Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 6 Series > 6 Series DIY
6 Series DIY
6 Series Do It Yourself (DIY) forum.
Old 04-04-2009, 03:45 PM
J.Ro J.Ro is offline
Mein Auto: 645Ci
645 Oil Change DIY
Can anyone specify the proper oil change procedures for an 04 645ci
1) Oil Amount, Type/Brand oils people use
2) Oil filters people use
3) How to reset the oil life indicator
4) Any Special tips or thing to do
I always change my own oil, just like to make sure it is done correctly. This is my first 6 Series and just wondered if anything special needs to happen or any secrets.
Old 04-05-2009, 09:51 AM
GregE GregE is offline
Mein Auto: 2008 650i coupe
I don't think anyone on this forum changes their own oil as that question never gets answered. I've also always done my own oil changes but it looks like I'll have to use the dealer or some other place for the 650.
2008 650i coupe space gray/chateau pearl, auto, CWP sport Logic 7 comfort HUD AS
Old 04-05-2009, 04:41 PM
coutts18 coutts18 is offline
Mein Auto: BMW 650i c
Yes....I would tend to agree......I think most of us would call our BMW dealer for an appointment.
Old 04-05-2009, 07:46 PM
welles welles is offline
Mein Auto: 2008 328i Coupe
I've changed the oil in my 645 once at this point - there's no magic to it, but it's a little different than non-BMWs in a couple of respects. With regard to your specific questions:
1) It holds 8.5 quarts - make sure you have a drain pan that holds at least that amount (most don't). I used the OEM oil ($8 per quart from BavAuto), but I believe any 5W-30 synthetic would do.
2) Like most BMWs, the 6 uses an internal oil filter (no case), and I don't think any of the usual aftermarket sources (Fram etc.) offer replacements. Again, I stuck with OEM from BavAuto - I forget the price, but next to the cost of the oil, it's trivial. It also includes fresh gaskets for the drain bolt and filter cover.
3) My understanding (and this may be flawed) is that the cars electronics monitor the oil life directly, so for oil changes, no reset is required. My plan is to change the oil every 7500 miles, so I didn't bother with a reset.
4) There's a trap door in the plastic belly pan under the car. Open it and you have access to the drain plug and the oil filter cover. The OEM service manual indicates an 8mm hex wrench for the drain plug, but I found a Torx bit (T45 or T50, I forget which) was a better fit. You'll need a large socket (24mm I think) to undo the oil filter cover. Apart from that, the usual advice applies - make sure you've got a good set of ramps, some rags, etc.
There is a good post (with pictures) on one of the 5 series forums regarding oil changes that applies pretty much step-for-step to the 6, but what I've said above should cover most of what you need.
2008 328i Coupe
Previous BMWs:
2005 645Ci coupe
2000 328Ci
1997 328is
Old 04-05-2009, 10:45 PM
Mein Auto: 645Ci
Thanks Welles!!!!
I would go to the dealer but I am a hands on guy and like to give my rides a little TLC myself. Take Care.
Old 02-08-2010, 01:00 AM
ohhhmannn999 ohhhmannn999 is offline
Mein Auto: CA
Hi All,
Is there anyway I can fill up the oil? I mean that if the oil level too low. Could I fill it up a little bit, or i have to bring it to the dealer?
Anyone know how? please help.
Thanks you
Old 02-08-2010, 02:15 AM
Koenvw Koenvw is offline
Mein Auto: 630i convertible
Hello,
I try to explane how to reset the Idrive, bud English is not my language so its a little dificult...
Put contact on
Push A button on the dashboard (A= left button on the I think you call it odd meter? where you set back the day millage?)
Hold this A button for at least 5 sec.
Then you see the menu on the milage meter.. With all the service stuff...
If you have found the service oil menu, press again 5 sec the A button... and its reset.
I make pictures later...
Greetings,
Koen Vw
BMW 630i convertible 2006 | Stratus Gray
Opel Speedster #2981 | Lotus Titanium Silver
Susuki swift sport (for the wife)
Audi convertible 2.6 V6
Old 02-08-2010, 02:45 AM
Hello,
I opend a new tread for you and other 6 drivers how to reset it easely.
On my 630i I needed 6.5 liters oil. I did not use the 5W40 oil, I only use 10W40 oil because it makes less dirt in the engine. Bud I change it every 10.000 km, and not 25.000km like on the manual.
Oil filter I buy after market for $13.
The amount of oil is in your drivers manual!!
Greetings,
Koen Vw
Old 02-08-2010, 07:01 AM
pablo645's Avatar
pablo645 pablo645 is offline
Mein Auto: 650i Convertible
Originally Posted by Koenvw View Post
Hello,
Thanks for the advise Koenvw
2012 650-xDrive Convertible. Titanium Silver Metallic - M Package - Driver assist package- Cold weather package - luxury seating package - Bang & Oulfsen system.
Previous Cars:
2008 650 Convertible 6 speed manual
2004 645 Convertible 6 speed manual
1994 540 6 speed manual
Old 10-29-2011, 04:57 PM
Superhart1977's Avatar
Superhart1977 Superhart1977 is offline
Send a message via AIM to Superhart1977
Mein Auto: 2011 328 XDrive
I did my oil change today, not bad and very easy to do. I used a purilator filter and 10w-30 Mobil 1. Exactly 8 1/2 quarts. reset my computer using the other post. total cost was 75.00 at Advance Auto and filter was in stock.
2011 BMW 328 xdrive
Black/Black int.
Retired BMW's
2006 BMW 325ci
2005 BMW 645ci
2003 Z4 3.0
2000 323i
1995 318i
1990 318is
Old 03-19-2012, 10:57 AM
herbcline herbcline is offline
Mein Auto: 2004 645Ci Convertible
Also hands on guy
Thanks everyone for this thread, I am a first time BMW owner and also like to do my own maintenance.
Your posts are going to make my first oil change easier, although I guess my biggest concern is getting the car on my ramps, with the low profile I think I may have a problem.
Old 03-19-2012, 06:46 PM
Yorgi's Avatar
Yorgi Yorgi is offline
Originally Posted by herbcline View Post
... although I guess my biggest concern is getting the car on my ramps, with the low profile I think I may have a problem.
Take a look at my oil DIY. I have pics in there on how to get your car up on standard ramps using 2x10 boards in front of the ramps. It works like a charm.
Another alternative is to buy Rhino Ramps which are designed for lowered cars.
'04 M3 - track
'06 650i Cab - daily driver
'02 Highlander - kid hauler
'01 330Ci - winter beater
Old 07-09-2013, 01:19 PM
Icyhateinyoeyez Icyhateinyoeyez is offline
Send a message via AIM to Icyhateinyoeyez
Mein Auto: 05 Bmw 645ci convertible
Thumbs up
I do mine all the time aswell! I get the original filter
And for those of you who like the original bmw oil
Its the same exact thing as castrol sintec. Bmw just puts
Their label on it. I use castrol edge wich is slightly better.
Old 02-21-2014, 10:32 AM
Alpine635 Alpine635 is offline
BAVARIAN500.COM
Mein Auto: E63, E24, C126AMG
Bmw oil banter! Solved, period!
Actually that is not quite correct about "Castrol Syntec suggestion"!
Castrol Syntec. Is a TOTALLY different formulated Engine oil and should NOT be used on all BMWs... It is not the "Universal" Engine oil for BMW's.
BMW has had a long standing performance and oil developing relationship with Castrol since 1999. BMW has partnered with Castrol for developing the Correct OIL's and lubricants for EACH and every Engine that BMW has built (Different Engines have different performance based requirements) And Castrol is the ONLY oil used to this very day!
For our 6 Series BMW's you should NOT USE SYNTEC. Different formula.
What should be used is Castrol EDGE. PERIOD!
Below is Directly from Castrol's Performance Website under the Partnership section and Oil selection area! Simply find your BMW. BECAUSE remember different Years have different Engine No. like N62 for example. Please use this data for your BMW's Engine Oil IF you do not want to use BMW Branded Motor oil, which CASTROL does supply BMW with.
Cheers!
http://castroledge.com/oil-range/oil-selector
