Old 03-16-2009, 03:59 PM
jaugustavo jaugustavo is offline
Mein Auto: 2000 740iL
E38 Steering wheel shake
When driving on highway at speeds in excess of 40mph I get a pretty violent shake or jolt when going over minor bumps...like a bushing is done. It's not the shimmy between 45 - 55mph, I already had that and replaced my traction struts. Any insight to what could be causing this..? I know for a fact that my steering wheel shouldnt shake like this over bumps at medium speeds because I was driving my buddy's 528i and his steering wheel didnt jolt or shake at all when I went over the same highway bumps...Any help would be great as I would like to know what to look for before I crawl under the car.
James
o/______\o
(Oo=00=oO)
2000 BMW 740iL - Silver
Old 03-17-2009, 10:07 AM
oembimmerparts oembimmerparts is offline
Mein Auto: 2001 Z3
James
James, Check the tie rod ends as well as the tie rod main assembly.
Old 03-17-2009, 11:10 PM
will do, as soon as i get some decent, warmer weather here in seattle.
o/______\o
(Oo=00=oO)
Old 03-18-2009, 03:11 PM
Bimmerjay Bimmerjay is offline
Mein Auto: 98 740IL
Did you check the tire balancers? Had the same problem when going 50MPH, if your running stock rims they are thps little metal peices on the tire thiers one on each tire.
Old 03-21-2009, 11:39 AM
havent checked tire balance but i am probably due for a tire rotation, should do that and bring it in for a balance.
o/______\o
(Oo=00=oO)
Old 01-21-2011, 08:28 PM
stocks740il stocks740il is offline
Mein Auto: 1994 bmw 740il
bmw wheel shaking
try and check your control arm bushings i had about the same problem and it fixed mine.
Old 01-23-2011, 01:20 PM
CodyItaliano's Avatar
CodyItaliano CodyItaliano is offline
Mein Auto: 2001 740i
mine had this problem. it was tire ballance, still does it from time to time when the tires are cold. i noticed that the tire shop does not take the time to properly ballance the wheels to perfection and this will be the case with such wide wheels. when i used to ballance tires, taking your time was all the difference. placement of weights are key. only getting them sort of in the right place causes this from what i've found. they need to be perfectly placed.
*Der E38*
manufactured: 7/01
color: anthrecite metallic
wheels: style 89 E66, 19X9F 19X10R
ext. lighting: 8000k D2S & LED plate light
*want to get sport rear diff*
Old 01-24-2011, 10:19 AM
balance balance is offline
Mein Auto: 97 740iL
I would lift up the front end and shake each tire up/down and left/right to see if there was any play in the suspension pieces. If there was, I would tell someone else to shake the wheels and I would go under the car to see which pieces had play.
Right now, I'm thinking that it may be the strut mounts in your car that are bad, but I'm not sure. You won't be able to detect a bad strut mount by shaking the front tires.
HTML code is Off
