Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 6 Series
6 Series
The BMW 6 Series builds on BMW's sporty heritage with aggressive lines and an incredible motor to back the design up. Available in coupe and convertible trims with a standard 4.8 liter engine producing 360 horsepower and 360 lb-ft of torque, the 6-series is a popular choice that exceeds expectations.
Old 05-18-2013, 10:52 AM
3Pedals_6Speeds 3Pedals_6Speeds is offline
Mein Auto: fun cars
Can I just put an add-a-fuse in one of the these?
I'm looking to add a direct wire setup for my new radar detector, and it seems I have about 3 or 4 empty fuse locations in the trunk. Could I just use these? Anyone know if these are live?
Drive fast, take chances.
Old 05-18-2013, 01:23 PM
tampamark tampamark is online now
Mein Auto: 2006 650 convertible!!!
Yes, you can. I used the standard add-a-fuse with no issue. I checked every fuse in the front glovebox and in the rear trunk, only one turned off immediately when you shut off the car. But I have a 650, it looks like your trunk fuses are different so you have a 645? Your fuse layout is different.
Regardless, if you find a fuse that works for you, then you have to run the wire up to the front. There is a spot on the side of the seat that passes through to the cabin, a wire loom already routes through there.
