E36 (1991 - 1999)
Old 07-30-2011, 08:59 PM
Eight Thirty Eight Thirty is offline
Hellawut??
Mein Auto: who knows?
Havent got a clue whats going on
This car im trying to fix.
Aftermarket alarm: Crime stopper cs-2000 dph series IV
Aftermarket radar: 3 band K40
Its EWS2 CONFIRMED. Transponder key and box under the dash says ews2 on it.(the white one)
Its a 1995. build date 6/95.
It has a m50.
The car has a no start issue. lights on the dash all come on. but no cranking.
I just the green wire to the black/yellow wire on the back of the ignition, no crank.
The aftermarket alarm is getting full voltage.
Battery checked in at 12 volts.
Swapped relays (not sure exactly which ones i had to swap for the ignition to work/dont work)
There is 2 green wires that run im guessing to the transponder thing around the ignition. but dont actually connect to anything
Any way to just delete the EWS 100%. but still have it all work
The guy said he does not car how i get the car running. he wants it running and he is going to pay me and give me a full set of brand new winters on rims. (I really need)
How easy can i just disable the aftermarket alarm. take it out 100%. make the car be normal again.
Any help would be helpful
-Franklyn
Old 07-30-2011, 09:15 PM
hornhospital's Avatar
D'oh, You Kids!
Mein Auto: E24x2,E36x2,E30x1, F150
I'm pretty sure the transponder HAS to be connected for the thing to crank.
Quotes to live by:
Ken Kanne, Silverhill, AL, E36 & New Member Intro Forum Mod/Bimmerfest Misplaced-Posting Tow Truck
BMW-CCA #441426 Which is worse, ignorance or apathy? I don't know, and I don't care!
1995 318is "Bebe"; 1993 325is "Elvira"; 1985 635CSi "Katja"; 1984 633CSi "Sylvia"; 1987 325is "Odette"
Old 07-30-2011, 09:17 PM
Hellawut??
What exatly goes on in the transponder.
I have 2 open green wires. and i have a transponder ring where i can see the little wires that run around the ring. then one wire sticking out.
What do/can i connect the green wires to to make the key be recognized again
-Franklyn
Old 07-30-2011, 09:18 PM
BMRfanatic's Avatar
BMRfanatic BMRfanatic is offline
Mein Auto: Bad Luck 46
One wire is sticking out of the ring? Put it back in then you SHOULD be able to start to the car
-Dino
Old 07-30-2011, 09:20 PM
Hellawut??
let me draw it....
-Franklyn
Old 07-30-2011, 09:28 PM
Hellawut??
If there is a way i can "jump" the transponder. let me know.
-Franklyn
Old 07-30-2011, 09:34 PM
BMRfanatic's Avatar
wtf? (not at your drawing, at the transponder and wires)
i would think the green wires would go into the ring
but i have no idea why there are tiny little wires all around it though
-Dino
Old 07-30-2011, 09:36 PM
Hellawut??
they are whats inside of the ring. i dont know how the green wires attacth to the ring.
Or if they should in a specific way.... know what im trying to say?
-Franklyn
Old 07-30-2011, 09:41 PM
BMRfanatic's Avatar
i think i understand what your saying...
does the ring look like this?
-Dino
Old 07-30-2011, 09:42 PM
Hellawut??
yes
but see how the plug thing comes off the circle? imagine that broken off.
-Franklyn
Old 07-30-2011, 09:44 PM
BMRfanatic's Avatar
that might be the problem.
hold on a sec...
-Dino
Old 07-30-2011, 09:48 PM
BMRfanatic's Avatar
from what i read to disable ews
you would "Cut wires 1 and 3 from the EWS harness plug (behind glovebox) and solder them together."
"Wire 1 goes to the starter solenoid, and wire 3 is from the ignition switch in the steering column. Connecting these wires effectively bypasses the system PROVIDED THAT you actually have a ECU that doesn't require a EWS signal to be present"
since its an M50 it would have a 413 Red label and work fine without EWS right?
-Dino
Old 07-30-2011, 09:52 PM
BMRfanatic's Avatar
lol.....wait didnt cj have to bypass ews when he did his motor swap?
He might know the secret!!
-Dino
Old 07-30-2011, 09:53 PM
Hellawut??
get ahold of him!!! idk how.
and if i fix this then i get the money.
If he fixes it... i dont.
-Franklyn
Old 07-30-2011, 10:01 PM
BMRfanatic's Avatar
i know it may sound stupid but....
did you un-arm the alarm and try starting it
-Dino
Old 07-30-2011, 10:02 PM
cj.surr's Avatar
cj.surr cj.surr is offline
some kid
Mein Auto: whiny 318
Alls I did was cut the EWS cable from the harness connector by the fusebox. I only had to do that because I was using the red label DME (no ews) from my old car.
I really have no clue as far as this goes...
-CJ
Old 07-30-2011, 10:05 PM
Hellawut??
http://forums.bimmerforums.com/forum...4&d=1174884627
this picture shows how to eliminate the key from the equation right?
no more transponder needed if i do that^^
and then that will allow the car to start if it cranks because the igniton and fuel system will work?
http://forums.bimmerforums.com/forum...6&d=1174885855
then this one will bypass the part of the EWS thats making the starter not work.
Right?
-Franklyn
Old 07-30-2011, 10:06 PM
cj.surr's Avatar
some kid
^ Bitches won't let you steal the pics
-CJ
Old 07-30-2011, 10:09 PM
cj.surr's Avatar
some kid
And to bypass the EWS, I believe you need a DME that does not require EWS. Which the car would obviously NOT have, since it was equipped with EWS.
-CJ
Hellawut??
**** that they wont... watch me...
-Franklyn
Old 07-30-2011, 10:14 PM
Hellawut??
Right?
-Franklyn
Old 07-30-2011, 10:18 PM
cj.surr's Avatar
some kid
That seems right... But I'm not sure how the aftermarket alarm fits into all this. Is it connected to the EWS? So you disable the EWS and the alarm gets disabled too?
-CJ
Old 07-30-2011, 10:21 PM
Hellawut??
dont care where the alarm fits in..
as long as the car runs/starts he doesnt care either and i get $$ and tires.
-Franklyn
Old 07-30-2011, 10:22 PM
cj.surr's Avatar
some kid
I'm just wondering if the alarm will cause the car to still not run even if you disable the EWS
-CJ
