Old 07-18-2003, 03:00 PM
dakarm dakarm is offline
Send a message via AIM to dakarm
Mein Auto: 00 M Coupe, 08 MCS JCW S1
Ron Stygar is there a master list of item that you improved upon :)
for the M Coupe that is
I would like to buy the clutch pedal or the clutch pedal bushing, whichever one gets rid of the squeek.
thank you
member of CRS Club
'00 Dakar Duck CRS Edition
'10 335d
'12 X5d
'12 MINI Countryman S
Old 07-18-2003, 03:14 PM
JonM's Avatar
JonM JonM is offline
Moderator
Mein Auto: 01 Mc, 08 M3, Motorrad x2
thank you
If you want to order stuff from Ron, your best bet might be to call him. His phone number is under his name in every post. I think that's his preference. He gets hit with a ****pot of emails.
And you want the clutch pedal. Might as well do the brake pedal and get a clutch stop while you are at it. If you're doing all that, you might as well order a new shifter carrier with delrin bushings.
Old 07-18-2003, 03:39 PM
It's like you read my mind Jon
I was going to get the new pedals and the bushings
Clutch stop I've decided not to use.
This past weekend while autoxing at 100+ weather. the Dakar Duck refused to go into all gear, including reverse.
I always had some problem when the weather was hot but never had this problem. I remove the home made clutchstop and removed one of the nut to make the travel longer but still would prevent the car from going into gear. So i remove it completely and it was find after that.
member of CRS Club
'10 335d
'12 X5d
Old 07-18-2003, 06:27 PM
PDX M Coupe PDX M Coupe is offline
Navy Vet. and ///M fan
Mein Auto: 03 jet blk SMG ///M3
dakarm~
I had the same problem with my clutch stop when the weather heated up. I removed it completely and the problem stopped. I then went to the local home improvement store and bought a shorter elevator bolt, and now the new clutch stop works perfectly! And this is driving like a mad man in 100 degree weather as well! Don't give up on the wonders of a clutch stop, just buy a shorter elevator bolt
Bryon
2003 Jet black/imola SMG M3
Old 07-18-2003, 08:06 PM
Ron Stygar's Avatar
19,585 Miles
Originally Posted by PDX M Coupe
dakarm~
Bleeding the clutch moves the disengage/engage point up.
On the '01 and later M coupes with the double spring, putting the shorter spring up top does too. The parts data agrees with this, but the cars I've checked come with it on the bottom as shown in the pic. Not sure why it does this yet, but my car has the small spring up top now.
Old 07-18-2003, 08:56 PM
Ron Stygar's Avatar
19,585 Miles
I can email you a so so list of things currently available.
Working on a bunch of things that I really don't what to talk about yet.
Trying to get the car ready for HC too, but a couple of major things I thought would be on the car, may not make it.
As usual, very busy, having fun figuring things out.
Lately, every new project generates two or three new projects. I guess that is good, but I would like to clean up things so that I can focus on the Z4 and start over again.
