What is road force balance? - Bimmerfest - BMW Forums
Old 03-27-2009, 09:39 AM
330blast 330blast is offline
Mein Auto: 2002 325i 5-speed
Hi there,
I have read a number of threads mentioning "road force balance". Is this a special type of balancing machine comparing to those used by normal tire shops?
I notice a very minor vibration, and my tires are hitting the tread life mark. So I put on a set of new tires (at America's tire, who has been balancing my car for several years with the same type of tires). Had the car aligned at a BMW dealer. The vibration is still there.
I am wondering if I need to take it to some other shop that can do "road force balance".
Thanks.
_______________________________________________
2002 325i, 5-speed, Silver/Black, ZPP, ZSP, Xenon
2003 530iA, Bluewater Metallic/Grey, PP, SP, Xenon - sold
2001 330iA, Titanium Silver/Grey - sold
Old 03-27-2009, 09:53 AM
armysweitzer armysweitzer is offline
Mein Auto: RB20 S13/ 1997 540i/6
simulates driving conditions vs just standard balance i believe.
very recommended, i think you can Google what shops have the machines in your area.
Old 03-27-2009, 10:03 AM
mmm635's Avatar
mmm635 mmm635 is offline
Mein Auto: '02 525i Sp/5, 95 FJ80 LC
Originally Posted by 330blast View Post
Hi there,
Thanks.
Read here
Old 03-27-2009, 10:49 AM
SoCaLE39 SoCaLE39 is offline
Mein Auto: E60 M5, E46 325i
I used to use this a Hunter Road Force machine for 3 years and let me tell you, that machine will pickup a lot more than your traditional balancer. In fact it will also tell you to rotate the tire on the wheel if its off balance too much. For a BMW ALWAYS DO ROAD FORCE! The road force balancer is definitely more accurate.
Old 03-27-2009, 11:30 AM
Fulltone74's Avatar
Fulltone74 Fulltone74 is offline
Mein Auto: 98 BMW 540i-6speed
IIRC --
The road force machine also detects side to side wobbling in addition to vertical vibrations.
So the tech can know whether the weights should be on the inside, middle, or outside edge of the wheel.
Doing this also eliminates the directional pull of the tire, in addition to eliminating vibration.
The road force machine puts a roller on the tire with 750 pounds of force.
Which is somewhat close to the weight that will actually be on the tire.
Road force is so much more accurate....
1998 BMW 540i 6-speed (SOLD)
Jet black on tan
Dinan springs, Dinan Koni dampers, Dinan front strut tower bar, M5 rear sway bar,
Dinan Stage-1 software, Dinan clutch, Dinan short throw shifter, CDV delete, Bosch Design III injectors,
Dice I-pod kit,
Hawk ceramic brake pads....
2001 BMW M5
Silverstone on Caramel
All stock.
Old 03-27-2009, 01:18 PM
chivas's Avatar
chivas chivas is offline
You Lick It, You Own It
Send a message via ICQ to chivas Send a message via AIM to chivas
Mein Auto: 98 540i/6
there's a local shop by me that no longer uses roadforce but laser. let me tell ya.. this thing is spot on.
americandan.com
It takes a lot of work to be lazy.
Old 03-13-2014, 03:28 PM
MJB9 MJB9 is offline
Mein Auto: 2002 525i (E39)
I too have heard about this "road force" but ignored as I just assumed it was slang for a balance. I just had my car balance and they did a crappy job. Didn't inflate tires to spec I asked for (infact, they deflated and gave to me 26PSI all around), then they didn't rotate correcty, and put the two best tires on the passenger side. All are good, but two were better. Then they stacked weights like crazy. I should know better than NTB pumping them out at $20 a car
I just called around and there's a TON around me. I called the first place and booked an appt. for Sunday. Getting all four done for $40. Might be a good price, might not, but I'd like to at least know I didn't skimp.
Old 03-13-2014, 08:06 PM
dckr dckr is offline
Mein Auto: 99 540i Sport Dinan
yeah, i would avoid NTB at all costs.
