E46 (1999 - 2006)
Old 05-06-2009, 06:16 PM
kpetelski1 kpetelski1 is offline
Mein Auto: 2002 330ci
auxiliary fan will not stop running
I have a 2002 330ci and my front auxiliary fan will not stop running. The only time it stops running is when the battery is unplugged or when I disconnect the wires from the fan. Today I replaced the water temp sensor and it still runs all the time.
Old 05-06-2009, 06:17 PM
KrisL's Avatar
KrisL KrisL is offline
Ubergeek
Send a message via AIM to KrisL Send a message via Yahoo to KrisL
Mein Auto: 330i ZHP
Sounds like the relay is bad.
Old 05-06-2009, 06:30 PM
Is the relay where all the wires from the fan go. Square looking thing?
Old 05-06-2009, 06:35 PM
KrisL's Avatar
Ubergeek
Mein Auto: 330i ZHP
Yup.
Old 05-06-2009, 06:37 PM
denice25 denice25 is offline
Mein Auto: car
better check the relay...
"thanE"
Old 05-06-2009, 06:57 PM
which relay is responsible for the axillary fan?
Old 05-06-2009, 10:56 PM
Brian McKinney's Avatar
Brian McKinney Brian McKinney is offline
BMW Nuthead
Mein Auto: e92 M3 6mt
does it have a fan clutch or electric fan?
08 M3
TMS pulley
RPi scoops and drop in filter
DRB Motorsports axle back exhaust
Old 05-06-2009, 11:02 PM
KrisL's Avatar
Ubergeek
Mein Auto: 330i ZHP
Seeing as how it only shuts off when he disconnects the battery, I'm going to guess he's talking about the auxiliary electric fan.
Old 05-06-2009, 11:12 PM
BMW Nuthead
well my electric fan is both the cooling fan and the aux fan....when my went it ran all the time. I had to replace the entire unit, problem solved
08 M3
TMS pulley
Old 05-07-2009, 06:44 AM
Solidjake's Avatar
Solidjake Solidjake is offline
Zero. Leaks.
Mein Auto: 02 330i 6MT
To cool down the car when it gets hotter than normal.
You need that thing running properly.
Old 05-07-2009, 07:52 AM
KrisL's Avatar
Ubergeek
Mein Auto: 330i ZHP
I think you identified it yourself.. the small box that all of the wires from the fan run into. A unit located right on/near the fan.
Old 05-25-2009, 05:51 PM
necrophielia necrophielia is offline
Mein Auto: 1999 328i
Any word on if changing the relay fixed this problem? the 99 328i I'm picking up this Tues or Weds has the exact same problem.
Old 05-25-2009, 05:56 PM
Dave 330i's Avatar
Dave 330i Dave 330i is offline
The King of Common Sense
Mein Auto:
or a bad temp sensor. disconnect the sensor to see if the fan stops. check the resistance across the temp sensor when it is hot (use a hair dryer) and at room temp. Manual trans doesn't have the aux fan.
Everybody is a genius. But if you judge a fish by its ability to climb a tree, it will live its whole life believing that it is stupid. Albert Einstein
Swim upstream. Go the other way. Ignore the conventional wisdom. If everybody is doing it one way, there’s a good chance you can find your niche by going exactly in the opposite direction", Sam Walton.
Old 05-26-2009, 03:09 AM
That was my next guess. the temp readout in the dash reads exactly halfway all the time. And the fan I was refering to is the electric one that is just behind the radiator. I should be paying for the rest of the car either today or tomorrow so I'll be able to tinker more. The dealer said the fan wont turn off so they unplugged the fan. Don't remember if that same connector somehow runs to the temp sensor or not, but if not that was my guess too. Thanks for the reply
Old 05-26-2009, 06:29 AM
Dave 330i's Avatar
Mein Auto:
I heard that one before.
Old 05-26-2009, 10:40 AM
haha, well the $150 fix might have just turned into a $20 fix. thanks mate
Old 11-09-2012, 06:56 PM
Charlotte330ci Charlotte330ci is offline
Mein Auto: 330ci Convertable
Where exactly is the sensor. My auxiliary fan will not stop either. I put on a trickle charger and the fan immediately starts up again. I just want to get it to the shop.
Old 11-11-2012, 06:00 AM
my05crf280 my05crf280 is offline
Mein Auto: 2000 323i 5spd
I would definitely say sensor before relay. relays can go bad buts its rare. I know the relays are problematic on the keyless but that's more of a surface mount solder connection problem. either way. pulling the relay would tell u what's wrong. if you pull it and it clicks. that tells you its the sensor. if its frozen it will not click. then replace the relay
330ci, auxiliary fan, e46, fan
