Old 12-09-2016, 05:50 AM
Jett3ch Jett3ch is offline
Mein Auto: 2001 530i
OEM sensors vs. Generic (Chinese)
Just a curious question I wanted to throw out there to see what y'all think. Is there really a difference between OEM sensors and eBay chinese sensors such as crank or cam for example? I've seen some debate on this where some discuss that some OEM parts are actually made in China just like the cheap eBay stuff, except they upscale the Chinese ones to make a killing. Whats everyone's opinion, has anyone had issues with cheap sensors?
Outer space.
Old 12-09-2016, 06:45 AM
Nyc Dito Nyc Dito is offline
Mein Auto: BMW 5
Outer space.
There's a difference from an OE supplier building parts in China over a unknown Chinese company building parts in China for BMW's. It's all about quality control.
Old 12-09-2016, 07:42 AM
Fudman's Avatar
Fudman Fudman is offline
I believe the manufacturer makes a significant difference WRT all replacement parts. I believe the OEM O2 supplier is Bosch. I replaced my pre-cat O2 sensors at 105K with Bosch. 20K later, one failed (threw code). I have my originals back in and all is good. This is the second time (first was with a Honda) I have had issues with Bosch O2 sensors purchased in the aftermarket from legit sources. Bottom line, the quality of the part matters regarding issues like reliability.
Old 12-09-2016, 08:27 AM
JKRIT JKRIT is offline
Mein Auto: '03 525i
But more specifically, it's about the quality specifications of the company that is going to put its name on the part, like an OE supplier or a car company. They all have different requirements, like "no more than 2 rejects per 100" vs. "no more than 7 rejects per 100." With an E-bay part from an unknown company name, you really raise your risk of getting a bad part. If you source from the car company or at least a brand that is well-recognized and respected, based on a history, then at least you have a better chance of getting a good part. Even if they all come from the same factory.
'03 525i Sapphire Blu/Grey, SP, Nav
'03 530i Sterling Gray/Blk, SP
'02 525it Titanium Silver/Grey, SP
'02 325it Orient Blu/Grey, SP, Nav
Old 12-09-2016, 08:29 AM
mjalloul11's Avatar
mjalloul11 mjalloul11 is offline
BMW forever
Mein Auto: 1996 528i 1999 MB C240
I had the rear ABS wheel sensor replaced with a chines one, couldnot find an OEM part, but for 20$ i tried it. One year later and all is good. Not all china made parts are equal !
Working on my car is a pastime
Old 12-09-2016, 09:11 AM
Mein Auto: BMW 5
Totally agree with you. BEHR is perfect example. For the E53 X5 the aux fan's they were making some years ago were catching fire. TYC (cheaper company) had no issues but was not recognized as a OE supplier. So people waited for BEHR to fix their issue or just went OEM.
Old 12-09-2016, 09:13 AM
Mein Auto: BMW 5
I sell both Chinese after market and OEM and honestly sometimes its hit or miss. We monitor all sales for comebacks and once something starts coming back more often, we block the sales for that item. Even with the OE/OES.
Old 12-09-2016, 09:52 AM
MKJS MKJS is offline
Mein Auto: '99 540iA
Have always heard here, when it comes to sensors, always oem.
I have had some experience with Chinese knives. Bought a ruff use knife from cheaper than dirt for $10. In tests to destruction it proved to be stronger than a $300 custom survival knife favored by some special forces people. Just because it's made in china does not mean it's junk. Just because it's made in Deutchland does not make it good.
Best I can figure is read and ask here what has worked and what has failed. The e39 has been around quite a while now and many here have tried about every brand of part out there and know a great deal about what is currently a good product.
Jim
Old 12-09-2016, 10:40 AM
Thanks everyone. I'm asking because I believe my cranksensor is bad, my car through a code for this so hopefully it is just that. Duralast brand at autozone wants $45 dollars for crank sensor so I'm thinking of taking the shot vs. EBay $10 or Oem$130 let's see..... I also have 2 eBay wheel speed sensors and they still work. I guess I've just been lucky so far..
Outer space.
Old 12-09-2016, 11:03 AM
Mein Auto: BMW 5
Outer space.
Where are you located?
Old 12-09-2016, 11:05 AM
Sroor9001 Sroor9001 is offline
ALGhoul
Mein Auto: Bmw 525i 2002
No problem with China sensors except oxygen sensors and map sensors brand new and already shot
Old 12-09-2016, 11:54 AM
NNJE39 NNJE39 is offline
Mein Auto: 1997 BMW 528i
Been 3 years on my chinese wheel speed sensors. Zero issues.
Old 12-09-2016, 12:53 PM
Florida
Outer space.
Old 12-09-2016, 01:28 PM
540nj 540nj is offline
Mein Auto: 03 540i6
Last week I replaced my original PS pump with autozone Chinese $110 replacement. Cured low speed steering, but whined like a (insert fav non-PC adjective) housewife. I replaced with German LUK from FCP, all is good for first 50 miles.
Dave
03 540i6
95 993
Old 12-09-2016, 04:48 PM
OK guys figured I'd update, I changed the sensor, reset codes, car is back to normal. I installed the Duralast brand from autozone using a 5mm Allen. Let's see how it holds up, had to swap over the oring. I compared both of the sensors and both seem very similar in construction, size and shape.
Outer space.
Old 12-11-2016, 09:27 AM
JaxPlanet JaxPlanet is offline
Mein Auto: 2000 528iAT
I always select OE parts for critical, long, and/or difficult jobs because you don't want to do them again or suffer the consequences, like Sachs fan clutch and Genuine fan. Except in cases where aftermarket parts work better, like FKM VANOS o-rings. I try OEM parts for non-critical, easy jobs, like a window regulator or gas cap.
Old 12-11-2016, 09:25 PM
ALGhoul
Dave
03 540i6
95 993
No no no
Big mistake
Power steering pump get new or used oem with warrenty
No China otherwise
You get whining noise and leakage within few months if it not days
Old 12-12-2016, 01:09 AM
Burning2nd's Avatar
Burning2nd Burning2nd is offline
Under the lift arms
Mein Auto: E39 540, E36 328is, E83x3
This is such a bad conversation.. I could beat you to death with the parts that you guys have thrown at cars over the years of my stay here
I stopped caring about what you guys put in your cars...
There is oil brand conversation, there's part manufacture brand conversation, there's suspension brand parts argument
@ this point i just watch you guys throw your money away.. out of sight out of mind,
FOr the record the 18$ amazon cam sensor in the 328is is doing great for about the 2nd year now.. and the 20 someing dollar one in the 540 is also doing great
Specializing In BMW, Audi, Mercedes Benz ,Volkswagen, Volvo
15486372<-----
