. Doesn't mean it will work the first time, however..
Part of the problem... is that a lot of the steps don't give you any confirmation that they've been completed correctly.. So... if it doesn't work, you aren't sure where the problem lies... I'll reiterate.. You CAN fry the electronics in your garage door opener. One other small bitch..lol: On our 3-series, you just had to tap the button to get the door to open. On the X3, you have to hold it in for a full-second before the door moves, even though with the normal remote... it's just a tap. Before this turns into a rant.... We love our X3!
The only confirmations you get is that the codes are cleared on your X3's buttons, that the button is programmed, and the flashing of your garage lights. Those should let you know you're moving in the right direction. I love my X3 too!
One last thing...
The instructions say to hold the original opener 8 inches away from the BMW opener. That didn't work for me. When I held it about 1 inch away, then it worked.
My owners book said 1 - 2 inches away. For the 2007 model year.
Granted, my unit is (was) ten year's old.. I'm sure a brand-new garage door unit can withstand a lot more... Which on another note... I love the new belt drive unit!
All good ideas - but no luck yet. I'l keep trying.
2010 X3 with Wayne Dalton worked perfect
Thanks for the post. Vipz
2010 X3SI; Alpine White; Saddle Brown; Light Burl Walnnut; Premium; Navigation; HD Radio; Heated Front Seats; Servotronic; 1995 325i Convertable; Red, tan interior. |
I tried this recently, and no luck! I have a sears craftsman garage door opener. What am I doing wrong? On the last step #4 above, do I need to hold down the button on the X3. Thanks in advance.
-nels |
#4 After pressing the button on the opener hold the button on the X3 mirror until the light flashes on the opener.
Instructions do work. Make sure you clear existing codes in X3, then hold remote that works 2 inches from X3 buttons to program. Then link to opener - get confirmation of lights on opener blinking on/off.
Should be on the opener unit itself.
2011 328i SA SULEV Black Sapphire Metallic, Dakota Beige, ZPP, Nav Prod Date: July 1, 2010 ![]() Traded in with 90K Miles: 2007 X3 3.0si Black Sapphire Metallic, Grey Nevada, M Sport Package, Premium, Cold Weather, Navigation, and Xenon. Prod Date: March 2, 2007 |
Also have a liftmaster and the trick I had to use was to press the remote opener for 5 seconds, then release for 5 seconds and I kept repeating until it worked. I then had to have the girlfriend press the Homelink button, while I pressed the learn button on the back of the opener. This worked on both openers. I also had to experiment on the direction to hold the remote and the location. Backwards, up and to the left of the mirror about 2" 4" away.
Good luck, it was a source of get frustration :-O Steve |
I had the same issue. The way to resolve it is to make your cars reciever learn to clone what one of your existing working remotes is doing.
Thanks for all the help on this thread/forum! Got mine to work! Step 4 was my key as I found the "Learn" button on my Liftmaster on the ceiling opener unit....thx again :Roundel:
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
