Old 04-10-2009, 04:53 PM
daveez daveez is offline
Mein Auto: Z3 1.8i roadster
Cool Z3 heater control dial removal
Hi , the bulbs have blown on my heater control. Does anyone know how I get to them to replace them?
Thank you.
Old 04-10-2009, 05:10 PM
The Other Tom The Other Tom is offline
Mein Auto: 2008 335i
Welcome to the 'fest !
There's a wealth of information to be found by using the search function at the top of the page (use the advanced search)
I happen to remember that Ron Stygar posted a fix it for the HVAC bulbs and found the thread by using the search function.
Here's a link
http://www.bimmerfest.com/forums/sho...highlight=hvac
(there's a bunch more threads...just search HVAC or bulb+replacement) in the Z3 forum.
2008 335i
2001 325i retired
2000 M Roadster Imola Red retired
1998 Z3 2.8L retired
Old 04-15-2009, 09:08 AM
celluje1 celluje1 is offline
Mein Auto: 1999 Z3 2.3l Alpine White
Get a Bently Manual they are extremely helpful. You have to remove the center console. I would get the trim tools from Bavarian as they will not mar your interior. Remove the climate control assembly. Install is the reverse.
Old 04-15-2009, 07:30 PM
EOD Guy's Avatar
EOD Guy EOD Guy is offline
Mein Auto: 98 Z3 // 06 X5
You don't have to remove the console, It's tricky and very tight, but it can be done through the radio hole. Remove the radio, remove the mounting screws for the A/C control panel, reach in and twist/turn/cuss it untill you can get a pair of long needle nosed pilers on the bulb.....
Old 04-15-2009, 07:35 PM
EOD Guy's Avatar
BTW the fan speed doesn't have a bulb in it, it relies on the temp control bulb to light it. The last time I had my console out I pulled the A/C control panel apart and hot glued an 12v LED (marker light bayonet type) in it and aimed it at the fan control and it works really well now, I can actually see all the numbers around the circle....
Old 02-07-2013, 06:21 AM
stm8r stm8r is offline
Mein Auto: BMW Z3
Here goes nothing
Thanks. I think I will at least give it a try through the radio hole before I put it back in this weekend. I am fully equiped to cuss as much as needed.
Old 08-06-2013, 08:39 AM
BStanton BStanton is offline
Mein Auto: 1998 BMW Z3
I too have the same issue, my fan control is not illuminated. So there is just 2 bulbs to illuminate all 3 dials, not 3 bulbs? Thanks..
This is my toy. 1998 (2.8)
Old 08-06-2013, 09:33 AM
dougmcintyre dougmcintyre is offline
formerly updmst
Mein Auto: 2000 M Coupe, 1997 318ti
Post 7 from previously posted url http://www.bimmerfest.com/forums/sho...highlight=hvac
Originally Posted by Ron Stygar View Post
Received the backplate today. Comes with lamps and the blower switch.
Lamps are sure tight in place. Had to use long nose to get them out. Not sure how you would do this with it in the dash.
Old 08-08-2013, 11:43 AM
Mein Auto: BMW Z3
Yes. Strangely, there are only two bulbs, and they only illuminate two dials. The air directional control dial does not illuminate, and never has. I read where one guy rigged a separate light bulb and just put it near the unlit dial and got (in his words) satisfactory light through the white parts of the dial. I have replaced my two bulbs, memorized the dark third dial, and learned to think of it as one of those endearing quirks. "nothing is perfect"
Old 08-08-2013, 07:36 PM
postalZ3 postalZ3 is offline
Mein Auto: 2000 Z3 2.8
My 3 dials light up just fine.
<img src=http://i.imgur.com/JMjPR.jpg border=0 alt= />
Old 11-10-2013, 04:10 PM
gatofelix gatofelix is offline
Mein Auto: 2000 z3 bmw
well I have just learned of only 2 bulbs! I knew all 3 dials lid up ,now only the blower and temp.dials light up, guess 1of them bulbs is out for sure!!well had to check it out for my self my 2000 2.3 z3 ,has only (1) went to dealership, told them what I drive ( bought it there) he showed me the diagram. so I went home and pulled the radio out, which is very easy .got a small mirror and a flash lite .sure enough only 1 bulb, and still good !while I had the radio out I sprayed the temp. con. nob from the back with silicon spray. and this is for 2000 2.3 Z3.
Old 11-25-2013, 05:46 PM
ditomfight ditomfight is offline
Tom
Send a message via AIM to ditomfight
Mein Auto: 1997 Z-3 1.9
1997 Z3 Climate Control Installation
I just learned that my climate control needs to be replaced. I have it to the point where I can turn it to look at it. I see from the posts here that it is difficult to remove the assembly. My next problem will be to get it out and reinstall the new one when it gets here in 8-10 business days. Any comments?
Old 03-19-2014, 02:47 PM
awbooth awbooth is offline
Mein Auto: 1998 BMW Z3 Conv. 318i
heater housing bulb
Are the bulbs available to purchase online/ebay?
is it a dealer item only? you have to buy the bulb and housing, bulb does not seperate from black housing.
Old 03-19-2014, 03:50 PM
vintage42's Avatar
vintage42 vintage42 is offline
BMW CCA 1405
Mein Auto: 1997 BMW Z3 1.9 5MT
Yes, a bulb in a black base as shown in:
http://zroadster.org/wiki/bmw-z3/mai...control-bulbs/
P/N 61138353797 from:
http://www.ecstuning.com/Search/SiteSearch/61138353797/
Old 03-19-2014, 04:40 PM
sweet! thanks for the quick response!!
ant
Old 03-19-2014, 05:08 PM
radio installation kit for 98 z3....
Not sure how to mount my new aftermarket radio in my z3? Any know where i can purchase one? Thanks
Old 03-19-2014, 07:16 PM
Blacklane Blacklane is offline
Mein Auto: 1998 Z3 Roadster
Any single-DIN radio will fit. Buy it anywhere. You will also need a radio antenna adapter for the German antenna wire and the job is much easier with a vehicle-specific harness adapter available through most stereo stores, including on-line stores, such as Crutchfield.
There are many threads here on the topic. Near the top of the page, on the right, is a button labeled "Search This Forum." Click that and search for "radio," "stereo," etc.
Old 03-19-2014, 07:18 PM
thanks!
it looks like all wire harness kits do not have the capability to power the cd changer in the trunk oh well. ill just sell it on ebay.
Old 03-19-2014, 07:37 PM
I'm not sure why you need that. The more modern approach is to get an Ipod, MP3, or even Pandora-capable radio. Any of those will be far more capable than a CD changer.
Old 03-19-2014, 07:41 PM
I agree. Good point!
Just had to replace the heating control dash light bulbs, $12 each. Holy expensive!
