X5 E70 (2007 - current)
Talk about the latest generation X5, codenamed E70, with other BMW owners here. |
#176
For those who had refilled the DEF on their own using non-bmw bottles, did you need any additional tools to refill it like say a funnel? Also how much stuff do you have to remove to get access to the Passive Tank?
#177
a funnel works great...........air intake needs to be removed to access fill point for passive tank...............easy peasy
#178
I spoke to a service rep today and he explained a couple things. The DEF is 66% ionized water and 33% urea, so it the passive tank/supply lines can freeze, causing the warning. Also, both tanks are filled at factory and you "should" get 10K miles before a refill. The front tank can be filled by a DIY, the passive tank port is located in rear and requires more time by using a hand operated transfer pump that you can get at a hardware store. Lastly, he said once the vehicle is driven the sensors drop to 66% and continue to fall from there per the mileage...a way for BMW to be extra conservative on the level so the customer does not run out. So, there's actually more DEF than indicated. He had no issues to report and the diesel has been trouble free so far. Anyone else have the same info??? We have one on order...hope this works out.
#180
So when you motor up Green Lantern with your 35d.......you'll be amazed at the torque getting you up the hill..........and everyone at the Chart House will be impressed that you drive a truley green car with style.......not a Prius like everyone else in the parking lot................ I was in the North End the other evening.....even the valet on Hanover street was impressed with the Diesel.........
#181
The passive tank on a X5 is located under the left front seat. The passive tank filler fitting is in the engine compartment partially obscured by the corrugated plastic air tube, which can be easily removed without tools. So you can easily fill it (DIY) since it has the same filler fitting as the small tank. Funf Dresig Last edited by Funf Dreisig; 04-09-2010 at 01:59 PM. |
#182
So you have played in my backyard...I am LMAF right now! I make it to yours as often as possible whenever I fly into Logan and stop in Regina's, Mike's Pastry's, the Daily Catch (on Hanover), the Barking Crab, and few other places I can't recall the names...just can't get that authentic stuff here. Don't forget those cigars next time you go...Cheers Scot! |
#184
grew up in Tustin.....USC alum......... Barking Crab.....our favorite out of town guest spot in the summer......forget Mike's ............go across the street to Modern Pastry........Daily Catch is good...........
#185
The passive fill port is identical. But it is on the other side of the engine tucked under the air intake tube. Funf Dreisig Last edited by Funf Dreisig; 04-09-2010 at 06:12 PM. |
#186
No but a problem exists with diesels passing emissions .... Anyone know anything regarding this snafu?
#188
I also got the message when accelerating hard around a corner at 1100 miles. Well, I now have 3000 miles and haven't seen another warning. I did buy a few gallons of DEF just in case, but I think it was an anomaly.
2010 X5 35d, Black Sapphire / Sand Beige Nevada / Premium / Cold Weather / Tech / Rear Climate / Premium Sound / Sport Activity / Roof Rails / Running boards / iPhone Snap-in Adaptor / HUD / Comfort Access / iPod and USB / Space-Saver Spare |
#189
Yes, I've had the problem 3 times and the dealer had to work with BMW to fix the problem. It had to be towed today with engine malfunction...power reduced issues. Have you experienced this problem?
#190
I've actually had zero issues (knock on wood) with the car and I'm coming up on 4k miles. Also, I've now left the car sitting in the garage for two week and it started instantly when I returned...
#191
New GT - I don't think you should be getting recurring Low DEF warnings, especially not at 4000 miles. I went over 11,000 miles before getting the warning after a top off at oil change. I don't imagine you are still freezing the tank this time of year. Just some thoughts.
2009 X5 35D Black Sapphire Tobacco Nevada |
#192
The longer I wait for the 2011 X5 35d and the more I read here and Xoutpost I can't help but question what is it that I'm doing. Exhaust urea, battery, comfort access, window, Nav, and a host of others all for the low low price of $70,000.00. This is my first BMW and while I like adventures I like them fun and exciting. The folks that run BMW act as if they doing me a favor and that doesn't sit well with me at all. I guess I will find out what all the fuss is about owning a bimmer, if I don't walk while waiting.
#193
Yes, BMW are an arrogant bunch of Assh@#es that build great cars..... Maybe that gives them the right ????........But we all want to drive one don't we ! Your waiting must be almost over, and soon you will truely be one of the BMW Club members. PS. i don't like calling it a Bimmer, it sounds like something you plug into your computer
2010 X5 30d M Sport pack on 20 inch In Space Grey, Panoramic roof, auto tailgate, Privacy Glass, Comfort seats in Black? Rear view camera |
#194
In the garage: '09 X5 Sport (Mineral Green) / '12 328iT (Deep Sea Blue) Previous: '06 M3C (Jet Black) '06 530xiT (Titanium Gray) '03 325xiT (Topaz) '02 330i sport (Jet Black) '01 330i (Jet Black) '01 Z3 (Topaz) |
#196
Best of seven huh, well.. |
#197
My 2009 X5 35d was the worst BMW I've owned. It will be my last. I was in the shop over ten times in one year, 6000 miles. I waited 3 months for an air temp. sensor to fix a check engine light. I drove around 3 months in a new car waiting on a part. I waited another 5 weeks for a heated fuel filter. Boht times, I had to call BMWNA and complain. I also own a Lexus LS 460 and now own a 2010 Lexus GX 4
Premium. If I knew then what I know now, I wouldn't have purchased the X5 diesel. My local dealer also tried to charge me 200.00 for the diesel exhaust fluid flush and fill that should be done once a year, or every 11,000 miles. That was the last straw. BTW, this was my 4th BMW and my last... I also forgot to mention, my battery wouldn't stay charged. The dealer and BMW say I didn't drive it enough. I had to keep a battery charger on it every night. Good luck with your decision, Craig Last edited by Craig B; 05-12-2010 at 02:34 PM. |
#198
The woes of being an early adopter. I passed on the diesel, even though it was just coming out as I ordered my gas burner. I wanted them to work the kinks out first.
#200
Craig |
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
