Old 07-25-2003, 01:53 AM
StevzZ3's Avatar
StevzZ3 StevzZ3 is offline
Analyzer Tech.
Mein Auto: 2000 Z3 , 3/blk.
Question Temp. sensor
Anybody know the thread size of the Z3 oil press.(idiot light) sending unit? I need some kind of "T" or "Y" fitting for my oil temp. gauge. Looking for ideas or part. Thanks,
Steve H.
2000 Z3
SchwarZ II x III
Old 07-25-2003, 06:22 AM
Randy Forbes's Avatar
Randy Forbes Randy Forbes is offline
Investigative Tinkerer
Mein Auto: ///Motorized Vehicles
Steve,
I got your E-mail (& PM), I just haven't been able to get back around to verifying the thread sizes (been a little busy trying to get two cars back on the road, police, insurance, neighbors, etc.).
When Maddox asked me about doing them, I ran off three adapter blocks. I sent one to Danno to "test" but since his engine is out...
I need to thread one of the other blocks for you and order a Banjo bolt (the block will need to be machined for the Banjo bolt once it arrives).
Thirty year high school reunion this weekend so I won't be home until sometime Sunday.
Randy Forbes
1957 Austin-Healey 100/6 Wine Red
1961 McCulloch R1 go-kart Screaming Yellow
1999///M Rdstr Cosmos Black Eurosport Twinscrew S/C
1999///M Coupe Estoril Blue Eurosport Twinscrew S/C
2001///M Rdstr Steel Gray
2011 X5 35i Sport Deep Sea Blue/Cinnamon
Old 07-25-2003, 01:53 PM
StevzZ3's Avatar
Analyzer Tech.
Cool
Much Thanks Randy. Let me know, I have plenty of other projects going on right now also. LeMans racing here Sunday, NHRA next Sunday, Historic Racers BMWFestorics at Laguna Seca, HC03(maybe)!
Have Fun,
Steve H.
2000 Z3
SchwarZ II x III
Old 07-25-2003, 05:54 PM
Ron Stygar's Avatar
Ron Stygar Ron Stygar is offline
19,585 Miles
Mein Auto: Z4 M Coupe 6LL93033
Steve H.
M12 - 1.5
Old 07-25-2003, 06:09 PM
StevzZ3's Avatar
Analyzer Tech.
Talking
Originally Posted by Ron Stygar
M12 - 1.5
Thanks much Ron.
Steve H.
2000 Z3
SchwarZ II x III
Old 07-25-2003, 08:21 PM
M12 - 1.5
Yes, that sounds right.
The VDO pressure transducer that Jon sent me was M10 - 1.0 so I was hesitant to say.
I'll try to dig up a picture of it (there's one posted "here" somewhere in the archives...)
Randy Forbes
Old 07-25-2003, 08:28 PM
JonM's Avatar
JonM JonM is offline
Moderator
Mein Auto: 01 Mc, 08 M3, Motorrad x2
Correct. VDO sender is M10x1. BMW uses M12x1.5, so you need an adapter.
Jon Maddux
08 E90 M3 | 06 M Coupe | 01 M coupe | 99 M coupe
http://coupenut.blogspot.com/
http://x5nut.blogspot.com/
Old 07-25-2003, 08:29 PM
Ron Stygar's Avatar
19,585 Miles
Yes. That one is tapered.
Old 07-25-2003, 08:50 PM
Steve,
Here is the preliminary design.
I have since come up with a much more streamlined version to accomplish the same function, but you'll get the idea.
Randy Forbes
Old 07-26-2003, 10:57 PM
StevzZ3's Avatar
Analyzer Tech.
Thumbs up
Randy, that looks good to me. There is not much room there. My sensor would work for the VDO in there but I do not have a large oil press. transducer there. I believe it is for the idiot light the Z has. Its smaller in size than the transducer. I was "assuming" it just screwed in, without an adapator but I really did not look that good. Clue me in. Would I need a M12x1.5 (male) banjo with a M12x1.5(female) for idiot light, and a M10x1.0(female) for the VDO sender?
Steve H.
2000 Z3
SchwarZ II x III
Old 07-27-2003, 08:18 AM
Steve H.
As set up for an M-54/S-52:
The intent was to remove an existing temperature sensor and replace it with this 3-port adapter block (one port for the existing temp sensor and an additional port for the newly added pressure sensor). The adapter would be attached by means of the Banjo Bolt.
You would need to verify the port size required for the oil temperature sending unit you wish to install. Looking at the bright side, it is not likely to be smaller than the hole I have pre-drilled in one of the blocks I already have roughly 80% finished...
Or, we start all over
Do some research and let me know.
Randy Forbes
Old 07-29-2003, 12:24 PM
StevzZ3's Avatar
Analyzer Tech.
Cool
Randy, the oil temp.sender is a VDO M12 x 1.5. Is that doable?
Steve H.
2000 Z3
SchwarZ II x III
Old 07-29-2003, 12:33 PM
StevzZ3's Avatar
Analyzer Tech.
Cool
Randy, the VDO temp. sender is M12 x 1.5. Same size as oil pressure idiot light sensor. Still doable?
Steve H.
2000 Z3
SchwarZ II x III
Old 07-29-2003, 09:05 PM
Steve H.
Steve,
So to summarize, you need an adpater that mounts (via M-12 x 1.5 Banjo Bolt) where your existing idiot light sensor is and has a port for that sensor and another port for your VDO M-12 x 1.5 temperature sensor. Both threaded ports will be M-12 x 1.5.
Doable.
Why don't you send me an E-mail (erandyforbes@aol.com)?
Randy Forbes
