Resetting driver info center. - Bimmerfest - BMW Forums
E28 (1982 - 1988)
Old 01-22-2017, 01:22 PM
JMerenda JMerenda is offline
Mein Auto: '86 535i
Hey all,
After doing some work on the car and reconnecting a new battery, other than time and date, none of the fuel mileage, outside temp or avg speed info is coming up. All it displays are PPPP
Any thoughts
Old 01-25-2017, 10:39 AM
joem52002 joem52002 is offline
Mein Auto: e28M, 2002
That happened to me many years ago. The dealer said I needed a new OBC.
Then someone told me to pull a certain fuse and put it back. Everything
worked fine after that. Since it was so long ago I don't remember which fuse.
Maybe check the wiring diagram for the OBC fuse
Old 01-25-2017, 01:13 PM
Mein Auto: '86 535i
Thank you. I will investigate
Old 01-26-2017, 08:30 AM
Found this on mye28.com
Press CODE then press the small recessed button on the lower right of the display
After a second or two the MPH LED will flash and the unit is reset.
Need to re enter date and time
HTML code is Off
