The X5 SAV Forum
Old 04-04-2009, 12:56 PM
SunilPandit SunilPandit is offline
Mein Auto: 2002 X5
Rear turn signal not working
Hello BMW experts
I need some help on fixing my 2002 X5 . The rear right turn signal on passenger side is not working. And the turn signal indicator is flashing rapidly . Initially I thought it could be a bulb burn our problem . So I replaced the bulb but that did not fixed the problem. Same Bulb work on the other side turn signal . I also swapped the bulb socket but that did not helped either .
Is there a separate fuse for each turn signal ? If so where can I find ?
What else could be wrong ?
Sincerely appreciate any help.
Sunil
Old 04-06-2009, 08:11 AM
Scott ZHP's Avatar
Scott ZHP Scott ZHP is offline
We want the Lion!
Mein Auto: 03 ZHP, 01 X5, 73 MGB
Do a search or read the wiki. This is a common problem on the E53 (X5) and the E46. The metal contact on the cluster is burnt and needs to be cleaned with steel wool and "tinned" with a soldering iron. You can bend the tabs/ears on the bulb carrier, but it is only a temporary fix.
JUST...LOOK...UNDER...THE...CAR....for Chrissakes....it`s like checking to see if a dog is male or female....
Originally Posted by smolck View Post
A bimmer with forced induction should have a proper manual gearbox. Anything less is like french kissing your sister.
