Old 03-20-2009, 11:05 AM
pgammon1789 pgammon1789 is offline
Mein Auto: 2004 745Li
Post Check (or add to) level of transmission fluid
How do I check the fluid level in my transmission?? I hate not having a transmission dip stick. I've removed the cover panel under the transmission, and see the drain plug, but can't seem to find how to check the level. Is this like a manual transmission with a plug on the side?? thanks for your help..Pete
Old 03-20-2009, 12:25 PM
dfauerbach's Avatar
dfauerbach dfauerbach is offline
Mein Auto: 2004 745i
there is a fill plug on the side you take that out and fill it till fluid starts to drip out that plug
2004 745i
2001 X5
2006 FXSTBi Night Train FOR SALE $15,850.00 over 30k Invested 4k miles
2001 Modified Triumph Daytona 955i SOLD
2005 SRT10 Ram
Old 03-20-2009, 09:07 PM
dmacd dmacd is offline
Mein Auto: 2004 745i, 2007 MINI
According to my SA, there is no need to check the transmission fluid as it is a sealed unit. If you ever get a leak, the computer will alert you, otherwise, there is no need to add fluid or do a regular transmission service. The fluid is apparently designed to last for the life of the transmission.
Old 03-20-2009, 09:22 PM
johndade johndade is offline
Mein Auto: 2002 bmw 745li
I do believe that changed from lifetime to 100k .Might want to check with your dealer. Not sure if computer will tell you bout a leak, as stated by bmw tech cause of the fluid expanding from different temperatures.
Old 03-22-2009, 05:13 PM
cjennjr cjennjr is offline
Mein Auto: 2002 BMW 745i
100k miles is the limit on transmission fluid, although I plan on changing mine around 80k miles.
Black Beauty
Old 08-20-2010, 11:27 AM
atif85 atif85 is offline
Mein Auto: bmw745i
what type of fluid bmw 745i 2003 transmission ??? please...
Old 08-20-2010, 11:38 AM
USALEXUSBMW750's Avatar
USALEXUSBMW750 USALEXUSBMW750 is offline
Little Odessa
Mein Auto: bmw
Yes but if you do that dont forgot to start your engine, then take out top plug and fill with engine run
Old 08-20-2010, 12:02 PM
bghubr's Avatar
bghubr bghubr is offline
BMW Driver
Mein Auto: 2011 activehybrid 7
You can use the Castrol Multi Import transmission fluid.
This meets the fluid specifications for the transmission.
2011 Activehybrid 7
2011 535i xDrive
Old 08-20-2010, 03:39 PM
Maverick62 Maverick62 is offline
Mein Auto: 2013 750lix m-sport
Level car and get engine warm. remove side plug in tranny and fill till fluid runs out. put plug back in fast watch out it's hot near exhaust pipe. Don,t listen about fluid lasting forever. change it at 50-75k yourself. I posted how 2 do it . search change tranny fluid.
MAVERICK62
2013 750lix dgm2 M-sport
2011 550ix dgm awesome (in pic)
2006 750li bk saph retired
1998 740il ox grn retired
Old 10-01-2010, 04:25 AM
LIONEL LIONEL is offline
Mein Auto: 745 LI
I was told that my 2002 745 li has a dip stick does it? If so how do you check the engine oil at also?
Old 10-01-2010, 01:14 PM
Keif Keif is offline
Master Tinkerer
Mein Auto: 2007 Alpina B7
No dipstick on the transmission, just a fill plug. Dipstick is for the engine oil.
Black 2007 Alpina B7
Tension strut bushings
White 2007 Alpina B7
Supercharger clutch/bearings, replaced exhaust valve/pulled head, sunroof seal, 6000K angel eyes
Black 2002 BMW 745Li (sold)
KW v3's, blue angel eyes, 8000K headlights & HID fogs, rebuilt alternator & mounting bracket gasket, sunroof seal, CCVs, plugs, sway bar bushings, timing & valve cover gaskets, valve stem seals, guibo joint, mechatronic sealing sleeve, trans fluid, sanded headlights...
Old 09-28-2013, 05:32 PM
troylair troylair is offline
Mein Auto: 2000 bmw x5 4.4
you should never use any tranny oil other than ZF fransmission fluid. it is specifically designed for the tranny in the bmw and if you use anything other than this fluid, it will eventually destroy your tranny. just read on here with the number of folks with tranny problems. when asked, everyone of them will tell you they had the tranny oil changed and they used everything under the sun excpect for zf tranny oils. stupid mistake so many people dont realize is that oils have different consistencies and volume.
Old 10-03-2013, 02:42 PM
rippjd rippjd is offline
Mein Auto: '05 745i / '10 X5 35d
See www.thectsc.com and click on Technical Info at the very top of the page.
2005 745i Individual
E65/E66 Parts for Sale:
Alpina Type 743 Front Spoiler complete retrofit kit (new in box) $1200
check transmission level
