Old 04-17-2009, 07:16 PM
toledotn toledotn is offline
Mein Auto: 2000 bmw 5281
Unhappy 2000 bmw 528i automatic transmission fill location
Urgent, can someone tell me where the location of the ATF fill? I changed the filter and when I tried to fill the fluid into the reservoir it topped quickly after not even 1 quart. Thanks in advance.
Old 04-17-2009, 07:30 PM
540iman's Avatar
540iman 540iman is offline
resident, old fart
Mein Auto: 2002 540i sport
If it is like my 540, you don't have a fill tube. You have a plug just above the pan that you remove and add fluid until the fluid starts to run out the hole and then you are full. Remember that our cars have "lifetime" trans fluid-yeah, right.... Are you saying that after you dropped the pan and changed the filter and put the pan back on, it would only take a quart? Should take 4-5 with the torque convertor still being full.
Old 04-17-2009, 07:37 PM
I tried to fill through the reservoir by the engine.
Old 04-17-2009, 07:39 PM
And what did you use to fill? Thanks for the info you are giving me I appreciate it.
Old 04-17-2009, 08:07 PM
lild's Avatar
lild lild is offline
livin the 'Fest
Mein Auto: 97' 528i, 06 ninja
there is no atf resevior, i hope you just didn't put atf into the oil pan. if you pulled out a red handled dip stick that's the oil dipstick. your suppose to fill at the tranny pan. theres a bolt on the drivers side towards the top of the tranny pan. if you put atf in the oil pan your gonna need to change the oil.
The more you complain, the longer God makes you live. SPHOBA #00002
Old 04-17-2009, 08:47 PM
there is a reservoir nx (it says atf fluid only) to the oil filter. thanks
Old 04-17-2009, 08:48 PM
Mikes00528i Mikes00528i is offline
Mein Auto: 2000 Electric Red 528i
Sounds to me like you are talking about the power steering reservoir that has ATF on the cap and sits right next to the oil filter housing. Not enough details though.
Old 04-17-2009, 08:50 PM
Oops you beat me to the post. Yup, thats your PS reservoir. So where is this ATF filter you changed out?
Anyways, your PS reservoir takes Dexron III fluid.
Old 04-17-2009, 09:04 PM
the ATF filter i changed out is at the bottom of the tranny, by removing the pan with i think 20 bolts? right there, hey thanks guys this is very helpful i really appreciate it i am learning a lot from you guys.
Old 04-17-2009, 09:19 PM
lild's Avatar
livin the 'Fest
heres a link even though it covers the 3 series, it is the same diy procedure.
http://www.pelicanparts.com/bmw/tech...Fluid_Auto.htm
Old 04-17-2009, 09:24 PM
And although this is from the other forum, a great resource nonetheless.
http://forums.bimmerforums.com/forum...d.php?t=860655
Old 04-17-2009, 11:20 PM
mike, thank you very much for the info it was helpful also everybody thank you very much
Old 06-27-2014, 10:26 AM
Al_e39 Al_e39 is offline
Mein Auto: 528i
Can someone help me out I'm confused do I put power steering fluid or atf fluid in the resivort that has the cap atf only
Old 06-27-2014, 10:33 AM
kutcht1 kutcht1 is offline
Mein Auto: 2002 530iA
That would be ATF Bob. The power steering system takes Automatic Transmission Fluid, Dex III.
TomK
2002 530iA Sterling grey Metallic 97,000 miles
2006 Volvo XC70 Blue/tan 133,000 miles
Old 06-27-2014, 12:43 PM
Mein Auto: 528i
Ey thanks man
