Old 02-14-2009, 12:17 AM
graphix1998 graphix1998 is offline
Mein Auto: 750Li
Programming key fob
I have an '06 750Li with Comfort Access. I ordered a replacement key from the dealer, and it works to start/stop the car and the buttons on the fob function properly. My car has comfort access. Can I program the key to recognize this function? The dealer wants $175. It should not be that difficult....?
Old 02-14-2009, 01:53 AM
harjothundal's Avatar
harjothundal harjothundal is offline
E65/E66 Helper Man.......
Send a message via AIM to harjothundal Send a message via MSN to harjothundal
Mein Auto: BMW 745 Li
ok.... first of all... is it really an 02? if it is, it cant be a 750, but a 745... so either you were given wrong infromation, or you are saying 750 to make it sound like a newer car... my apologies if you take offense to this last statement....
if i remember correctly, comfort access required a special key, compared to a car with non comfort access... are you sure you ordered the right type?
Old 02-14-2009, 04:26 PM
Mein Auto: 750Li
Mistake - sorry
I should not drink and type... my car is an 06 750Li....
Old 02-14-2009, 04:28 PM
Mein Auto: 750Li
key
Yes, I did order a comfort access key. The valet portion and the key has to match the VIN on the car and required proof of ownership and driver's license. The key will work all options, but according to the dealer, needs to be "programmed" to function with comfort access.
According to the dealer, only 2 comfort access keys can be programmed to the car, but you can have unlimited key fobs. Since this is a replacement, they have to "deactivate" the missing key and reprogram the new key.... so they said.
Last edited by graphix1998; 02-14-2009 at 04:34 PM. Reason: additional information
Old 02-14-2009, 06:26 PM
manithemoneyman manithemoneyman is offline
Mein Auto: n/a
I had a similar experience but I know they can clear ALL the keys from the car without any of the key fobs.
Usually they will ask you to bring both working keys to them, then they'll reset the car and program the new keys
Old 02-15-2009, 01:07 PM
Mein Auto: 750Li
dealer programming
Yes, the dealer wants both keys, will clear the system.... Keep the one (original) comfort access key and if I want the second key to function with comfort access, they want $175 to program. I was able to find instructions to program the new key to work with the car, but it does not work with comfort access.
I would like the comfort access to work and avoid paying the dealer.
Old 02-15-2009, 01:46 PM
Mein Auto: n/a
Unfortunately I dont think there's any other way to do that. Only the dealership has the necessary equipment that can be used to program the car.
You can try negotiating to get a lower rate, I'm sure if you work with your SA you can get it down to $100. Otherwise you can look for a BMW independent mechanic but I doubt any of them would have the coding equipment.
Old 02-15-2009, 01:54 PM
rashannon rashannon is offline
Mein Auto: 2006 325 xi
Talking programming key fob.
not sure where augora hills is located, but i just purchased a second fob key with remote access and my dealer here in PA said it will cost around $40 to program the second key for comfort access. They too said to bring in the key that is working and they need to re-program it. All for approx $40. I am going this coming weekend to have it all programmed. Wish I could do it myself too but haven't heard how to do that and must go to the dealer i'm told.
Old 02-15-2009, 02:01 PM
Mein Auto: n/a
oh... didnt even realize that graphix1998, I'm right here in Simi... Did you go to Rusnak?
Old 02-15-2009, 07:17 PM
Mein Auto: 750Li
Dealer
Yes, Rusnak wanted $140/hr @ 1.25 hours.... Calabasas said it would be around $100. I will make a few calls tomorrow.
Old 02-15-2009, 08:09 PM
Mein Auto: n/a
Call Brice Carson 805-267-8337 at Rusnak and tell him Mani (with the silver 750) referred you... he always hooks me up with that stuff.
If you have any other maintenance work that needs to be taken care of, it would make it even easier since they can usually schedule the programming in while the car is in for service.
Old 03-05-2009, 09:08 AM
bembo19 bembo19 is offline
Mein Auto: E65 745
my indipendent specialist can program keys here in blighty ! the dealer wanted 150 for a new fully programmed key !!
Old 01-04-2010, 10:47 PM
dvddvd1 dvddvd1 is offline
Mein Auto: 2006 750i
Exclamation 2006 750i Used Remote Programming
2006 750i Used Remote Programming: Is it at all possible now in 2010 to reprogram a used 7 series remote purchased from ebay if it matches all the numbers, including the BMW number on the original working remote? Not just to open the doors, but also to start the car. I understand there are unique chip sets in the key remotes that must match the factory unique programmed slots in the car, and I was hoping matching the BMW number on the working remote would do the trick. I was also told that some new equipment has come out recently where locksmiths can program the BMW remotes, but I can't find one in the St Louis area. Any help to avoid the $250-$300 dealer costs would be appreciated. Thanks.
Old 08-10-2012, 11:59 AM
raysoto raysoto is offline
Mein Auto: BMW 750LI
HI MY NAME RAYSOTO I purchased a used key fob need some one from florida /broward county to asisted in progaming key fob
Old 08-30-2013, 07:35 PM
Jorge554 Jorge554 is offline
Mein Auto: 2003 BMW 745LI
programing
what are the programming instructions?
Old 08-30-2013, 07:43 PM
2003 745li wont start! No idrive,no radio
Hi guys, im having issues with my key it locks and unlocks my doors but it wont turn on the car i think i need to program it since i took out my battery to charge it been having issues ever since.
anyone have the instructions for programming the key thank you
2003 745li BMW.
Old 08-30-2013, 07:49 PM
PAPER's Avatar
PAPER PAPER is online now
CRISP & CLEAN
Mein Auto: Ford Pinto
2003 745li BMW.
if it locks & unlocks your car , then it is already programmed .
you might have another problem , or your battery might be
bad .What exactly does it do when you try to start it ???
Old 08-30-2013, 08:17 PM
key wont start car
Bought car at auction , drove car home (2 hour drive), removed battery to charge instructed by mechanic at auction, installed battery back in, key wont start car,only today key started locking and unlocking doors( or i didnt notice it did this before). internal lights come on i.e:
overhead lights, dash lights, emergency light buttons work,lock button on dash works, but no power to idrive or ignition. key fob get pushed out . 2003 745li BMW.
(just tested car again key stopped locking and unlocking doors)
Old 08-30-2013, 08:49 PM
PAPER's Avatar
CRISP & CLEAN
bad
Old 08-30-2013, 09:02 PM
key wont start car
bad
How can i check the battery to see if its bad?
Old 08-30-2013, 09:05 PM
PAPER's Avatar
CRISP & CLEAN
take it to sears or autozone .
Old 08-30-2013, 09:06 PM
PAPER's Avatar
CRISP & CLEAN
have you tried giving the car a jump ???
Old 08-30-2013, 09:07 PM
key wont start car
good idea thank you.
any other ideas will be greatly appreciated
Old 08-30-2013, 09:32 PM
SuperSnoop's Avatar
SuperSnoop SuperSnoop is offline
Mein Auto: 2007 760Li
Programming key fob
We've been through this already. Spamming the board with 9 posts all asking the same thing isn't going to get you a different answer.
Everyone talking about "programming instructions" are talking about the remote portion - locking and unlocking, not starting. The only way to program a key to start the car is to remove and solder on a blank transponder chip and find someone with a programmer who can code the blank transponder to your car. Since you've already opened the key and screwed something up, I doubt that's an option for you. There's no telling what you did to break that key.
You need to take your title to the dealer and drop $300 on a new key.
Old 08-30-2013, 09:39 PM
2003 745li WONT START!,PUSHES KEY OUT!
Thanks for your help sir, are you a technician?
