E30 (1982 - 1993)
Old 04-06-2009, 01:21 PM
_Ethrty-Andy_'s Avatar
E34 Converted E30 Fanatic
Headlight Alignment
How do you align the normal beam (outtermost) headlights up and down? Failed a warrent f fitness because the right one is aimed too low to the ground. thanks
E30 above Sold
E34 V12 Project Thread Here: http://www.bimmerfest.com/forums/sho...=502437&page=4
Last updated 2nd January 2014
Old 04-06-2009, 09:48 PM
downhiller's Avatar
livin large
open the hood, and behind the headlights theres a plastic cover, remove. and behind there are 2 whiteish looking screw handles. turn the upper one clockwise, but do it during night and park infront of a garage door. its pretty easy
Old 04-07-2009, 02:42 AM
I have the electronic height adjust head lights... so i need to know how to adjust that black cylinder thingy....
E30 above Sold
Old 04-07-2009, 08:43 PM
downhiller's Avatar
livin large
you got me there.
Old 04-07-2009, 08:48 PM
Yea... facelift headlights are different. anyone??
E30 above Sold
Old 04-07-2009, 10:17 PM
fcsteve's Avatar
fcsteve fcsteve is offline
610EUROs
Mein Auto: 90' 24v, 89' 325is
you mean the euro spec adjust headlights ? try and turn the black housing. i had a set here that i could spin by hand, but if yours are part of a working system i dont know if that will work. cant hurt to try. is the electronic adjuster broken ?
if you want to lead the orchestra, you must turn your back on the crowd
build: http://www.bimmerfest.com/forums/sho...d.php?t=382667
Old 04-08-2009, 12:14 AM
Managed to figure it out. I dont think they are euro spec, just normal facelift headlights with the circle in the middle (looking front on) and eliptical at the back. Not like the ones in your signature anyway.
anyway, for anyone who wants to know the answer, first turn the electric controller in the car around to 0 (on the drivers kickpanel), unbolt the grill, and the three bolts holding the headlight bracket in place. then pull the headlight up from the bottom (it wont break) and the rod coming from the black electronic height adjusting cylinder will pop out of the rubber mounting. You will notice there is a + shape on the top of the rod. Screw driver away! clockwise pulls the light down, and anticlock wise goes up. unfortunately, you have to do everything back up again (except the grill) to test it, so a guess as to how much you will need to turn it should be made. Trial and error will be inevitable
E30 above Sold
Old 04-08-2009, 07:24 AM
fcsteve's Avatar
610EUROs
the ones in my sig are standard us non-el;lipsoids. i have euro spec smoked lights here that have the auto adjust on them.
