Old 09-02-2015, 10:45 AM
vauxpartsuk vauxpartsuk is offline
Mein Auto: BMW 730D Astra GSiT
Talking BMW 730D 2006 Running issue please help
I have a 2006 BMW 730D.....
Basically driving home one evening it started "juddering" Missfiring" as slowing down and idling ruff on idle...
Now its got worse... you go to pull away it just says engine reduced power and then cuts out the engine and you go to restart it and nothing, push start again and it fires up.. it takes longer to start now but really have no idea of what the problem could be... the cars done 80k.
Any help would be grateful as really need the car on the road for work journeys. Thanks
Old 09-02-2015, 11:34 AM
v40lly v40lly is offline
Mein Auto: Mercedes S Class
That sounds to me, that you're problem is throttle body related. It's a common fault with E65's.
Old 09-02-2015, 11:35 AM
IS there any tests to do for this?? As all i keep getting is fueling codes? Thanks
Old 09-02-2015, 11:41 AM
I got these codes... 4560 4565 & 4570 all related to fueling..
Old 09-02-2015, 11:51 AM
It's going to be an intermittent problem, which gradually gets worse. These code readers are to be taken with a pinch of salt. The codes provided may not necessarily, be of any use to a BMW garage. Ultimately, you're going to need to take your car to the nearest reputable BMW specialist and pay for an electronic diagnosis. They'll be able to tell you what the problem is exactly and how much it'll cost to put right.
If, it is the throttle body, it ain't going to be cheap, I'm afraid.
Old 09-02-2015, 01:48 PM
PAPER's Avatar
PAPER PAPER is online now
CRISP & CLEAN
Mein Auto: Ford Pinto
have you checked your spark plugs , coils , or Maf yet ???
Old 09-02-2015, 02:14 PM
Rick in Yuma's Avatar
Rick in Yuma Rick in Yuma is offline
bimmerfest Supporting Member
Mein Auto: 05' 760li,94' H1,08'Smart
I hate to correct you Paper. You've been so knowledgeable and everything else. But I think you missed this one. I believe the 730 D is a diesel. That's the D designation. It would not have plugs or coil. It would have glow plugs or some type of heat to start it but after that they make no relevance to the running.
Old 09-02-2015, 03:32 PM
PAPER's Avatar
CRISP & CLEAN
Thanks for the correction I missed that .
Didn't even notice he was referring to a
Diesel .
Old 09-02-2015, 10:17 PM
Thanks for your help guys... I changed the glow plugs when i got the car a year ago so shouldnt really be them... i also give it a full service too.
Old 09-02-2015, 11:30 PM
This site does not really have a lot of diesel owners on it. Found this on a UK site. Realize it's for a five series. However the engine might be the same. Worth a shot looking here.
http://forum.bmw5.co.uk/topic/4965-530d-rough-idle/
Old 09-03-2015, 10:17 PM
Thanks guys... have booked in with BMW for Wednesday...
Old 09-12-2015, 10:35 PM
Had it diagnosed at Ardens BMW... they said injector number 5 leak back was no good... so i bought a brand new bosch injector... fitted that.. still the same... so, so far ive wasted 700 nearly and still same issue..
Old 09-13-2015, 05:23 AM
AActive AActive is offline
Mein Auto: BMW X3 e83LCI
Did you fit that injector youself?
your a brave man if you did . The fuel rails runs about 3000 bar of pressure . Enough to lob a few fingers off.
After you fit the the injector you need to code it in the DDE. each injector has a different no. And its stamped on the injector. You need to put this in the DDE.
Old 09-14-2015, 09:32 AM
Hi, yes did the injector myself... not hard to be honest.... and yes did program it too... but still made no difference... back to BMW now for further diagnostics... they cant find a problem... its not done the whole cutting out thing etc...
Old 09-14-2015, 09:54 AM
Andra V12 Andra V12 is offline
Mein Auto: 2005 760i
Reading the first post I thought fuel pump , maybe the electric in tank pump . I read something somewhere a while back regarding the juddering issue with bmw diesels which says it`s the high pressure mechanical pump , maybe the electronic diesel control ( EDC ) on the pump .
Tried to find that info , no go , but I found other info which may help .
First , a couple of UK companies can repair your pump if that is the problem .
http://www.ecutesting.com/bosch_vp44...p_repairs.html
http://www.bba-reman.com/uk/index.aspx EDIT WITH CORRECT SITE
And some posts from other forums by folk with the same codes , different remedies
http://www.bmwforums.info/bmw-3-seri...e-issue-2.html
http://www.bmwforums.info/bmw-electr...es-list-2.html
http://www.justanswer.com/bmw/1yc62-...injection.html
http://www.bimmerforums.co.uk/forum/...t138161-print/
http://www.justanswer.com/bmw/4y5vb-...xxxx-xxxx.html
Old 09-18-2015, 11:55 PM
bembo449 bembo449 is offline
Mein Auto: 730d sport
did you sort this issue ? just bought a 730d , it was running great but I still removed and blanked the swirl flaps and had a remap with EGR delete , 150 well spent and mores the point , prevents any of the usual 3.0d issues , I would have all your injectors reconned but before that , whip the inlet off and see if your swirls are working correctly ?
Old 09-21-2015, 04:03 AM
mathat mathat is offline
Mein Auto: 730d
Mine does a very similar thing (730d) but only when just started - runs fine for a minute and then starts to shudder for about another minute then fine for rest of the day (sometimes stalls), I have had no luck working out what it is but presume that it's not a injector as it would be constant, I was presuming that it would have something to do with fuel pressure (was going to use inpa to read values while running to see fluctuations) but very hard to find as you can only test once a day and no errors in memory (yet to do glow plugs)?
what year is yours (mine 05 facelift) - I was not sure if the flaps actually caused problems on this car -I know there was a problem with the 5 series but I thought it was sorted on this model (ie they don't fall into the engine anymore) - I also would have removed all the injectors - local shop here will check and clean them for 15 each and can recon if required?
