Old 02-26-2009, 08:31 PM
dimariko dimariko is offline
Mein Auto: 525 i
Strange water leak on back seat floor
Hi,
water has appeared a few times on the back pass side floor. Not a window or roof leak. Someone has mentioned it could be a heater coil? Any suggestions? I've got a 2001 525i.
Mariko
Old 02-26-2009, 08:46 PM
dkotanto dkotanto is offline
Mein Auto: 2003 BMW 530i sport
Common E39 issue. Lot's of threads on the subject...Search is your friend. Here's one:
http://www.bimmerfest.com/forums/sho...d.php?t=164891
2003 530i Sport - Current
2007 530 xi (wife's car)
2004 X3 3.0i (daughter's car)
2011 E90 M3 ESS VT1-550 (Sold)
2006 530i Sport (Sold)
2004 330i Sport (Sold)
Old 02-27-2009, 09:51 AM
540 M-Sport's Avatar
Mein Auto: 01' 540 M-Sport, Scuderia
Vapor barrier seal leak. Been there, done that. Go to the dealer and buy a roll of the the 3M rubber sealer tape/rubber gummy stuff.
Now, here is the easiest way to fix this. First, spray the door, window and seals and get everything wet with your garden hose. Open and check the door jam, there should be some water in there, that is good, now you can trace the source. Remove the door panel, and rather than remove and completely reseal the vapor barrier, simply look around and find the places where it is leaking, you may need a drop light or flashlight to see clearly. Then, when you find a leak, tear a long peice of the tape (at least two or three inches longer than the area affected, and work it into the seam/seal and squish it down under the foam vapor barrier real good. Use your thumbs to press hard and smooth it out. Do this everywhere you see water or wetness. While you are at it, wet and inspect your other doors, you will probably find them leaking, though not enough to cause water on your floor, but if there is water at the bottom of the door jam, that is bad! Fix it. The dealer would completely remove the vapor barrier and reseal, and they were not 100% sucessful, but I did my "patching" method and had better sucess.
Good luck.
Old 02-27-2009, 11:25 AM
x13alle12x x13alle12x is offline
Mein Auto: 2003 525
Good luck.
Darn..! I ripped the whole barrier off and having a tuff time glueing this thing back on. I called the dealer and they said the glue comes as part of the new part. My barrier is s till good. I tried black silicon and it just aint sticking for me.
Old 02-27-2009, 12:57 PM
A great thread here. Pictures and instructions in page 4.
http://www.m5board.com/vbulletin/e39...d-water-4.html
Old 02-27-2009, 02:50 PM
Get the proper sticky rope 3M stuff from the dealer, and when you press it down, press hard and get every spot nailed down or it WILL leak. The rope can be bought seperately. Dealer is misinformed.
Old 04-08-2010, 08:04 AM
andrewm andrewm is offline
Mein Auto: 530D Sport
Mariko
I have the same problem, did you get yours fixed?
Old 04-09-2010, 03:33 PM
paulbad paulbad is offline
Mein Auto: 2002 530i
Just sealed mine 2 days ago, took me about 1.5 hours per door. The most difficult part was cleaning the old sealent, I've noticed that the easyest way is to use sealent to ....remove sealent.
Roll some of it into a ball and tap it along the old one.
Old 04-09-2010, 03:36 PM
You do not need to buy the 3M from the dealer, I found it at Kragen for $14 enough for both doors.
Old 10-05-2010, 06:15 AM
Kacique2002 Kacique2002 is offline
Mein Auto: E36 M3, E39 530i
I am having the same preoblem your guys are having, and the issue i am trying to solve is that i have water accumulated under the carpet on the rear floors. I removed the rear floor mats and there seems to be a lot of water accumulated under the carpet. I press on the floor and wate comes out of the hole in the carpet. How do you remove the water? I really dont want to drill the bottom of the car!!!! I guess I could remove the carpet but that seems like a lot of pain. I noticed underneath the car there are two plugs right under where the water is accumulated. I wonder if I can pull this plug and the water will come out. Anyone had this problem?
thanks
Old 10-05-2010, 08:39 AM
GSA1's Avatar
GSA1 GSA1 is offline
Mein Auto: '01 & '02 E39 530i Sports
I have not heard about draining through these plugs. One thing is clear; you need to reseal the vapor barrier in the rear doors. i used towels and pressed them into the floor; left the windows open for a couple days too. also a wet vac works wells on puddles.
Old 10-05-2010, 08:43 AM
speedchase speedchase is offline
Mein Auto: 2001 540i MT M62
I had the same problem a few months ago. It is easy to get underneath the carpet. You have to remove rear seat and remove the bolt on each side to take out the panels holding the carpet.
I put some large object underneath the carpet and let a fan blow air directly underneath to completely dry out the carpet (especially the noise insulation foam that soaks up a lot of water). I got a suggestion from one of the forum member to put baking soda underneath the carpet after it is dry to remove any odor or avoid mildew.
One of members posted this http://www.bimmerfest.com/forums/sho...7&postcount=10
2001 540i MT - Still a newbie until I change my VCG, VANOS & Coolant system...
Repairs so far - Steering fluid pump ($1k - Indy), CCV replacement ($1k hosed to another Indy) & Axle replacement ($850 to another indy).. 3 indys to date and now I am diving all in as a DIY'er
Old 10-05-2010, 09:51 AM
mlnelson mlnelson is offline
Nelliramma
Mein Auto: 02 540I Sport
I had the same issues in my car. I tried the black goo, but it was black goo and it has a horrid brith defects warning on it. My wife, who was pregnant at the time, drives teh car most of the time. I had to find an alternative. I went and bought a tube of GE pure silicone calking. Superrior in every to the black goo because it remains soft after it drys. Did both Vapor barriers and i havent had a problem since. I live in Seattle/Tacom area where it rains all the damn time. Not a drop has leaked in the car. I would advise GE Silicone instead of BMW or Autozone Black Goo. Its cheaper too.
Old 10-05-2010, 11:23 AM
bmw_n00b13's Avatar
bmw_n00b13 bmw_n00b13 is offline
Freude am Fahren
Mein Auto: 99 528iA
Has anyone ever tried LePage's Acousti-Seal vapor barrier product? It's supposed to never skin over. Pretty messy to work with lol.
'99 528i ('98/12 build). 282,000km BY29428/Royalrot
Breaking My Wallet since 2009
Mods: Stoptech SS brake hose, 280piece toolkit resting on trunk floor, Beisan VANOS seals, increasing amounts of duct tape and glue
'99 540i (grandfather's)
Old 10-05-2010, 03:05 PM
bluebee's Avatar
bluebee bluebee is offline
Seek to understand,^Value
- rear vapor barrier seals that allow rain water to fill the rear footwell (1) (2) (3) (4) (5) (6)
Old 10-05-2010, 03:11 PM
wolfen wolfen is offline
Mein Auto: 97 BMW 540i
Easy fix. Go to autozone and buy BLACK window silicone. But the whole tube for the caulking gun. Remove interior door panels and seal up the gray/black weather shield. You will see where the adhesive let go. Very easy fix
Old 12-09-2012, 06:35 AM
JMeyers20 JMeyers20 is offline
Wet floors?
Here's how one guy fixed the problem:
