Old 07-31-2003, 08:08 AM
gbrown gbrown is offline
M coupe
Mein Auto: 2001 M Coupe
Ordered a camera mount for the coupe.
Not wanting to drop megabucks on the harness bar and camera mount I found a suction cup type mount from ioport that seemed to work good enough for some NSX owners. It should be here Friday and I will put it through its paces and report back.
Old 07-31-2003, 10:32 AM
ScottMC ScottMC is offline
Mein Auto: 99 Mcoupe
I had that one and it sux,seriously. I have a HMS harness bar I will sell you if interested.
Old 07-31-2003, 10:35 AM
Jseely Jseely is offline
Mein Auto: 02 M Coupe
ScottMC - can you send details and the asking price on the harness bar to:
jseely at arcsight dot com
Thanks!
Old 07-31-2003, 05:39 PM
M coupe
If it shakes more than a crack addict in recovery then Ill send it back!
Old 08-01-2003, 06:59 AM
cozog's Avatar
cozog cozog is offline
Sir Mix-A-Lot
Mein Auto: 99 MCpe, 05 X3, 88 325is
Here's what I just got....
I had good luck with this package. I purchased it at Smile because they were ~$20 cheaper than anywhere else for that model. I used it on the right rear window and ran through the Dragon ~15 times without any issues. The only problem I had was that it leaves a little rubber residue behind. It create little rings that you have to rub off. But I expect any suction cup mount will do that.
Here's the stuff I have....
Suction Cup Description:
http://www.bogenphoto.com/product_te...=92&itemid=350
Purchase Here:
http://www.smilephotovideo.com/detai...&itemno=BG3294
Mounting Plate Description:
http://www.bogenphoto.com/product_te...hp3?itemid=325
Purchase Here:
http://www.smilephotovideo.com/detai...&itemno=BG2934
3/8 to 1/4 Adapter Description:
http://www.bhphotovideo.com/bnh2/con...ku=5588&is=REG
Purchase Here:
http://www.smilephotovideo.com/detai...&itemno=BG3358
Good Luck!
Old 08-02-2003, 09:28 AM
M coupe
I just tested it out a but, works awesome IMO. Mounted on back window also, took very smooth footage with my Canon Elura2 mini DV.
Old 08-02-2003, 09:29 AM
M coupe
The one I have is the HAMA autostativ mount. $99.
Old 08-02-2003, 11:51 AM
Im happy it works for you, its probably my stiff suspension setup.
Old 08-02-2003, 02:14 PM
M coupe
Im running Bilsteins and H&R's - still worked great. Might also be the camera quality.
