Old 05-09-2009, 07:02 PM
BMW GUR1's Avatar
BMW GUR1 BMW GUR1 is offline
Mein Auto: 2005 BMW 330i
M3 220 STYLE RIMS ON A 2007 335i COUPE!!!!!
OK so I really love the 2009 M3 rims...I am thinking about getting some for my 2007 335i Coupe. I don't know much about rim specs and such. Is this an easy task? How much am I looking at for labor besides the rim cost? Will BMW swap out for me? Should I buy them from ebay and have a wheel shop put them on for me? Do you think they will rub? Any help is appreciated!! Also I am looking to buy real M3 rims and not replicas!!!!!
"ONLY 22 AND I ALREADY OWN TWO BMW'S"
Old 05-09-2009, 07:27 PM
stompdx stompdx is offline
Mein Auto: '09 Accord Coupe LX-S
First off, I'm not sure if the wheel well is big enough to accommodate the 220Ms.
The 230 Style 19" available on the 335 Coupe use 225 front and 255 rear tires, the 220Ms are 245 front, 265 rear.
The 220M's are a $1,200 option on the E90/92 M3. So, I imagine that being the highest price to pay. Not sure of 3rd party sellers with OEM BMW rims.
If the first two points check out, getting the rims replaced shouldn't be too costly. I think I did my Non-RFT swap for like.... $150? (I think I had them aligned while I was at it) + a $20 to tip the guy.
I got 2 years to get my second bimmer if I wanna keep up with u
2007 328i E90 - Jet Black|Black Leatherette|Aluminum|Sports|Steptronic|Memory Seats - 5/07-3/09
Old 05-09-2009, 09:00 PM
Orient330iNYC's Avatar
Orient330iNYC Orient330iNYC is offline
Flying monkey herder
Mein Auto: Daihatsu Terrios
OEM M3 rims WILL NOT fit the regular coupe or sedan. the offsets are too aggressive.
these are the M3 220 rims:
02ALLOY RIM FORGED81/2JX19 ET:292
36112283555
02ALLOY RIM FORGED91/2JX19 ET:232
36112283556
these are the stock coupe rims:
02Light alloy rim8JX18 ET:342
36116768858
02Light alloy rim81/2JX18 ET:372
36116768859
the fronts will extend another half inch, which might be ok. unfortunately, your front fenders are plastic, so you cant just roll them for more clearance.
the rears however stick out 1.25" more. you would need custom fender work to get them to fit without rubbing. I'm not sure a fender roll will allow for that much space.
FYI, MSRP for the front pair is 1500, the rears are 1550, total of 3K for the set. figure another 1-2K for the proper tires, you're looking at 4-5K for the wheels and tires, plus whatever body work you'll need to do to get them to fit.
Past: 2001 330i ZSP/ZPP/Step
Past: 2004 S60R 6MT Sport
Past: 2013 335i 6MT ZMM/ZDH/ZTP/3AG/494/508
Present: 2016 F34 335i xDrive ZCW/ZDA/ZDH/ZTP/ZMP/2V5/5DL
Old 05-10-2009, 07:08 AM
bigshug1 bigshug1 is offline
Mein Auto: 2006 330i
The rims will cost considerably more than $1200 - that's actually the cost over and above what the stock rims and tires cost...make sense?
Old 05-10-2009, 10:33 AM
I see, didn't quite think that through fully
Old 04-28-2014, 06:35 PM
Phipps Phipps is offline
Mein Auto: 2008 328i Sport Sedan
Did this ever get attempted? I'm in same boat and been told the fronts go out another 11mm and rears 27mm. Which seems like it would work unlowered
Old 03-02-2015, 08:02 PM
Yssenneh Yssenneh is offline
Mein Auto: 335i
Check out this video, 220m style rimes on a 335i. Looks so clean!!!
