E36/7 Z3 (1996-2002) and E85 Z4 (2003-2008)
Coupe and Roadster talk with our gurus here... |
Hi,
I have been on a rattle hunt for the last couple of weeks, and I now have 2 out of 3 solved. First was the retaining spring/pin for the driver's side parking brake pads that had somehow worked loose and was twirling away inside the disc drum. Yesterday, I finally found the time to implement WarCamp's glovebox fix and my dashboard is blissfully silent again! My last annoying rattle was initially masked by the parking brake issue, but is now pretty obvious. It is coming from the driver side rear and happens whenever I go over bumps. It is definitely not the parking brake (adjustment or cable knocking against struts). However, I was under the car once again this morning looking for the source and it seems that the inner brake pad on that side is very loose and jiggly. With the car up, I can bang against the wheel or caliper housing and the brake pad rattles loudly. If I hold a finger on the brake pad, no rattle. The brake pads on the passenger side seem solidly in place, so I am guessing that this is the sound I am hearing. I am about to go out and tear the brake apart, but my guess is that the clip that holds the pad to the piston has either come loose or has somehow broken? These pads are Porterfield R4S's that only have 10K on them and have a lot of life still. If I do find a broken clip, is there anything I can do short of buying new pads? I'm guessing the answer is no. Any thoughts on what might have caused this or any repair ideas are much appreciated!
HaqDeluxe ![]() AKA: Michael G. 78' E21 - 320i Saloon - Resedagreen-Met 08' E60n - 535xiT Sport Touring - Space Grey-Met |
I am hoping that the different pads, right vs. left rear, will not cause a dangerous situation under hard braking. I will order a new replacement pad, but it will probably take a week or so before I get it.
The spring clip is NOT neeed for proper brake operation. They are needed only for quiet brake operation.
I would call Porterfield and ask them to either replace the pad, assuming you are SURE the install was done properly. Or at least go halves with them to send the defective one back for their analysis. You can change only the one pad.
Terry Carraway '95 Alpine M3 LTW '00 Dakar M Roadster '02 Topaz M3 Red/White SRF #4 (Chassis 561)
I'll be real interested in what Porterfield has to say. Just had my car teched for a track day and was told that my RR brake pad was loose.
Haven't pulled the brake apart but suspect that the clip is missing or mangled just like yours. I've got about 12K and 20 or so track days on the pads. They are 50% used, don't want to replace before the end of the season, so I'll probably pull it apart get rid of the remainder of the clip and run the rest of the season or 3-4 track days.
David Blue Ridge Mntns, NC 1999 2.8l Z3 Coupe Arctic Silver |
Just talked to "Tim" at Porterfield. They said they would replace the clips on the back of the pad and turn it around the same day if I sent it to them. Will do so tomorrow. He had nothing much to offer in the way of tolerance info or possible fitment problems. So, for the price of one way shipping and some close attention on my part when I reinstall the pad, I think this is the best outcome possible.
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
