Old 02-18-2009, 08:20 AM
davidk davidk is offline
Mein Auto: 2008 X3, 2009 128i
No Mirror Tilt in Reverse
Our first issue after a year of ownership. The right side mirror had been tilting as advertised when we shifted into reverse, then began tilting only sporatically when vehicle was shifted into reverse, now it has quit tilting altogether. It does not matter which mirror the selector switch is set for, but I do know how it is supposed to function. I will be making a trip to the dealer for this, but was curious if there is a reset procedure for the tilt function. It also does not matter which key is used. This is a 2008 with sport, premium, and AT.
Old 02-18-2009, 08:40 AM
UncleJ UncleJ is offline
Mein Auto: '09 Cayenne "S"
I just noticed mine was not tilting in reverse either. I found it kind of annoying actually so I kept the selector switch on the right side to keep it from tilting. I don't miss it and so will probably not mention it the next time I take it in and see if they catch it and fix the problem.
Old 02-18-2009, 08:52 AM
madurodave's Avatar
madurodave madurodave is offline
BMW Enthusiast!
Mein Auto: 2007 Z4+X3, 2006 530Xi
I had the same issue. It was a problem with the mirror motor. It should be covered by warranty.
Madurodave
My garage: 2013 BMW 550xi GT, 2007 BMW Z4 3.0si Manual, 2006 BMW 530xi
Retired: 2007 BMW X3, 1998 BMW Z3
Member of BMWCCA!
Old 02-18-2009, 03:47 PM
redRocketZ4 redRocketZ4 is offline
Mein Auto: 2003 Z4, 2007 X3
Mine tilts in reverse, then TRIES to return to normal when I shift into 1st, but often doesn't make it all the way back. I press the seat memory button, and it finishes. Sounds like I better get that motor changed too.
Old 02-18-2009, 04:28 PM
Mystic1's Avatar
Mystic1 Mystic1 is offline
Mein Auto: '11 328xi, '09 550i
Just have the dealer look at it as it is most likely the switch or motor.
That is one feature I dislike in our X3. I always turn it off when I backup as it drives me crazy looking at the ground. More interested in looking down the side of the car to see where I am going to make sure I don't hit anything behind me. But I do not have to parallel park where it would actually come in handy.
Old 02-18-2009, 11:22 PM
HT417's Avatar
HT417 HT417 is offline
Mein Auto: 2008 BMW X5 3.0si
+3 for the motor being bad and this function's limited usefullness. I would never pay extra money for it.
Old 02-19-2009, 06:44 PM
... I always turn it off when I backup as it drives me crazy...
Mystic, how do you turn it off? I would too if I knew how...
Old 02-19-2009, 09:16 PM
Mystic1's Avatar
Move the mirror selector switch to the center or left position. In the right position it activates the downward tilt when in reverse.
Old 02-20-2009, 11:23 AM
Old 02-27-2009, 05:40 AM
BJC BJC is offline
Mein Auto: 2004 X3 3.0i sport
Awesome, thanks. I have a 'new to me' 2004 X3 and was wondering why the mirror's operation was spordic in reverse... now I know!
Old 03-08-2009, 07:46 PM
don conklin don conklin is offline
Mein Auto: 2004 x3 & 1999 323
Both driver and passerger mirrors quit working this past week on my 2004 X3. I suspect its the switch in the door handle rather than the motor since it quit working for both sides at the same time. I checked the fuse and it looks OK. The manual lists two fuses covering the mirrors but only one of the two slots had a fuse and it was not blown.
I need to know if its possible for an owner with a medium level of skill to take the switch out of the door handle themselves without leaving permanent tracks.
Don in Portland
Old 03-08-2009, 08:24 PM
Mein Auto: 2004 X3 2.5i
First it might be worth spraying a bit of electronic switch/contact cleaner around the sides of the rocker, or anywhere it might get drawn down into the switch.
Otherwise you will just have to carefully use a small putty knife to lever the switch out.
Old 03-11-2009, 05:38 PM
bobbyjoe bobbyjoe is offline
Mein Auto: 2008 X3 3.0si
Could someone please clarify - are both mirrors suppose to tilt down with the feature on? Ever since I got my car (2008 3.0si) only the right side ever tilted down. I thought that was a BMW "feature" i.e. the left mirror to judge distance etc, the right mirror to check the lines on the floor.
Old 03-11-2009, 05:54 PM
Sonoman707 Sonoman707 is offline
Right / passenger side only.
Old 03-11-2009, 06:48 PM
No, only the passenger side mirror.
BMW calls it the "Automatic Curb/Kerb Monitor", so the main intent is to avoid scraping a rear rim when parallel parking, and the bad language from the driver's seat that ensues.
As mentioned, it can be unhelpful when backing up in a straight line.
My 2004 Owner's manual indicates this is Optional equipment, but also says the angle of tilt can be adjusted by the dealer during ignition key programming. That is, separate adjustment from the one tied to power seat adjustment.
Also, the default in key programming is to have the Automatic Curb Monitor set to OFF (at least it was in 2004). Not sure if that is what makes it Optional equipment or not.
Are we confused yet?
Speaking of which, contrary to what Mystic1 wrote earlier, the mirror selector switch on the drive's door armrest must be set to Driver rather than Passenger for the tilt of the Pasenger mirror to be invoked.
Sounds backward? (Maybe it got changed in later years?)
And there is not really a center position of the switch.
Wouldn't the best practice be to keep the selector switch permanently on Passenger, and move it to Driver when you need the curb monitor to kick in?
I have avoided using L and R in order for this to make sense for RHD as well as LHD vehicles.
Possibly I didn't need to do that, but I have a hard time visualizing a steering wheel on the right, and ascertaining if the mirror selector switch works just the same as ours.
Finally, would it really be a separate motor for the automatic curb monitor?
Surely there is just one motor that controls all basic angle adjustments of the mirror?
Anyhow, I either don't have the option at all, or it is not programmed to be ON, and I am quite happy without it.
Old 03-11-2009, 09:28 PM
Mystic1's Avatar
You are correct. I was going by memory as I only drive the vehicle once or twice a month as it is my wife's car. All I know is I have to hit the selector switch to the oposite side to turn it off. I realized my error a day or 2 after that post, and was just waiting for someone to correct it. Took longer than I thought it would. lol.
Old 05-11-2009, 06:33 PM
07X3platinum's Avatar
07X3platinum 07X3platinum is offline
Mein Auto: 2012 E550 Sedan
I had the same problem on my 2007 X3, but I found instructions on how to "reset" the mirror thanks to "ub6ib9" who posted instructions on this board a couple of years ago. After I reset the mirror I haven't had any problems with it and it works fine tilting down whenever I go in reverse. Below is a copy of the instructions provided by "ub6ib9":
"the guys fixed it for me and the way they did it, if im not mistaken, goes like this... with your key in the ignition but not turned on (car not turned on), move the mirror switch to the right to take control of the right mirror... then move it all the way to the bottom left till u see the mirror click...then move straight up till it clicks then straight across to the right till it clicks then straight down till it clicks...... do this as a clockwise motion..... after the final click just move it to the middle to adjust the mirror to how you want it... turn the switch back to the left and then back to the way its suppsoe to be for the tilt feature to work........shut car off and turn car on put in reverse and it should work........ that is the way to reset the mirror.... oh by the way if going bottom left first doesn't work, try going to the top right first and repeat the same process in a clockwise motion"
Old 05-13-2009, 09:55 AM
silverkripto silverkripto is offline
Mein Auto: 2005 X3
I just took my 2005 x3 yesterday to the dealership i had the same problem there getting it fixed kinda annoying when something thats supposed to work doesnt haha
Old 07-17-2011, 03:44 PM
MajorTron328i MajorTron328i is offline
Mein Auto: '07 328i
Thought I was loosing my mind
WOW, thanks. This has been driving me crazy for the past few days. You just saved me a trip and an embarrassment.
Old 01-22-2014, 10:21 AM
LesAshmore LesAshmore is offline
Mein Auto: BMW X5 40D M Sport
One thing that annoys me about this feature is how far down it lowers, It is too far and should be adjustable, Unless it is and I don't know how to
Old 01-22-2014, 10:54 AM
luigi524td luigi524td is offline
Mein Auto: '13 535xDrive; '98 Z3 2.8
tilting rear side mirror
That can be changed in coding (check that in the forum). It's been a feature of all of my BMWs going back to my e28 (1986 524td). If you slide the position switch even while backing up it will change from tilt down to normal and visa versa. For my purposes I have it set to tilt down. Admittedly, when not parallel parking it prevents a view down the side of the car but then I have rear and top view cameras so I know what's going on.
My opinions are free - you'll get exactly what you pay for!
Current: 2013 535xDrive | 2013 X1 MSport | 1998 Z3 2.8
Past: 2007 530xi | 2001 740i | 1998 740i | 1994 740i | 1986 524TD
"Seek and ye shall find" ... start with your owner's manual!
Click on the MrRebates logo/link below for cash back savings at on-line stores like Tirerack!
Mr. Rebates
Old 11-04-2016, 11:46 AM
hitchrropes hitchrropes is offline
Mein Auto: 2006 X3 -1995 Lexus SC400
This solved it for me
Many many years after you posted this it was sooooo useful to me. No repairs necessary - just a reset operation. Amazing. Couldn't believe it worked. So relieved thankyou so much for taking the time to re-post this solution. Awesome.
Old 11-04-2016, 12:10 PM
44 Cents 44 Cents is offline
Mein Auto: X-3
Im going to reset mine too. Its nice to have these old threads! My mirrors actually seem "loose" or something compared to my other cars. I read somewhere that there is a "folding" option that can be initiated from the driver seat but IDK. I have noticed no pattern...some days the mirror points down in R and others it doesnt....some days it looks so far out of wack and I have no clue why its where it is. I actually wish the mirrors were a bit bigger as I would rather have an "over kill" amount of visibility even at the expense of "style". I find that when Im driving a bit more aggressively, I am not always 100% comfortable with my visibility from the drivers seat....maybe its the mirrors and the pillars behind the door, Im not sure. I just wish I felt more confident. Maybe as I drive the car more often my confidence will improve as I get used to how to "swivel my head" and see everything I want to.
Old 11-04-2016, 01:29 PM
TomNJ TomNJ is offline
Mein Auto: 2005 BMW X3 3.0i
The power folding mirrors is an option on some models. I believe you'll have a button next to the mirror selector switch if you do. Does the whole mirror assembly seem loose or just the actual glass mirror part? If just the mirror it might be the actuator that has issues or maybe somehow the mirror glass got loose from the actuator. It just clips in to the actuator.
I have a code about one of the potentiometers in the mirror having a fault. The potentiometers determine the position of the mirrors. I'm glad you bumped this thread because my mirror dips but doesn't come back up. I'll try the reset procedure. Another suggestion I saw was to try and clean the contacts.
I find the mirrors to be a good size personally. Sometimes I drive a 3 series and the mirrors are much smaller and I can't seem to adjust them the same way I do in my X3.
I agree that there's something weird with the visibility when turning to the side. It took some time to get used to it. Also I found the following video helpful in adjusting the mirrors to get the minimal amount of blindspot. It took some time to get used to that too but once I did I think it's great.
Old 11-04-2016, 03:51 PM
Mein Auto: X-3
That is a fantastic video. I used to be a driver trainer years ago for a government contract. I WISH that they would require all newly licensed driver to watch a video like this and then adjust their mirrors in front of the driving instructor to prove comprehension. Simple but vital and so easy to do. Can you imagine how many accidents would be avoided every single day if all drivers simply had their mirrors correct? Too many people don't take driving seriously and are not engaged to the task...all these " safety". Features like auto breaking and lane assist contribute to a less aware driver. Drivers need trained on how to fully and correctly use this technology. Whoa, sorry, way off topic! Thank you for the mirror info. I'm going to go and get this all done now. I think it's the whole housing that's loose ...I'm not sure.
