E46 (1999 - 2006)
Old 03-04-2009, 10:27 AM
txsbabe txsbabe is offline
Mein Auto: 2000 mbw323i
Where do I put Power Steering Fluid
Can anyone please tell me where to put power steering fluid in my 2000 323i? It was making noise this morning when i made turns and not turning as easily as it should. I ran in and picked up some steering fluid, looked in my owner's manual - which told me to contact BMW Dealer - - no diagram of where the reservoir is - nothing. I had several nice gentlemen come by and try to help me locate it - but after carefully going over everything I had already checked - no one knew where it went. Can someone please help?
Old 03-04-2009, 10:41 AM
spazmataz's Avatar
spazmataz spazmataz is offline
Mein Auto: 2002 318i m-sport 5 spd!
FIRSTLY, DONT PUT POWER STEERING FLUID!! Its the canister that says ATF on it!! and put ATF. It'll cost you more than just the fluid if you put the wrong stuff in there.
Old 03-04-2009, 10:43 AM
KrisL's Avatar
KrisL KrisL is offline
Ubergeek
Send a message via AIM to KrisL Send a message via Yahoo to KrisL
Mein Auto: 330i ZHP
It's the reservoir with the star shaped cap right in front of the engine that says ATF only...and like it says, use ATF, not power steering fluid.
I recommend looking at my power steering fluid "flush" DIY which can be found in the E46 Wiki:
http://www.bimmerfest.com/wiki/index.php?title=BMW_E46
Old 03-04-2009, 10:44 AM
tturedraider's Avatar
Freedom isn't free!!
As you look at the engine the reservoir is located to the right, just left of the airbox. It has a top that can be screwed off by hand.
www.bmwcca.org
Old 03-04-2009, 11:00 AM
Not Power Steering Fluid? Automatic Transmission Fluid (ATF??) instead?
Old 03-04-2009, 11:11 AM
Bucknekkid's Avatar
Bucknekkid Bucknekkid is offline
Fully Dysfunctional
Mein Auto: 02 325i
Yes, Automatic transmission Fluid not Power Steering Fluid...
Today is more like it is now, than it has ever been before...
That costs too mucking fuch ! !...
Sig courtesy of SolidJake...
Old 03-04-2009, 11:12 AM
AlboBMW's Avatar
AlboBMW AlboBMW is offline
#422323
Mein Auto: '01 325i
Yes. Get it at autozone. The BMW dealer will sell you the same ATF that autozone has. I forgot the name of the ATF, but it should meet Dexron III standards.
I think the name is Castrol Dex/Merc.
Old 03-04-2009, 11:27 AM
delirium330's Avatar
delirium330 delirium330 is offline
John Voight's BMW
Mein Auto: 05' 330i ZHP 6MT
not to change the subject, but i doubt adding more PS fluid is going to solve the problem. follow krisL's guide and replace your PS entirely. if the problem arises, check to see if there are air bubbles in the fluid reservoir, if so, air is getting into the system somwhere and will make the steering whine.
My Merit Badges:
CVV, VCG, OFHG, Full Cooling System, Tensioners, Plugs, All Fluids, Fuel Filter, Angel Eyes, Kidneys, Badges, Front/Rear Clears, Battery, Brakes, CDV, V1 Install, TB Housing, ICV.
Old 03-04-2009, 12:27 PM
smolck's Avatar
smolck smolck is offline
ROLL TIDE!
Mein Auto: 2002 330i ZSP
I use Mobil 1 synthetic ATF.
That is KrisL's car........
Old 03-04-2009, 12:36 PM
Thanks so much for all your help!! I will go by auto zone this afternoon!
power steering, ps
