1 series boot not unlocking - Bimmerfest - BMW Forums
Old 04-30-2009, 04:59 AM
simondixon simondixon is offline
Mein Auto: 1 series
Hi,
i have a 54 1-series 120i. When pressing the unlock on the key fob, the boot does not pop (the rest of the central locking unlocks). Any ideas? It is a royal pain in the ... as i have a child seat in and putting a push chair into the boot via the folding down seats is not easy.
Please help?
Old 04-30-2009, 05:35 PM
mclaren's Avatar
mclaren mclaren is offline
Chairman of the Bored
Mein Auto: 2014 M5
You have to hold it down for a few seconds, if you're doing that I don't know. You could change the key to unlock everything with the door unlock.
Old 05-01-2009, 08:30 AM
Mein Auto: 1 series
its not the key as both my keys don't work. is there a another way of opening the boot?
Old 05-01-2009, 11:31 AM
mclaren's Avatar
Mein Auto: 2014 M5
If you program the key to unlock everything then it unlocks the trunk but it does not pop up. you have to pull it up with your hand. You sure you're holding down the correct part of the key for at least 5 seconds ?
Old 05-01-2009, 07:06 PM
JAWJr's Avatar
JAWJr JAWJr is offline
Le plaisir de conduire
Send a message via AIM to JAWJr
Mein Auto: All Manuals
Have you solved the issue?
If not, I bet you the problem is that the truck lock switch is on in the glove compartment. To find it, open up your glove compartment, get down really low and look towards the upper left side. You'll see there's a switch where you can either completely lock or unlock your trunk. It's part of a valet system. Hope that helps!
~Jon
2013 135is | Le Mans / Black w/ Blue stitching | Manual | Premium | HK Sound
1991 318is | BrilliantRot / Natur ette' | Manual | Fogs | Sunroof
2009 135i Cp | Alpine White / Black Plastic Cow | ZSP | ZPS SOLD
2007 Z4 R 3.0i | Silber Grau / Dream Red | ZSP | 711 | 522 | 494 SOLD
2007 335i Cp | A61 / LCSW | ZPP | ZSP | 322 | 4AS | 609 | 655 SOLD
2005 DINAN 330Ci | Silber Grau / Alacantara | ZHP | ED 12.10.04 SOLD
Old 05-01-2009, 07:41 PM
mclaren's Avatar
Mein Auto: 2014 M5
~Jon
This sounds like the answer. Wish I would have thought of it.
Old 05-01-2009, 07:48 PM
AzNMpower32's Avatar
Tar Heel Faithful
~Jon
That's what I was gonna say. Check the switch in the glovebox.
Current consumption: Spritmonitor.de
Old 05-01-2009, 08:23 PM
ProRail ProRail is offline
"Clunker" *****
Mein Auto: 1999 BMW 528A-220K-traded
No fair. I'll bet you looked in the manual.
Old 05-02-2009, 06:56 AM
Tar Heel Faithful
I've read the manual so many times, I've almost memorised much of it
Old 05-06-2009, 01:16 AM
Mein Auto: 1 series
hi,
thanks for the replies. still no luck.
there is no switch in the glove compartment. At the back is a flap that pulls away and has the fuses on it. Is this what you mean???
Also is there a way to open the boot without the key? ie can the plastic facade in the boot it self be taken of and the boot popped manually?
Old 05-06-2009, 09:40 AM
kja325ci kja325ci is offline
Mein Auto: 2008 SGM 135i
Try dropping the rear seats and crawl inside. Then pull on the emergency handle.
Old 05-07-2009, 04:21 AM
Mein Auto: 1 series
where is this emergency handle you speak of?
Old 05-08-2009, 08:24 AM
neill neill is offline
Mein Auto: an old Camaro
Does the trunk open using the grip strip (soft touch pad) above the lic plate? I think the doors need to be unlocked as well
Old 05-09-2009, 05:57 AM
interestedbmw interestedbmw is offline
Mein Auto: E87
Try this:
Unlock the car with the remote control so all doors and boot are unlocked.
Then, with the boot closed, press and hold the boot unlock button on the remote for 1 second or longer and see if the boot pops open.
UK cars dont have the button in the glove box.
Let me know how you get on.
Old 05-14-2009, 03:43 AM
Mein Auto: 1 series
hi, i have managed to open the boot using the emergency handle. It seems to me that it is something electrical. Ie when pressiing the remote the boot is not lunlocking. I don't think it is a problem with the key fob (we have 2 and no difference), is it likely to be a fuse, wiring or something more complicated?
Old 06-22-2009, 02:01 AM
flirtz2009 flirtz2009 is offline
Mein Auto: bmw 116i
where is the emergency handle. the same problem happened to me
Old 06-22-2009, 04:46 AM
jsc's Avatar
jsc jsc is offline
Mein Auto: E85 M-Roadster, E82 135i
If you don't have the glovebox switch for enabling/disabling the remote boot unlocking, you probably have the switch in the boot lock itself. Is the boot lock slot horizontal or vertical? If it is horizontal, then try seeing if you can turn it to the vertical position and remove the key. The E46 3-series used this method of remote boot unlocking enable/disable. If this doesn't work, then it is probably electrical.
