E90/E91/E92/E93 (2006 - 2013)
Old 04-17-2009, 04:55 AM
MrVegas MrVegas is offline
Mein Auto: 2008 335i
Please recommend nice soft tires for my 335i
What are the best tires for absorbing the rough road surfaces? Price is not a factor, I just want excellent tires that are quiet and soften up rough roads ... the runflats have to go!!!!
Old 04-17-2009, 05:01 AM
DSXMachina's Avatar
Automaticallyparsinglinks
Do you have the Sport Package, and which size wheels do you have?
Old 04-17-2009, 05:31 AM
Yes, I have the sport package and I have the stock 18's
Old 04-17-2009, 06:16 AM
DSXMachina's Avatar
There have been many discussions on this board which address your question directly, and a few indirectly. For instance, search "Pothole explosions" for starters, it's epic. Then search "tires". You are going to be reading a long time.
Lots of opinions and helpful information can be found using the Search function.
Old 04-17-2009, 06:31 AM
captainaudio's Avatar
Worlds Foremost Authority
Mein Auto: 335i E93 - 750Lix
I found that Pirelli P_Zero Nero M&S high performance all season tires were a big improvement.
CA
Drivers Club at Lime Rock
The Glen Club
BMWCCA
Cayman Club Nor'Easters
Sports Car Club of America
American Mural Project
Old 04-17-2009, 06:39 AM
Spagolli94 Spagolli94 is offline
Mein Auto: 2006 330i
Are you looking for all-season or summer tires? I don't want to worry about the swap, so I'm going to try the all-season Yokohama Advan S4's. If you do want to go all-season, your choices are pretty limited.
Old 04-17-2009, 06:43 AM
I would like to get all season if they are great tires for absorbing rough roads. It would be nice to not have to swap them out in the winter.
So Pirelli and Yokohama make real good all-seasons?
Old 04-17-2009, 07:05 AM
daranco daranco is offline
Mein Auto: 09 BMW 335i Convertible
Smile my opinion
I've been researching this very question as well (for the past year!) -
and I don't even have my car yet!! (I'm picking it up next month in
South Carolina). Anyway... after reading through tons of stuff here
on bimmerfest, and also doing hundreds of hours of comparisons
via TireRack (using many of their surveys, etc), here are my
opinions: (note... I'm getting a 335i convertible, with the sport
package which has 18" wheels, 225/40 in front and 255/35 in rear)
(1) Going to NON RFTs will be the biggest factor for softening the
ride and better survival over those potholes;
(2) Since I don't run my car on a performance track, nor do I expect
to run at speeds over 100 mph (this will be a car that I use for my daily
commute), I am willing to give up some of that instantaneous road-gripping
steering performance. My preference is to maximize ride comfort AND
thread life AND good performance on wet roads. Due to all these factors,
I am strongly leaning towards getting all-season tires, instead of
separate summer and winter tires. SInce I live in Maryland, we don't
get much snow - but enough winter weather that summer tires just won't
do.
(3) Since my previous cars have been large sedans (Buick LeSabre,
Lincoln Town car, etc), I become very spoiled with that "big car ride"
and also getting 60K miles on a set of tires. So, my plan for the
new BMW will likely include doing a -1 down-sizing (like TireRack
recommends for better winter performance). That is, I will likely
buy new wheels (rims and tires) which are 225/45-17 - and use that
SAME SIZE on all four wheels. From everything I have read, this should
(a) help soften the ride
(b) better survive potholes
(c) better tread life (especially since all 4 wheels are the
same size means you'll be able to rotate every 5K miles)
(d) There are a WHOLE LOT MORE choice for 225/45-17 size tires
than there are for the 18" staggered set-up which can't be rotated.
And this smaller size is also cheaper than the 18" versions, and a
WHOLE lot cheaper than the typical RFTs (and RFTS wear out
a lot sooner in almost all cases);
(e) This down-size technique will get better performance in
a typical snow environment (like 6" or less). If you usually have
much bigger snow storms, you might need to go with real winter tires.
(f) You have to remember, how-ever, that by doing this minus
size trick and having a slightly higher aspect ratio (45 verses 40 in front
and 45 versus 35 in rear), the sidewalls WILL be slightly softer, and
so if you are doing extreme cornering - the limits as to what the
car (and tire) can do will be lower than with the RFT's with a lower
aspect ratio.
(4)So, given all those assumptions above, I've researched this to death
as far as tires brands, and here are my top choices for tires in the
all-season Ultra High Performance category (in priority order):
(a) Michelin Pilot Sport A/S Plus
(b) Yokohama ADVAN S.4
(c) Bridgestone Potenza RE 960 A/S Pole Positions
** The Michelins have a 45K tread life warranty, Yokos have no warranty,
and Bridgestones have a 40K warranty.
Go and read TireRack's surveys on these tires (for the Michelins, make sure
you read about the Pilot Sport A/S PLUS, as there used to be a previous
version - without the "Plus" - which wasn't as good).
(5) One more thing to think about.... one more option...
you could consider going with a "Grand Touring Tire" instead of the
Ultra High Performance tire. In this Grand Touring class, here
are my choices for an All-Season tire:
(a) Michelin Primacy MXV4
(b) Bridgestone Turanza Serenity
(c) GoodYear EAGLE Response Edge
** This category will obviously not be nearly as good with respect
to steering response as you would get in a UHP class category, but you
are likely to get closer to that "big car ride" . The Primacy has a 60K
tread life warranty, and the Serenity has 45K. The EAGLE has no warranty.
CLearly, since something like the Primacy - with a 60K tread life - you are
apt to be riding with that "floating" feeling of a big sedan... so it all depends
on what you are looking for.
So.. there are lots of factors: non RFT, minus sizing the wheels down to 17",
and deciding whether you want pure summer and pure winter tire sets, or
compromise and get all seasons. Those 3 major decision points will be the
biggest factors that affect your ride. (There are certain physical properties
that come with the sport suspension - like stiffer ride- that you just can't
change). Once you decide on these 3 najor factors, then (in my opinion)
the tire Brand and specific choice of tire will determine tread life,
performance in rain (resistance to hydroplaning), performance in
light/moderate snow, etc.
Good luck. Hopefully, some of this will save you some time.
Old 04-17-2009, 07:07 AM
panerai7's Avatar
panerai7 panerai7 is offline
MT4LIFE
Mein Auto: E92-M3, E90-335
CA
I second that, had those on my e46 coupe before, great tires.
I have the General Exclaim UHP right now and it's one of the lightest tires out there and can even take a little snow, and of course the fact that they're cheap doesn't hurt.
Old 04-17-2009, 07:46 AM
zampag zampag is offline
Mein Auto: '12 X5 50i
CA
How are they with some snow? Looks like there's also a new version of these (down a speed notch to H) with a 45k tread warr. "Pirelli PZero Nero All Season" 91H 400/AA/A. I assume you need some adjustments with the TPM when swapped?
I currently have the sport package but with 225/45 17's all around.
2012 X5 50i
Sparkling Bronze/Oyster/Bamboo, Sport, Adaptive, Premium, Cold, Sound, Boards, 3rd
2009 335i
xDrive, Blue Water, Sport, Cold, Navi, Logic7, PDC, Assist, 6MT, RE960 non-rf (Prod 10/08)
1994 325i
Red, Leather, Cold, 5MT
Old 04-17-2009, 08:02 AM
hmr's Avatar
hmr hmr is offline
.oo=||=oo.
Mein Auto: Bimmers
You may want to give tirerack a call and see if the customer rep has any recommendations, too. Also, you may want to consider increasing the sidewall height a little (if you want to go in the extreme direction).
Edit: You may also want to post this question for forum member, Gary@TireRack, on this site's subforum: Tire Rack's Tires, Wheels, Brakes & Suspension.
Old 04-17-2009, 10:24 AM
dandanio's Avatar
dandanio dandanio is offline
The One who Drives.
Mein Auto: 11 f25 n55/09 Jetta TDI
My 2 cents: I drive a 3.5L Altima, with a spirit (not much longer, I hope!) and I have set of 4 those rubbers on my ride now.
The road noise is low, very acceptable.
Cornering and sidewalls are surprisingly sturdy and comfortable. Quick in-out lane changes are predictable and safe.
And the price/value ratio is excellent!
Highly recommended!
Trips and Pieces - My new blog for Travelers by Travelers!
Personal Euro Delivery Blog
My, somewhat outdated, BMW Euro Delivery of 2009 blog with pics!
Old 04-17-2009, 11:49 AM
bsell bsell is offline
Black Squared
Mein Auto: 1998 535 COSMOSSCHWARZ ME
Get the 17's, they don't ride that bad. It is stiff but liveable. (That's what she said!)
Yes, I have that setup on my sedan and with the much unloved Bridgestones.
The guy that ordered this car specifically ordered the 17's due to the bad press the 18's had received...he also skipped the I-Drive. Smart guy.
Brian
Old 04-17-2009, 12:12 PM
the328's Avatar
the328 the328 is offline
Enjoying Your Money
Mein Auto: 2009 328i
I'll swap my 17' for an 18' with pleasure. Just let me know
Old 04-17-2009, 12:13 PM
They are OK in light snow but if you are going to be using the car regularly in moderate to heavy snow they are not going to cut it. I rarely use the car in the snow ane we don't get much snow here (NYC). I stayed with the stock 18" size. I replaced the stock 189 rims with BMW OEM style 196 but that change was purely cosmetic. There is no performance advantage.
CA
The Glen Club
BMWCCA
Old 04-17-2009, 01:32 PM
fasttimes fasttimes is offline
Mein Auto: 99 Maxima GLE
Do the OEM wheels w/ RFT accept non-RFT tires?
I live in Northern VA, where we get a few snows a year. I was just planning on driving my Maxima during those times instead. However when I wear off the tread on the RFT's I might make a switch.
Old 04-17-2009, 01:53 PM
Yes they do. And the tire pressure monitor system will operate properly.
CA
The Glen Club
BMWCCA
Old 04-17-2009, 02:58 PM
CA
Cool, thanks. I'm going with Bridgestone RE960s. Seems to be the best for what I want - bias towards dry and wet, good tread, good ride, and snow traction a little better than the crape stock - Bridgestone EL42s. Probably a good pick for OPs original 'softer ride'.
2012 X5 50i
2009 335i
1994 325i
Old 04-17-2009, 03:31 PM
meyergru meyergru is offline
Mein Auto: E92 335iA
If you want to have a real smooth ride, you can do something more than just using non-RFTs:
Choose another tire size, namely 225/45 R18 and 255/40 R18, the same combination as the old M346. They fit. Speedo error is compensated, wheel wells are filled better and ride quality is superb.
Images here:
http://www.auto-treff.com/bmw/vb/sho...89#post2263489
Old 04-17-2009, 04:54 PM
riceqx2 riceqx2 is offline
Mein Auto: 335xi coupe
I like the "225/45 R18 and 255/40 R18, " suggestion, and will research that.
Old 04-18-2009, 05:55 PM
Images here:
You can fit those different tire sizes on the stock OEM wheels???
Old 04-18-2009, 07:17 PM
Michael Schott Michael Schott is offline
Mein Auto: 2011 328i
Brian
This is the best answer. Changing to a higher profile tire is the best way to improve the ride and may do more than just changing to non-RFT's. If you get another set of 18" tires they will still have short stiff sidewalls which are not conducive to a smooth ride.
Thanks, Mike.
Old 04-18-2009, 07:26 PM
Thanks, Mike.
I have a friend who has a car very similar to mine. They are both 07 335i comvertibles. Mine has the sport package, his does not. I replace the RFTs with Pirelli P_Zero Nero M&S he has the OEEM Bridgestones. He drove my car in his neighborhood (Fairfield County Ct.) and felt that mine had a smoother ride.
On another note. I was parked next to an E92 M3 tofay. It appeared to have stock rims and they were probably 18s. They seemed to have larger sidewalls than the 18s on my 335i.
The Glen Club
BMWCCA
Old 04-18-2009, 07:39 PM
Yes, I think they do. The tires on the M3 appear much more substantial than on our 3 series.
Old 04-18-2009, 08:03 PM
panerai7's Avatar
MT4LIFE
E92 m3 in 18 are 245/40 and 265/40 rear, in 19 are 245/35 and 265/35.
So yes they are beefier on an m3
