E36 (1991 - 1999)
Old 05-05-2009, 10:35 AM
JayCee1998beat1 JayCee1998beat1 is offline
Mein Auto: 1998 328is
Codes P0443 and P0111
After replacing the crankcase oil separator(PCV) valve which froze up on me one day and shot oil into my intake through the cats and out the tailpipes, I thought my engine was shot but was not the case. After everything was replaced and cleaned, the car is running like a top, even went with synthetic and replaced dirty K&N filter set up back to stock. Problem is I'm getting these 2 codes (P0443-purge control valve) and (P0111-Intake air temp. sensor)
Has anybody had these problems and resolved them ? Can't pass Ct. state emissions so I can't register the vehicle which means I can't drive it.
Old 05-06-2009, 10:20 AM
Anybody?
Old 03-29-2011, 07:28 AM
tbs04 tbs04 is offline
Mein Auto: 328is
p0443 and p0111
I am haqving the exact same problem and I am trying to track down the culprit. What did you do to solve your issue?
Timothy Smith
Old 11-21-2012, 05:44 AM
MaxwellSimons MaxwellSimons is offline
///M Power
Mein Auto: 1997 E36 Cosmos M3 S52
You switched your Evap Purge valve and IAT Sensor, seeing as the connections look the exact same.
Or you need to replace them.
