E46 (1999 - 2006)
Old 02-11-2009, 08:38 PM
SlimKlim's Avatar
SlimKlim SlimKlim is offline
Speed is Zen
Mein Auto: Bavarian Bombshell
Angel Eye Switch DIY
Hey guys, my little switch has drawn some attention and after 3 PM's I decided to post what I was PMing to make it easier.
I'd like to thank KrisL for giving me some basic schooling in electronics and helping me figure out how to do this, I hope everyone finds it helpful.
You will need:
-a soldering iron
-a dremel
-a small sheet of lexan plastic
-a Double Pole Single Throw (DPST) Switch
-extra wire, same gauge as the trigger wire
-female connectors for the spades on the switch
Step one:
Measure the height the switch will sit above the lexan, and the thickness of the lexan. Combine the numbers, and mark that amount to cut down the interior features of your ashtray.
Then cut the lexan, I recommend scoring it and breaking it with a straight edge to get it close, and using the dremel to sand it to fit properly. Work gradually, and be patient. I chose to pressure fit it as opposed to silicone, that way I can pop it out easily to get to the back of it.
You will have to cut a hole in the bottom of the ashtray and the back of the center console to make room for the connections. I used a drill attachment to mark my corners and a cutting wheel, could have been much neater though.
Step two:
You will have to extend both trigger wires, you can run them through the free grommet on the passenger side of the engine bay.
Run them extra long up to the switch, and then cut them back as needed, so you don't make unnecessary splices. Solder and use heat shrink on the ones you do make.
Now that you have them run connect your switch to the trigger wires using your female connectors. If you choose to use an LED tap it into the ECU wire on the output side of the switch. (If you do it on the wrong wire the LED will only be on when the footwell lights are, ask me how I know.) Ground the LED to the ground for the original LED that is supposed to light the ashtray, and tape off the old positive so it can't touch anything.
Done!
Old 02-11-2009, 09:56 PM
MalibuMafiaV's Avatar
TheMalibuMafia
Mein Auto: E60 M5 & JB4+ 335i
Yessssssssssss
"Be yourself for who you are, or be no one at all" - MalibuMafiaV
TheMalibuMafia.com
BMW 2006 M5 - REALLY LOUD
BMW 2007 335i. Single Turbo 6266.
Audi S4 2000 Stage 3 - Dat turbo spool - SOLD
BMW 2000 3-series - Supercharged Because race car SOLD
Maserati 2004 M128 GT - HREs/tint/straight piped SOLD
BMW 2006 M3 - stock - SOLD
Old 02-11-2009, 10:17 PM
Missmodena310's Avatar
* BLONDETOURAGE 2010*
Mein Auto: BMW
o goodness that looks hard slim......
Old 02-11-2009, 11:06 PM
TimE46's Avatar
TimE46 TimE46 is offline
Mein Auto: 2000 BMW 328CI
So I think that this is a cool mod but not to seem like a smart ass but whats the benefit of having this...like when would you want to run your headlights with no angle eyes JW
2000 328ci Titanium Silver, Tanin Red/Black Interior, Clear croners/tails/sidemarkers,
Navigation, Angle Eyes, HID Kit, Eyebrows, Hamann HM3 Wheels
Old 02-11-2009, 11:13 PM
TheMalibuMafia
I think its more for just running your angel eyes during the day. And if you wana listen to music or be in your car with the radio on stealthy you can turn the angel eyes off.
TheMalibuMafia.com
Old 02-11-2009, 11:16 PM
TimE46's Avatar
oo alright I got it.... yeah you wouldnt be too stealthy with those eyes starrin out at everyone hahaa
Old 02-12-2009, 04:42 AM
SlimKlim's Avatar
Speed is Zen
When I'm pulling up to meet someone and I care about the impression I make, my most recent example is working on a contract with an elementary school, I'll flick my switch before I get there and I go from teenager with a modded car to successful young man.
Its also very handy when working on the car or cleaning it out so they aren't constantly turning on and turning off every minute.
Old 02-12-2009, 05:27 AM
Capps330xi's Avatar
Capps330xi Capps330xi is offline
Mein Auto: 2001 BMW 330xi- Silver
Great job once again like I said in the PM. Thanks for all the help.
330xi
Old 02-12-2009, 07:23 AM
Solidjake's Avatar
Solidjake Solidjake is offline
Zero. Leaks.
Mein Auto: 02 330i 6MT
I added this to the Wiki.
Old 02-12-2009, 12:54 PM
TimE46's Avatar
OO okay I got it now. Yeah thats a good point that its probably not good to be turning them on and off...I might do this too when I install mine
Old 02-12-2009, 01:07 PM
ThreeTwoFive ThreeTwoFive is offline
Mein Auto: B25
Very nice DIY..Can you provide some info from running it from the glove box to the console place? I'm thinking about doing this to mine in the summer.
Old 02-12-2009, 02:47 PM
SmokedE46's Avatar
SmokedE46 SmokedE46 is offline
chillen
Mein Auto: 01 330CI 5spd.
.... but what if you USE your ashtray
Old 02-12-2009, 05:02 PM
SlimKlim's Avatar
Speed is Zen
Quit smoking. Its much easier sooner than later. Or fab it under the dash, probably not that hard.
Old 02-12-2009, 09:03 PM
easyIsle easyIsle is offline
Mein Auto: 02 330i
your local autozone caries pushbutton toggle on/off accessory light switches that have an adhesive backing. They are simple to remove and no drilling required.
Good option if your use your ashtray and dont want to drill holes
Old 02-12-2009, 09:07 PM
TheMalibuMafia
His named is "SMOKEDE46" hehe. Smoked I hope your smoking what I'm thinking of
The other day I was like WOW that trees really GREEN and then I drove my car and almost ran over a SKUNK:P
TheMalibuMafia.com
Old 02-12-2009, 09:08 PM
Mein Auto: BMW
hahahahah sly there babe
very slyyyy
Old 02-13-2009, 09:12 AM
SocalZHP's Avatar
SocalZHP SocalZHP is offline
Send a message via AIM to SocalZHP
Mein Auto: 330i ZHP
+1 My angel eye switch is under my dash by the trunk switch, along with a couple of other switches . I should have put them in my ashtray though.. I like that setup.
2004 330i ZHP
Alcantara . Xenons . Factory Alarm . Auxiliary Jack . Black Cube
Axxis Ultimate Pads . 6000K HID headlights/foglights . CCFL Angel Eyes
Headers . PlanetAudio Dual 12" Subs/1000W Amp . Dynamat
OEM Clear Corners . Eagle Eye LED Taillights . Black Kidney Grilles
Passport 9500i . Tinted 15% . Navigon 2100 GPS . Michelin PS2's
Old 02-13-2009, 10:12 AM
xecure xecure is offline
2002 325xi
Mein Auto: 2002 325xi
do you loose use of your cigarette lighter with this mod?
Old 02-13-2009, 10:45 AM
SocalZHP's Avatar
Mein Auto: 330i ZHP
As long as you keep it wired and not blocked with any mounts/brackets, no you won't lose function of your lighter.
2004 330i ZHP
Old 02-13-2009, 10:48 AM
Solidjake's Avatar
Zero. Leaks.
ANGEL EYES FTW
lol
Old 02-13-2009, 02:37 PM
SlimKlim's Avatar
Speed is Zen
Nope, check out the picture in my original post.
Old 05-07-2009, 08:50 PM
Mein Auto: B25
Hey Slim, When your bored, can you take some pictures of behind the switch, and what/which is the trigger wire. And this LED bulb stuff etc.
If you could explain a bit in detail for the challenged ones like me, that would be great.
I am planning on doing this next weekend when I install my Ipod integration kit.
Old 05-07-2009, 08:52 PM
Capps330xi's Avatar
Def do it a fun and awesome modification for the interior. My next thing is incorporate some LED's for each one of my switches so I know when one is on or off because I can get caught with strobes on.
330xi
Old 05-08-2009, 04:52 AM
SlimKlim's Avatar
Speed is Zen
Its a complete rats nest back there, because I never got around to neatening up the wires. They are all the trigger wire. You need a DPST (Double Pole Single Throw) rocker, which will have four prongs on the back of it. Your trigger wires simply run through the switch, so on one side of the switch you have your "incoming" trigger wires, and on the other your outgoing. It took me some trial and error to get it plugged up correctly. The LED just taps the power from one of the outgoing connections and borrows a ground from the ashtray LED.
Its not too hard.
Old 05-08-2009, 01:56 PM
Mein Auto: B25
Its not too hard.
ok thanks. that simplifies the wiring,
so which wires are the trigger wires?
sorry im dumb..haha
angel, eye, switch
