E46 (1999 - 2006)
Old 02-23-2009, 11:11 PM
jcourcoul jcourcoul is offline
Supporter of Bimmer Lore
Mein Auto: 2006 325Ci
DIY: Cleaning under the 3rd/Center brake lamp
Have you noticed that the glass under the 3rd or center brake lamp gets progressively dirtier, misted up and maybe even with insects inside? Here's a quick DIY on how to take the LED lamp assembly off a 2006 325Ci for cleaning. Other 3 Series models will have a similar setup. There are two parts to remove: the front cover and the lamp assembly, see figure 1.
  1. Front cover is held in place by two nylon push pins and two clips. As shown in figure 2, slip you index fingers under the center of the cover, spread them out to the corners where the pins are and then carefully pull the pins out. Lift the cover down just enough for the pins to clear their holes, then slide the cover away from the lamp assembly so the clips clear the assembly. See figure 3 for placement of the pins and the clips. If you pull the cover down too much, the clips will break.
  2. Spread the two latches holding the lamp assembly to the rear glass, like figure 4. The assembly will drop in your hands, just held by the cable, which you can separate at the connector if desired. The glass can then be cleaned, just be careful with the metal brackets that hold the assembly in place: see figure 5.
  3. Reconnect lamp if necessary. Open the latches, center on metal brackets and close. Replace cover by centering pins in their holes, tapping them in, then pushing the corners for the clips to engage the lamp assembly. Done.
Thanks for all the positive feedback. Hope this DYI proves useful to all.
Name:	1 The parts.jpg
ID:	175901   Click image for larger version
Name:	2 Remove cover.jpg
ID:	175902   Click image for larger version
Name:	3 Cover fasteners.jpg
ID:	175903   Click image for larger version
Name:	4 Remove assembly.jpg
ID:	175904   Click image for larger version
Name:	5 Clean the Glass.jpg
2006 325Ci
Old 02-23-2009, 11:47 PM
e46_platform e46_platform is offline
Mein Auto: 2002 330Ci 5M sport
nice write-up!
Old 02-24-2009, 07:20 AM
Gryphon's Avatar
Gryphon Gryphon is online now
I brew life
Mein Auto: 2005 ZHP, Wife's Prius
Hmmm....this would fix my lighting bug that I have, but I think I'll let 'em stay until the meet.
Arthur John
Born 02-24-11
Has already been awarded the title "Destroyer of Sleep"
Old 02-24-2009, 08:07 AM
Just like the corpse I have in the headlamp. Can't imagine how the damn bugs manage to crawl in there....
BTW, I found a dead mosquito in my center brakelamp, so I really had two corpses in the car.
2006 325Ci
Old 02-24-2009, 08:57 AM
bmw-hoya bmw-hoya is offline
Mein Auto: 2008 Montego Blue 335i
Great DIY!
Old 02-24-2009, 09:05 AM
Solidjake's Avatar
Solidjake Solidjake is online now
The one and only
Mein Auto: 2002 330i
Excellent write up. Do you want me to add it to the Wiki?
_______________Going to Bimmerfest East AND West
Youtube - Electric Fan Swap/Aux Fan Removal - Projector Retrofit - E46 Bulb Guide
Old 02-24-2009, 09:47 AM
By all means, that was the intent in the first place, if it passes the standards of the Wiki. Giving back what little one can.
2006 325Ci
Old 02-24-2009, 10:25 AM
iskoos's Avatar
iskoos iskoos is offline
Coupe OR Never
Mein Auto: '02 - 325ci
It is great that somebody thought about this. No bugs yet but there are lots of unnecessary dirt in mine as well.
Great DIY and thanks for sharing it but would you mind adding some more pictures(not upclose ones) to make it easily understandable? A lot of black objects and black background in the pictures making it a bit confusing to orient myself. I kind of lost my orientation. If no more pictures available, maybe you can add some arrows.
Definitely not trying to be picky. Just trying make this DIY better.
dfoster99 dfoster99 is offline
Love My 330CI
Mein Auto: 2002 BMW 330CI
Great post. I have some kind of a pod in mine. I am not sure if it's going to hatch some mutant species or what, but I will sleep better at night when I follow your advice and get rid of it
Anyone else have unusual items lodged in their third brake light? So far we have a mosquito, a lightning bug, and some sort of alien pod.
Old 02-24-2009, 10:37 AM
Heh heh, sorry about that. Got hit by a moment of 'midnite inspiration', hence the dark shots. I'll get a couple of extra (daytime) shots in there.
2006 325Ci
Old 02-24-2009, 10:40 AM
Solidjake's Avatar
The one and only
Done
Old 02-24-2009, 12:23 PM
jcatral14's Avatar
jcatral14 jcatral14 is offline
Running around in circles
Mein Auto: E46 ZHP
Thanks for posting. I had my tints removed and a little bit of the soap solution ran in the assembly. I was trying to pry it open but couldn't figure out how and was afraid I would break something. Now I know. Thanks
2005 Imola Red 330i 6MT, ZHP, ZCW, Xenons
Previous Bimmers ( All sorely missed ):
2007 Mystic Blue 530i - ED 12-15-06
2003 Grey Green 330i
2003 Electric Red 325iTa
Angular velocity is where it's at
-Jay
Old 02-24-2009, 08:59 PM
Gryphon's Avatar
I brew life
Originally Posted by jcatral14 View Post
I had my tints removed and ....
Just about inspection time?
As an aside, I'm getting ever closer to medical support for me getting tint.
Arthur John
Born 02-24-11
Old 02-24-2009, 09:49 PM
Mo.licious's Avatar
Mo.licious Mo.licious is offline
Who is John Galt?
Send a message via AIM to Mo.licious
Mein Auto: 2001 325Ci Convertible
Very well done indeed! It was clear, concise and effective. Dido on the pics, but you've got that taken care of. Thanks for contributing. (although I have a vert)
From the outside looking in, you can’t understand it. From the inside looking out, you can’t explain it.
Old 02-24-2009, 09:57 PM
tturedraider's Avatar
Freedom isn't free!!
Thanks for posting this. People need to see it and it's very easy. Everyone should do this before taking their car to get the windows tinted!!
"People sleep peaceably in their beds at night only because rough men stand ready to do violence on their behalf." -- Geo. Orwell
Keep Right, Except to Pass
Then & Than usage - "It was hotter than ever (comparison). Then (time) it got cool."
2006 330i Sonora w/ ActiveAutoWerke flash tune - I like it!
2004 330i ZHP Imola/NB - missed
2000 328i TiAg - gone but not forgotten
BMW CCA member #388003 - www.bmwcca.org Use me as a referral, you could win a one day ///M Driving School!
Old 02-26-2009, 07:39 AM
FYI, I've adjusted the pics so the orientation is explicit now. Hope that takes care of any issues. Sorry about the night shots, but am too lazy to repeat + shooting a black interior in bright sunlight is an exercise in frustration.
2006 325Ci
Old 02-26-2009, 09:45 AM
jcatral14's Avatar
Mein Auto: E46 ZHP
Haha, no, I had to get the car inspected for the first time in Jersey. Car was from Delaware.
All my cars never had tint so no problem for me. I would like to get a really light tint but hate the aggravation with tickets and cops. Tell me more about this "medical support"
-Jay
Old 09-17-2010, 06:09 AM
Whoad_way_down Whoad_way_down is offline
Mein Auto: 2009 335I Coupe
Thanks for the help. I don't have much of a bug infestation but I do want to complete a task on my NTM car. I am installing a third brake light flasher. I have been rear ended and it isn't much fun. So, protect me and protect my ride.
http://www.3rdbrakeflasher.com/index...roducts_id=181
Old 09-17-2010, 06:48 AM
marlin1881 marlin1881 is offline
Mein Auto: 2003 330i ZHP
With your ZHP, you should have tint already, correct? What does NJ have to say about that? OK? Not?
Old 09-17-2010, 07:49 AM
SJBimmer SJBimmer is online now
Living Life At The Beach
Mein Auto: 2004 325 Convertible
It is now a moot point. We just dropped all inspection here in New Jersey except for emissions. Makes me sleep better at night knowing we will have even more dipsticks with unsafe cars on the road. Love the Gov. and his budget cuts!
Old 09-17-2010, 09:20 AM
Gryphon's Avatar
I brew life
Ha, this post was for the Xi. I have some scarring on my one eye that makes me a bit light sensitive, NJ is not interested, they said wear sunglasses.
Yeah feel free to read through my couple of blurbs about dealing with DMV these days, first they wanted to fail me for low washer fluid and then they pass me without even having a front plate. Gotta love it.
Arthur John
Born 02-24-11
