E36 (1991 - 1999)
Old 04-13-2009, 10:18 AM
der BMW der BMW is offline
Mein Auto: 1992 BMW 325is
DIY - Oil Service Light Reset *PICS*
My oil service light was bothering me so I decided to do a quick fix and write up this diy. This will take no more than 5 minutes to complete.
Tools required:
1. A paper clip, bent like so:
I used pliers to bend the ends in order to increase the contact surface area. This probably isn't necessary but whatever.
Procedure:
1. Pop hood, remove black plastic cap from diagnostic port (located near the engine on the passenger side).
2. Turn key to position 2 so that the oil service indicator lights up on the dash.
3. Take your paper clip and insert one end into pin 7, then the other end into pin 19. It's important that you follow this specific order. Hold for approximately 6-8 seconds, then remove.
Pin 7 is the second one across from the Pac Man's open mouth, Pin 19 is the one directly to the left (for reference, if you visually connect the points from pin 7, to Pac Man, to pin 19, it will form a right angle)
4. After removing the paper clip, check your dash to see if your light has been reset.
It should look like this:
Yes, I know my '92 has very low mileage.
5. Slap yourself on the head for not doing this a long time ago.
6. Pat yourself on the back for saving $ and a trip to the stealer or mechanic.
*NOTE* Don't hold the paper clip in longer than 10 seconds. If the light doesn't reset the first time, try holding it in a second or two longer. Mine took 8 I think.
1992 BMW 325is
Old 04-13-2009, 10:22 AM
Vitacura's Avatar
Vitacura Vitacura is offline
Ich liebe mein BMW
Mein Auto: 15 M235i CV & 16 M5
So if done properly the dash will have the CEL?
j/k. Nice write-up!
Past:
-1989 325i Convertible
-2008 328i Jet Black/Black, Premium, Sport, Nav, Step, Paddle, Ipod
-2002 M5 LeMans Blue/Black, Rear Sunshade, M-Sound, Heated Seats, Xenon, PDC
-2004 M3 Convertible Silver Grey/Grey, SMG, Nav, HK Sound, Heated Seats, Xenon
-2007 335i Jet Black/Terra Leather, Premium, Sport, Step, Paddle, Nav, CA
-2006 525i Black Sapphire Metallic/Beige, Manual, Nav, HUD, PDC, Xenon
-2002 325i Orient Blue Metallic/Beige, Manual, Sunroof
Old 04-13-2009, 11:27 AM
cmybimmer's Avatar
cmybimmer cmybimmer is offline
IM DA BES
Mein Auto: A rental
Great write up, I've done this before and it works great. Thx
-Usama
"The American Dream only makes sense if you're sleeping" - Lowkey
Old 04-13-2009, 01:11 PM
rrtec's Avatar
rrtec rrtec is offline
Bored Worker
Mein Auto: 540i/6 4/99
Awesome, saved me a trip to the dealer as I just changed my oil yesterday!!
2001 740il Sport- Needs maintenance.. Parts ordered..
2006 Volvo XC90- Kid Hauler
FC3S LS1/6Speed
1992 BMW K75s Cafe build
Old 04-13-2009, 01:36 PM
eddie_b eddie_b is offline
Mein Auto: 1993 325is, 2006 Ford Exp
I believe 19 is just a ground, and grounding pin 7 will accomplish the same. Also if I'm not mistaken, keeping the paper clip in longer would reset the service indicator light.
Old 04-13-2009, 02:30 PM
E36 Phantom's Avatar
E36 Phantom E36 Phantom is offline
I Am The Machine
Mein Auto: Dreier, Fünfer & Siebener
Eddie, right on both counts.
// Chad //
// 2006 BMW 330i Sport 6MT // 2006 Toyota Highlander Hybrid //
// 1997 Range Rover 4.0 // 1994 Range Rover Classic //
// 1997 Land Rover Discovery // 1998 Land Rover Discovery //
// 2009 Kawasaki Concours 14 // 2006 Kawasaki Ninja 250 //
// 1999 Chevy Tahoe //
Ok...this is getting ridiculous. Someone come buy a few of these things.
Originally Posted by SlimKlim View Post
You're a derbanana
Old 04-14-2009, 06:24 AM
rrtec's Avatar
Bored Worker
If I could only figure out how to reset the ABS and PAD warning after the brake job, i'd be set.
FC3S LS1/6Speed
Old 04-14-2009, 08:31 AM
I think someone on here said he pulled the ABS relays out for a few hours and after he put them back in the light was gone. Give it a shot I guess.
1992 BMW 325is
Old 04-14-2009, 01:00 PM
I Am The Machine
RRTEC,
By PAD warning do you mean the low brake pad light? That's not "resettable" - you have to replace the loop sensor with the brakes each job for it to go away.
// Chad //
You're a derbanana
Old 04-14-2009, 08:04 PM
Bimrpwr's Avatar
Bimrpwr Bimrpwr is offline
Mein Auto: 85 VW Quantum
Originally Posted by E36 Phantom View Post
RRTEC,
or you can just cut the sensor off and strip the wires bare and twist them together..
Old 04-15-2009, 12:20 AM
I Am The Machine
^Yes, you could, but then you lose the sensor. For 99% of the people, having a functioning sensor is preferable.
// Chad //
You're a derbanana
Old 04-15-2009, 04:34 AM
N:CR41G N:CR41G is offline
'97 318is Hellrot
Mein Auto: 1997 BMW 318is E36
I heard something about bending paper clips and f*cking around in the diagnostic socket...
...I just bought my self an oil & service light indicator tool that did them both...
Pretty expensive, but pretty awesome too!!
(PS. I serviced my car myself with my mechanic mate, before using the rest tool)
Old 04-15-2009, 08:09 AM
rrtec's Avatar
Bored Worker
RRTEC,
Ah, so I need to replace the sensors... I did a brake job as the light was on when I bought the car, the pads looked ok so I am assuming that the brakes were fine but the PO didn't spring for the new sensors..lol OH well..
FC3S LS1/6Speed
Old 04-15-2009, 08:13 AM
Adam318is's Avatar
Adam318is Adam318is is offline
Can I Scream?
Mein Auto: 1994 BMW 318is
I did this trick last night, worked like a charm. Does anybody know the "inspection service" light schedule? As in, when in green, when it drops to yellow and finally red? The light has been yellow since I've had the car and have had a couple oil changes in between, so figured I'd just reset it before it dropped to the red.
*Bianca*1994 BMW 318iS CalypsoRot -1245
Old 04-15-2009, 12:04 PM
Bimrpwr's Avatar
yeah, but i jsut short mine out. I dont need a stupid light to tell me when my brakes are going out.
If i had the time i would get rid of 90% of the sensors.
Plus my car is getting more and more of a track car then a DD.
Old 04-15-2009, 12:14 PM
Adam318is's Avatar
Can I Scream?
^ Agreed. Kind of like the rain sensors on cars now. I mean, really, do you honestly need your car to tell you when it's raining and turn on its wipers? Just one more thing to break is how I see it. The less bells and whistles, the better, I already hate the seat warmers on my girlfriend's '03 325i.
Old 04-16-2009, 02:40 PM
I'm pretty sure the lights change every time the car reaches a certain mileage interval. The exact number, I have no idea, but I think it should go from all green to red in less than 5,000 miles.
1992 BMW 325is
Old 04-16-2009, 03:03 PM
I Am The Machine
I happen to love my rain sensing wipers .
The point isn't to "tell you when it's raining" dork. It varies the speed to keep up with rain amount. This is AMAZING when you do a lot of driving on/off/on/off freeways or stop and go city driving or when the rain is changing intensity a lot on it's own. No adjusting the wipers every 10 seconds. Flick the switch to auto, and just let it change it. It's not like the point is to turn them on if you forget .
(Edit, just FYI, my car has Off, Auto, Intermittent (with several intervals that you can actually adjust ), Low, and High. Not like Auto is all that we get.)
Also, out here seat warmers are hardly necessary, but now and then on a cold morning or if I'm a little sore, damn they feel good.
I love convenience or fun bells-n-whistles. I DEPLORE things that make up for the driving being an idiot (traction ctrl, lane departure warning, the warning lights on side view mirrors that tell you if a car is there, Volvo's new "auto braking" thing, etc). Back up cameras I have mixed feelings about***********: obviously they can be helpful to let you know if a kid is behind you, but I have seen people not even look behind them first and just start backing up, eyes glued to the little screen. Bad.
/soapbox
// Chad //
You're a derbanana
Old 11-25-2009, 09:13 PM
cmybimmer's Avatar
IM DA BES
Mein Auto: A rental
Thats on an e90. Its completely different between the E36 and the E90.
-Usama
Old 11-26-2009, 06:58 AM
All2kool's Avatar
All2kool All2kool is offline
Mein Auto: '02 BMW 325Ci Convertible
j/k. Nice write-up!
No, the CEL will not stay illuminated; remember, the car wasn't started to RESET the Oil Service indicator, the CEL comes on when you turn the key to perform the RESET.
Old 11-26-2009, 07:28 AM
Crashj Crashj is offline
Mein Auto: 1994,318ci,Red,vert
Accolades.
Old 02-23-2010, 05:13 PM
Gary Perkins Gary Perkins is offline
Mein Auto: 1996 BMW328ic
reset 5bars after service
Someone please help me identify the#7 and #19 on the pacman face, I need to learn how to do this very much since no one cares or knowsin this area. Come on guys help an old fart out with his 1996 328ic
gary perkins
randolph
garyp75@msn.com
Old 02-23-2010, 05:18 PM
jonesin's Avatar
jonesin jonesin is offline
The Canadian Prick.
Mein Auto: '96 328is Cosmos
Here you go Sir.
http://www.unofficialbmw.com/e36/ele...ce_lights.html
(I found this at http://www.bimmerdiy.com - Great site!)
Originally Posted by hnaz View Post
I grew up in a time when the internet was just a baby. Grammar back then versus now... holy cow. You could watch the degradation of society as the internet became more mature.
HAS KEN HAD HIS MEDS YET?
Old 06-07-2010, 08:15 PM
bluebee's Avatar
bluebee bluebee is offline
Seek to understand,^Value
For the record, the E39 can use this method to reset the oil, brake fluid, service I and service II interval. This may or may not be useful to you.
