Old 04-15-2009, 02:07 PM
nutterdog nutterdog is offline
Mein Auto: 328xi
replacing front turn signal bulb
How do I remove the drivers front turn signal bulb holder? Is it a turning motion? I can barely get my hand on it.
2015 328xi Sport Line/Premium/Nav
Old 04-15-2009, 02:08 PM
lild's Avatar
lild lild is offline
livin the 'Fest
Mein Auto: 97' 528i, 06 ninja
might have to remove the air box.
The more you complain, the longer God makes you live. SPHOBA #00002
Old 04-15-2009, 02:52 PM
RRsE39's Avatar
RRsE39 RRsE39 is offline
Mein Auto: 2001 530iA Sport
I removed mine fine...it is a tight squeeze though on the drivers side.
Just like any other bulb on any other car, just twist it and pull it out.
Old 04-15-2009, 03:51 PM
QSilver7's Avatar
QSilver7 QSilver7 is offline
Hmmph...well I'll be @$%&*+...I have a page from the owners manual on every bulb except the headlight/turn signal bulbs.
OH WELL...with so many different kind out there...perhaps it's better that I didn't.
Q {BMW CCA Member #191509}
(SOLD)
Old 04-15-2009, 04:29 PM
Hosephus Hosephus is offline
Mein Auto: 2002 540i6
My driver's side is just fine, but my passenger side I had to remove the airbox for. No way to get leverage otherwise.
Old 04-15-2009, 04:41 PM
Mein Auto: 328xi
I got it out with a good amount of force. Just wanted to make sure the force was applied in the correct direction. Thanks.
Old 05-22-2011, 12:12 AM
N3llyNova N3llyNova is offline
Mein Auto: PORSCHE 911
Question Recognize..
Hi Nutterdog,
Do you recognize my name? If so, please respond.
Old 11-09-2011, 09:23 PM
Curtis37617 Curtis37617 is offline
Mein Auto: 525i
Which way do you twist it, counter-clockwise or clockwise? Like everyone else I can barely get to it on the drivers side, want to be certain I'm twisting it in right direction, is really tight.
Old 11-09-2011, 10:46 PM
King 5's Avatar
King 5 King 5 is offline
Send a message via AIM to King 5
Mein Auto: 1997 BMW 528i
Pinch the tabs together, twist, and pull. Be prepared to snap a tab though...
1997 BMW 528ia 2/97
2004 BMW 330ci 4/03
2008 BMW 335i 3/08
Old 11-10-2011, 06:00 AM
bluebee's Avatar
bluebee bluebee is offline
Seek to understand,^Value
I'm always confused when this topic comes up.
Is the OP trying to replace the rectangular side marker light bulb or the curved side of the headlight assembly where the angel eye fiber optic link ends or the (orange) bulb that is the third bulb inside the headlight assembly?
Here is the side of the headlight itself, which flashes with the turn signals but which has no bulb:
Now, here is the actual bulb in the headlight that is the turn signal bulb:
And, then, there is the side marker light (does that flash with the turn signals?).
Anyway, a quick E39-only title-only search for "turn signal bulb" revealed a few threads on that topic (and these pictures, which are of my E39, and quite a few of QSilver7's excellent responses).
Personally, if it's the orange bulb, even with small hands, I find it vastly easier to just unbolt the headlight (four 8mm bolts) and then pull the headlight assembly out a bit for muuuuuch easier access. But that's just me.
To the OP, I will add all these threads to the bestlinks so please let us know what you did to resolve the problem, and please let us know which of the three 'bulbs' it is:
1) Yellow bulb inside the headlight assembly
2) White light at the very side of the headlight assembly
3) Side lights at the side of the vehicle
Thanks - and please keep us updated.
Old 11-10-2011, 05:33 PM
Steve530 Steve530 is offline
Counter-clockwise looking from the back of the car. It's a normal right hand threaded socket. It's a tight fit.
Steve
2001 530i/5 S+P CDV delete/Akebono ceramic pads
M5 SSK/RedLine MTL/M5 rear sway bar/Bilstein HD
OSRAM CBI
BMWCCA Member #337964
Old 11-12-2011, 07:50 AM
Edgy36-39's Avatar
Edgy36-39 Edgy36-39 is offline
Constantly Learning
Mein Auto: 2006 M3, 2002 M5
If you think the regular E39 is tight, you should see the M5. No room whatsoever. I had to ask my wife for help, much smaller hands!
To remove, twist clockwise -- away from the inside of the car. Reverse to tighten.
BB, I know I could have removed headlights but seemed like too much trouble for turns replacement. Subsequently I was told that removing the air box is very easy and gives lots of room.
While you're in there, replace with better bulbs. I like the silverstar blues, kills some of the amber:
BLUE HEAVEN:
Interlagos Blue 06 M3, Autologic tune, K&N CAI, Agency Power midpipes and exhaust, Fortune Auto coilovers, ///M Pedal Kit, UUC SSK. MRegistry listing here.
Le Mans 2002 M5, Black/Titanium, Rogue SSK, Dinan exhaust, PSS9 coilovers, Euro rotors, iPod integration. MRegistry listing here.
Old 11-12-2011, 02:36 PM
Yes, the side markers just in front of the doors flash with the turn indicator..
I have a pair of those and like the way they look. Unfortunately, OSRAM/Sylvania no longer makes those coated bulbs that flash yellow.
So you're stuck with the "egg yolk" look. You can spray paint the front of the bulb with a light coat of silver paint. I've had mixed results with that on the PY21W rear turn signals.
Steve
OSRAM CBI
Old 11-12-2011, 03:24 PM
Edgy36-39's Avatar
Constantly Learning
Unfortunately, OSRAM/Sylvania doesn't make those coated bulbs that flash yellow.
Don't know what you mean here -- my silverstars flash amber. Otherwise I'd never pass inspection in VA.
BLUE HEAVEN:
Old 11-12-2011, 03:32 PM
I edited the post. It's my understanding that the OSRAM/Sylvania has discontinued production of the "Diadem" bulbs that look silver and flash yellow. They are not in the current catalog.
Steve
OSRAM CBI
Old 11-12-2011, 04:00 PM
Edgy36-39's Avatar
Constantly Learning
If true that's disappointing. Good thing I've got a backup set of 1157s for my M3. Better find some for the M5.
Stealth bulbs are offered by other vendors.
BLUE HEAVEN:
Old 11-12-2011, 04:05 PM
Let know if you find any OSRAM/Sylvania stealth bulbs. I'd like an extra pair for the front and back.
Steve
OSRAM CBI
Old 01-08-2012, 05:57 PM
Edgy36-39's Avatar
Constantly Learning
Happy 2012. Powerbulbs still has the rears: http://www.powerbulbs.com/product/os...ulbs-twin-pack
No luck so far on the fronts.
BLUE HEAVEN:
Old 07-23-2014, 03:03 PM
Me Happi Me Happi is offline
Mein Auto: 2010 328i sedan sport pkg
I did it myself!
Thanks to all of you that post helpful DIY instructions on this forum.
I was able to replace my right front turn signal bulb today in under 5 minutes. When my left turn signal bulb burns out, it won't be as simple. It's tucked way down in there behind stuff!
Helpful tip: I went to my local BMW dealer's parts department to get the replacement bulb. Big mistake! I really don't know how they can look you in the eye when they take your money. Google the part number and you'll find reputable online German auto parts companies (Pelican Parts) that carry it for a third of what I paid (before shipping costs). Lesson learned!
Part #: 63-21-7-160-900 BULB YELLOW 5
Thanks all!
Barbara
Old 07-23-2014, 11:32 PM
bluebee's Avatar
See also:
- How to cross reference all light bulbs for any BMW E39 including for the headlights, stoplights, backup, blinkers, dome, vanity, side markers, licplate, parking, fog, trunk/boot, glovebox, etc. (1)
Old 08-08-2014, 02:55 PM
bluebee's Avatar
Interesting thread today on someone who failed Massachusetts inspection, not due to the amber turn signal bulb, but due to the clear lens.
> E39 (1997 - 2003) > Car won't pass inspection (BS reasons)
Originally Posted by hh3uunp View Post
I have amber turn signals but they are telling me the lense needs to be amber.
We might find information about the clear plastic in one of these threads, found by typing /lens f3 in the bestlinks:
replacing just the headlight lens (1) (2) (3) (4) (5) (6) (7)
For the record, this is my turn signal bulb:
And this is my lens (ignore the caption, the dark spot is the parking light):
Here are all my bulbs in one headlight:
See also:
- Headlight aiming DIYs (1) (2) (3) (4) (5) & how to physically remove the BMW E39 Hella headlights (1) & how to twist out the headlight bulbs (1) (2) (3) including HIDs (1) & which stock H7 'halogen' bulbs to buy (1) (2) (3) & how to physically remove the front turn signal bulb (1) (2) (3) (4) & what front turn signal bulb to replace it with (1) & how to remove the angel eye bulb (1) (2) (3) & which stock angel-eye bulbs to buy (1) (2) (3) & how to retrofit halogen angeleye bulbs to LEDs (1) (2) (3) (4) & how to modify pre-facelift headlights to angel eyes (1) (2) (3) (4) & headlight plastic polishing & refinishing DIYs (1) (2) (3) (4) (5) (6) (7) & replacing just the headlight lens (1) (2) (3) (4) (5) (6) (7) & how to cross reference all light bulbs for any BMW E39 including for the headlights, stoplights, backup, blinkers, dome, vanity, side markers, licplate, parking, fog, trunk/boot, glovebox, etc. (1) & more information if you really want to know everything about broken headlight adjusters (1) (2) (3) (4) (5) (6) (7) (8) (9) (10) (11) (12) (13) (14) (15) (16) (17) (18) (19) (20) (21) & how to make your own headlight adjusters (0) (1) (2) (3) and a summary list of all your options when your headlight adjusters are broken (1) & headlight autopsy photos (1) (2) (3) & an explanation of the weird flat spot on the USA spec headlights (1) (2) & an explanation of HID versus conventional headlights and why the high beam is always a halogen H7 bulb (1) (2) (3) & the age-old argument of whether to buy aftermarket DJ Auto or Depo headlights (1) or OEM Hellas (1).
Old 10-27-2014, 01:17 PM
Scotes's Avatar
Scotes Scotes is offline
Send a message via AIM to Scotes
Mein Auto: '03 M5
Ok... so '03 M5... Looking from the back of the car do you turn this counter-clockwise to loosen (normal thread) or clockwise (reverse thread)? Post 11 says one way and post 12 says the other...
'03 M5 Carbon Black
Incoming: 2016 340i Estoril Blue
Stolen, recovered, auctioned: '03 530i 5sp Sterling Gray, SP, PP, modified CDV, Dinan rear sway, retrofitted NAV
"A democracy is a sheep and two wolves deciding on what to have for lunch. Freedom is a well armed sheep contesting the results of the decision." - Benjamin Franklin
Old 10-28-2014, 01:41 AM
pudl's Avatar
pudl pudl is offline
Mein Auto: E39 530dAT 2001
You turn it the normal way to loosen on both sides.
Old 10-28-2014, 02:24 AM
bluebee's Avatar
Typing /bulb f3 in the bestlinks nets this:
- How to physically remove the front turn signal bulb (1) (2) (3) (4)
See also:
Old 10-28-2014, 09:28 AM
golferjohnm's Avatar
golferjohnm golferjohnm is offline
Mein Auto: '01 540i 6sp '01 X5 4.4
One thing I noticed while replacing a Corona Ring, (Angel Eye) bulb was the 'parking' light or second filament of the turn signal bulb illuminated. This occurred when I had the AE bulb removed from its housing.
So I guess we have an option to run our AE's or take them out and have the two corners lit
'01 540i 6-speed, blk/blk, upgraded stereo w/sub, passport, Dice Mediabridge and some cool M-stuff
