E46 (1999 - 2006)
Old 04-15-2009, 08:42 AM
Doc Holliday Doc Holliday is offline
Still Cruisin'
Mein Auto: 2003 325xi, 2001 Z3 3.0
2003 325xi transmission fluid
I have a 2003 325xi with the A5S390R transmission (don't kill me, it's my wife's car, my Z has a manual).
The transmission fluid for this car is Texaco EFL8072B, which is horrifically expensive.
Has anyone successfully used another Dexron VI level fluid like Red Line D6 without any problems?
I don't believe in "lifetime fill" fluids. I'll believe in it when I get a lifetime warranty from BMW for not changing the fluids.
Any help is appreciated.
Old 04-15-2009, 09:35 AM
3beemers 3beemers is offline
Mein Auto: 01 330i 09K13GT 83R100RS
How much is expensive?
Old 04-15-2009, 09:37 AM
Mo.licious's Avatar
Mo.licious Mo.licious is offline
Who is John Galt?
Send a message via AIM to Mo.licious
Mein Auto: 2001 325Ci Convertible
Source: http://www.bimmerfest.com/forums/sho...d.php?t=166135
The original fluid in this transmission is Esso ATF LT71141, a synthetic blend that BMW sells in 20L barrels for $28/L (yes, you read right, $560 bucks a barrel). If you bring your own container, some dealerships will sell you smaller quantities. 7 L at $28/L is still $192, so if you insist on sticking with the OEM fluid, VW, Audi, and Porsche use the same ZF transmissions that use the same fluid and you can get it for $16/L from their dealerships and a couple of web sources (see p/n and links at the end). VW also sells a Pentosin substitute that can be had for $8-9/L. Valvoline has certified Mercon V as compatible with Esso LT 71141, as has Castrol with their Multi-Vehicle Synthetic ATF. Plenty of folks have also used the Redline D4 ATF product, and some have also tried Amsoilís synthetic ATF with success. If youíre still under warranty Iíd stick with the OEM fluid (VW stuff is fine, itís the same thing). If anything were to happen I think youíre position would be better if they couldnít blame it all on different fluid. Being out of warranty, I felt comfortable using the Mercon V. It doesnít hurt that it goes for $4/qt, 1/7 the price of the BMW juice and ľ the price from VW.
From the outside looking in, you canít understand it. From the inside looking out, you canít explain it.
Old 04-15-2009, 10:20 AM
Still Cruisin'
67 bucks a liter.
Old 04-15-2009, 12:26 PM
Melquin Melquin is offline
Mein Auto: 2005 330i
That is for the ZF 325Z not the GM 360/390R.
Old 04-15-2009, 12:30 PM
mickey513 mickey513 is offline
Send a message via AIM to mickey513
Mein Auto: e46
I suggest you jack up the car and actually go down and read the part# on the transmission sticker. Mine had the green sticker (texaco fluid), but when I down to check the part# on the sticker, it had the part# for the Esso Fluid.
Old 04-15-2009, 01:26 PM
Still Cruisin'
Already did that, that's how I know it's the Texaco EFL 8072B. The BMW part number on the sticker on the pan translated out to that fluid.
Old 04-15-2009, 02:37 PM
slyfocks slyfocks is offline
Mein Auto: 2005 330ci
Yours should specify the Esso LT-71141, but I'd check your color perception, sticker really should be blue (faded/stained maybe?). The '02 330i has the ZF 5HP19 (A5S 325Z) The RWD 330i didn't start using GM5-4L40E (A5S 390R with the Texaco ETL-8072B spec.) until 03/03. The Xi always used the 390R .
Old 04-15-2009, 08:04 PM
GCoop's Avatar
GCoop GCoop is offline
Mein Auto: 2004 325xi
If he has an XI he has the GM tranny. No question about it.... GM tranny needs fluid that meets the Texaco ETL-8072B specifications.
This is what I just used in my recent ATF change. At 4.99/QT its a bargain at twice the price compared to what the original fill fluid goes for. It meets the ETL-8072B spec. I have about 800 miles on the new fluid and couldnt be happier. Here is a link to the data sheet stating that it meets the Texaco spec.
Old 04-15-2009, 08:55 PM
xi_ter xi_ter is offline
Mein Auto: 2003 BMW 325xi
Use Redline D4 ATF at about $10 a quart. With a full drain you'll need about 7 quarts. The user consensus is smoother shifting.
Old 04-16-2009, 05:12 AM
Still Cruisin'
Thanks for the link, that's what I was looking for. I figured there had to be an alternative to 67 bucks a liter ATF.
Old 04-16-2009, 10:42 AM
Still Cruisin'
I confirmed this opinion by direct contact with Red Line. They said it's a recommended substitute and will mix fine with the Texaco fluid. Thanks to all who replied.
Old 04-16-2009, 01:26 PM
Mein Auto: e46
Nope, I am positive it was green. Pass my last vision test with flying colors :P
Old 04-25-2009, 12:19 PM
bimmerman11 bimmerman11 is offline
Mein Auto: 2005 330 xi & 2009 X5
[QUOTE=GCoop;4096909]If he has an XI he has the GM tranny. No question about it.... GM tranny needs fluid that meets the Texaco ETL-8072B specifications.
I have a 330 xi and my indy mechanic told me I have the ZF tranny. Are you saying that all xi cars have GM transmissions?
Old 04-25-2009, 01:25 PM
[QUOTE=bimmerman11;4124725]
If it is an automatic, yes.
All automatic E46 xi have the A5S390R (GM5L40E) transmission.
A 2005 manual would have a ZF GS6X37BZ.
Old 04-25-2009, 05:48 PM
shadow 2 shadow 2 is offline
Mein Auto: 2011 335ix
He is mistaken. All Xi automatics have the GM tranny.
Old 04-25-2009, 08:50 PM
GCoop's Avatar
[quote=bimmerman11;4124725]
Yes I am. Unless your car has had its transmission replaced or something your mechanic is mistaken.
Old 06-16-2009, 12:16 AM
sp100 sp100 is offline
Mein Auto: 2004 5301
How do you know that this fluid meets ETL-8072B spec.?
Old 08-04-2010, 10:34 AM
himefrankie himefrankie is offline
i love lamp.
Mein Auto: 03 330xi
Question typo?
If you follow the link, and look at the compatible BMW fluid specifications it says ETL-8027B .. not ETL-8072B. Typo?
Old 08-04-2010, 12:04 PM
aioros aioros is offline
aioros
Mein Auto: 99 528i auto m-sport susp
my 01 330xi has the GM tranny which has the green sticker and the texaco fluid part number. I used the castrol import multi-vehicle fluid on my recent ATF change. No problems so far.
