The X5 SAV Forum
Old 03-17-2009, 10:15 AM
X5 Delight X5 Delight is offline
Mein Auto: X5
Fuel and Oil additives
Anyone using Lucas Oil or fuel additives. I've used fairly regularly and found better millage as well as smoother runs. 85K on the car now. I want to run to 185K
Old 03-19-2009, 10:59 AM
uberpanzer44 uberpanzer44 is offline
Mein Auto: X5
I recommend BG 44k for gas tank. Costs about 19-24$ locally. One can makes a difference. Check out web testimonials. Other car makers use it before expensive fuel system procedures
Old 03-20-2009, 07:20 PM
dcharnet's Avatar
dcharnet dcharnet is offline
Mein Auto: BMW '15 X5 35d
Additives
I recommend a high quality fuel with additives aleady in the fuel. Not all fuels have this. Google "top tier gasoline" and review the entries there. If you want to use cheaper fuel, then you will need and benefit from fuel additives. As to oil additives, there are many additives on the market and I am not aware of one that is recommended by qualified independent petroleum engineers. Most if not all of these are simply not worth it. Use a top-quality synthetic like Mobil 1, and change it every 7500 miles or so. X5's and all BMW's may also benefit from higher viscosities than BMW recommends. One factor in BMW's recommendation is meeting CAFE standards, and a lighter weight oil helps achieve that, but possibly at some cost to valve train wear, especially in more severe conditions.
Old 03-25-2009, 04:42 PM
Mein Auto: X5
make sure oil has BMW-LL specs. Careful also with viscosities
