Old 02-11-2009, 06:17 PM
Blue Monk Blue Monk is offline
Mein Auto: 2004 X3
I've got an oil leak...somewhere
I noticed a small puddle this morning and checked the oil level. It was at the min so I added a quart. This is what I found when I checked underneath:
Any idea what could be going on?
ID:	174595   Click image for larger version
ID:	174596   Click image for larger version
ID:	174597   Click image for larger version
ID:	174598   Click image for larger version
Old 02-11-2009, 09:21 PM
Mein Auto: 2004 X3 2.5i
In your first pic., it looks like the plastic shield underneath the radiator is broken up.
The metal shield beneath the oil pan looks O.K. though.
If there is no other evidence of a foreign object having damaged some lower oil-carrying component,
the Crankcase Ventilation Valve, a.k.a. Oil Separator or BMW's version of a PCV is a likely suspect.
Hopefully it's just a connecting hose, such as the one at the lower part of the dipstick.
Old 02-12-2009, 05:56 AM
X3-terrestrial's Avatar
X3-terrestrial X3-terrestrial is offline
Aficionado
Mein Auto: '05 X3, '02 M3, '91 E30
Another place to check is, looking from the top of the engine, pass. side, look for any traces of oil on the metal shields above the exhaust maniful. Valve cover gasket and/or the grommets are known to fail anywhere after 60k miles on M52 engines. Here's how my e46 looked:
At that point, the leak was so small that the oil wasn't dripping to the floor, it just burned on the shield.(And a horrid burning smell get in the cabin as well, that scared the heck out of me, smells like transmission burning! ) some time later I started seeing some drops on the ground.
Old 02-27-2009, 03:12 AM
Mein Auto: 2004 X3
I had that same valve cover gasket replaced last year. One indy mechanic told me it was the oil filter housing. Took it to the dealership and they're telling me it is the oil separator plus four other hoses. Grand total $750.41. Ouch. The separator makes more sense seeing how they actually showed me where the leaking is.
Old 02-27-2009, 10:20 AM
Sounds right. From other recent posts, $186 in parts + labor.
If a clogged oil separator isn't dealt with in a timely fashion, it can cause real problems and a labor bill in the $1,100 range.
Old 02-27-2009, 10:27 AM
Mein Auto: 2004 X3
Yep, parts are cheap, but the labor is 5 hours.
Old 03-02-2009, 07:47 AM
teamfalcon teamfalcon is offline
Mein Auto: 2003 325I
I have the exact same problem, maybe a little worse. Here is the picture I took yesterday.
From the passengers side, from top I lowered the camera and took this side picture. (No oil stains in my garage):
Old 03-02-2009, 09:59 AM
Evlengr's Avatar
Evlengr Evlengr is offline
Ukemi - that's how I roll
Mein Auto: 2013 Audi S4 2010 MT MCS
Sorry to be so cynical, but this tells me that unless I have a full garage at home, never to own a BMW out of warranty.
Glad they offer 4 years trouble free initially.
2013 S4 Loaded (and NO RFT's) Awesome is an understatement
2008 MT X3 RIP you were a faithful sidekick and will be missed.
2007 AT X3 RIPOS
2005 GC
2000 Jeep Cherokee
1997 Twin Turbo RX-7
1984 GTI Wolfsburg Edition Neuspeed and more
Old 03-02-2009, 12:18 PM
Aficionado
Kind of hard to tell if is the valve cover gasket from that picture. It looks like the side of the oil pan? Do you have more pics?
Old 03-03-2009, 09:42 AM
rs6655 rs6655 is offline
Mein Auto: 2009 X3 (MT)
Not cynical, just smart. The military recognizes it too which is why everywhere I was ever stationed had auto craft shops to work on your car in.
If one cannot work on their own car for whatever reason they had better keep getting new ones or set-aside a fund for repairs.
I've always worked on my own and have rebuilt or repaired everything from voltage regulators, generators/alternators starters to complete engines and manual transmissions. I've never paid for an oil change or brake job and only one clutch job (I was on the road when that one failed). The amount of money I've saved over the years in incalculable. It really pays to get a book and do everything you can yourself.
Old 03-03-2009, 09:44 AM
My advice is to get it up on ramps and start pulling covers and plates until you can see where it's coming from.
Old 03-03-2009, 09:50 AM
Bentley Manual
While I'm on the subject I emailed Bentley Publishing. They haven't got an X3 manual in the works but one is planned. What that means as far as how long before we see one I have no idea. In the meantime they suggested using BMW TIS.
Old 03-03-2009, 12:37 PM
Aficionado
Ha! and pay $250.00 for a 30-day subscription?
We should all pitch-in, get the access and print all the X3 related SIB's!!
I'm a DIYer myself too.
Old 03-03-2009, 01:40 PM
I'll probably just do a 24hr and print all the stuff I think I'll need before the book comes out.
Old 11-06-2013, 01:19 PM
neosimago neosimago is offline
nsmgo 2006 X3
Mein Auto: 2006 X3
Hello Brother,
My 2006 X3 has a similar issue of a leak, but I haven't seen the puddle yet.
It just looks like your fourth picture where it seems to be leaking from a seal somewhere.
Can you tell me how you've addressed this situation and update us on your challenges?
So far, I'm just keeping a watch on the oil level and filling it when it gets low.
Old 11-07-2013, 04:20 AM
jlex jlex is offline
Mein Auto: 2005 X3.0i
The problem with oil leaks is oil will creep given a little time which makes it hard to tell where it originated. Best thing to do is to wash all the oil off first using engine degreaser.
Old 11-07-2013, 09:45 AM
swampX3 swampX3 is offline
Mein Auto: bmw++many
change this stuff at 60-80k miles
for a few hundred $$$$ you can change the valve cover gaskets, CCV bag pipes and valve plus the oil tower single gasket and be done with loads of where's that oil leak/what's that blue smoke/what's that smell of oil burning from the passenger side of the engine head scratching ......reducing all the site tribal wisdom puts doing this in the 5 year or ~50-70 K mile range.....also .....while in there doing the oil tower and CCV stuff change $10 worth of vac hose at rear of the 54 engine inlet manifold plus the line to the vac accumulator and save some what's that lean code head aches plus change the intake boot....this stuff should be in the routine level 2 ish PM
best to slay these mini dragons all in one swoop
Old 11-07-2013, 01:21 PM
Well said. My 90,000 mile X3 was an oily mess before I replaced the valve cover gasket & the oil housing gasket. I've had the metal skid plate off a few times since then & it's so clean you could eat off it. Luckily, these aren't emergency repairs so you can pick nice days to work on it & take your time.
Old 10-03-2015, 01:54 PM
Firewire Firewire is offline
Mein Auto: X3 3.0
Oil leak from bolt out of transmission
Reviving an old thread, but I noticed a very small oil leak and when I ruled out everything on the topside of the engine, I traced the leak to a bolt that goes through the transmission. It is coming down the threads of this long bolt you can see through the transmission window.
What is this bolt and why is it leaking oil? The yellow fluid is degreaser I used to help locate leak. The 10mm bolt is tight, couldn't get it any tighter in fact. The leak is actually coming out of the area where the transmission meets the oil pan.
2004 X3 3.0
2011 328xi Coupe
2009 335xi Coupe SOLD
Old 10-03-2015, 03:11 PM
make and model/is it trans or engine oil
which engine do you have ....which model X3.....also ....is it engine oil or transmission oil ????.....they smell and feel different plus have different colors.....it could also be residual from an old leak or a rear main seal drip on many engines
also .....have you checked the engine oil level regularly and spotted any biggish losses ....how many drips are going on the floor or plastic stone guard under the X
also ....how is your transmission fluid level ????? ....have you checked it hot while running just like the step for level checking after a transmission oil and filter change......are there any drips under the transmission or being captured by the plastic stone guard any place ?????
Old 10-03-2015, 03:19 PM
engine parts for 04 x3
you can spot all your engine parts in this realoem.com link....just input the last seven of your vin ....the seal is item 5 in this....many folks live with a small drip
http://www.realoem.com/bmw/enUS/show...diagId=11_2167
Old 10-03-2015, 03:20 PM
whole engine
this is the generic 54 engine ....maybe exactly yours ....double check
http://www.realoem.com/bmw/enUS/part...W-X3_30i&mg=11
parts 6 and or 7 in this link maybe yalls bolts
http://www.realoem.com/bmw/enUS/show...diagId=11_2187
Old 10-03-2015, 03:25 PM
FEST links for parts/manuals
http://www.bimmerfest.com/forums/sho...32#post9245332
Old 10-03-2015, 03:33 PM
FEST leak links
post 22 in this link ....
http://www.bimmerfest.com/forums/sho...d.php?t=647367
Old 10-03-2015, 03:34 PM
image files of the 54 engine rear main leak etc
https://www.google.com/search?q=bmw+...=1680&bih=1281
